Broadlink RMpro+
Posted: Thursday 12 April 2018 15:21
Since one week, I try to use the new version of the Broadlink RMpro+ without success.
I use the BroadlinkRM2 plugin, I'm able to discover the RMpro+ but not to connect to it.
see my log. (I replaced the Mac's address by XXXXXXXX)
I begin to think that it's not possible to use this version. Someone have one and successfully connected to Domoticz?
Thanks in advance for your feedback
2018-04-12 14:54:10.369 Domoticz V3.9208 (c)2012-2018 GizMoCuz
2018-04-12 14:54:10.369 Build Hash: ff40091a, Date: 2018-04-08 17:15:17
2018-04-12 14:54:10.370 Startup Path: /home/pi/domoticz/
2018-04-12 14:54:10.406 Sunrise: 07:06:00 SunSet: 20:23:00
2018-04-12 14:54:10.406 Day length: 13:17:00 Sun at south: 13:05:00
2018-04-12 14:54:10.406 Civil twilight start: 06:37:00 Civil twilight end: 20:53:00
2018-04-12 14:54:10.406 Nautical twilight start: 06:01:00 Nautical twilight end: 21:29:00
2018-04-12 14:54:10.406 Astronomical twilight start: 05:24:00 Astronomical twilight end: 22:06:00
2018-04-12 14:54:10.406 EventSystem: reset all events...
2018-04-12 14:54:10.487 PluginSystem: Started, Python version '3.4.2'.
2018-04-12 14:54:10.496 Active notification Subsystems: (0/14)
2018-04-12 14:54:10.497 WebServer(HTTP) started on address: :: with port 8080
2018-04-12 14:54:10.502 WebServer(SSL) started on address: :: with port 443
2018-04-12 14:54:10.503 Proxymanager started.
2018-04-12 14:54:10.504 Starting shared server on: :::6144
2018-04-12 14:54:10.505 TCPServer: shared server started...
2018-04-12 14:54:10.505 RxQueue: queue worker started...
2018-04-12 14:54:12.505 (Rmpro) Started.
2018-04-12 14:54:12.506 EventSystem: reset all events...
2018-04-12 14:54:12.506 EventSystem: reset all device statuses...
2018-04-12 14:54:12.626 Python EventSystem: Initalizing event module.
2018-04-12 14:54:12.626 EventSystem: Started
2018-04-12 14:54:12.627 EventSystem: Queue thread started...
2018-04-12 14:54:12.907 PluginSystem: Entering work loop.
2018-04-12 14:54:13.115 (Rmpro) Entering work loop.
2018-04-12 14:54:13.116 (Rmpro) Initialized version 4.0.0, author 'zak45'
2018-04-12 14:54:13.169 (Rmpro) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2018-04-12 14:54:13.169 (Rmpro) 'Mode2':'/home/pi/domoticz/plugins/BroadlinkRM2'
2018-04-12 14:54:13.169 (Rmpro) 'Version':'4.0.0'
2018-04-12 14:54:13.169 (Rmpro) 'Mode1':'xxxxxxxxxxx'
2018-04-12 14:54:13.169 (Rmpro) 'DomoticzHash':'ff40091a'
2018-04-12 14:54:13.169 (Rmpro) 'HardwareID':'2'
2018-04-12 14:54:13.169 (Rmpro) 'DomoticzVersion':'3.9208'
2018-04-12 14:54:13.169 (Rmpro) 'Mode4':'yes'
2018-04-12 14:54:13.169 (Rmpro) 'Address':'192.168.0.71'
2018-04-12 14:54:13.169 (Rmpro) 'Port':'0'
2018-04-12 14:54:13.169 (Rmpro) 'Mode6':'Debug'
2018-04-12 14:54:13.169 (Rmpro) 'Key':'BroadlinkRM2'
2018-04-12 14:54:13.169 (Rmpro) 'Mode3':'RM2'
2018-04-12 14:54:13.169 (Rmpro) 'HomeFolder':'/home/pi/domoticz/plugins/BroadlinkRM2/'
2018-04-12 14:54:13.169 (Rmpro) 'DomoticzBuildTime':'2018-04-08 17:15:17'
2018-04-12 14:54:13.169 (Rmpro) 'Name':'Rmpro'
2018-04-12 14:54:13.169 (Rmpro) 'Mode5':'9000'
2018-04-12 14:54:13.169 (Rmpro) 'Author':'zak45'
2018-04-12 14:54:13.169 (Rmpro) Device count: 4
2018-04-12 14:54:13.169 (Rmpro) Device: 1 - ID: 1, Name: 'Rmpro - Command', nValue: 0, sValue: 'Off'
2018-04-12 14:54:13.169 (Rmpro) Device ID: '1'
2018-04-12 14:54:13.169 (Rmpro) Device Name: 'Rmpro - Command'
2018-04-12 14:54:13.169 (Rmpro) Device nValue: 0
2018-04-12 14:54:13.170 (Rmpro) Device sValue: 'Off'
2018-04-12 14:54:13.170 (Rmpro) Device LastLevel: 0
2018-04-12 14:54:13.170 (Rmpro) Device: 2 - ID: 4, Name: 'Rmpro - Temp', nValue: 0, sValue: ''
2018-04-12 14:54:13.170 (Rmpro) Device ID: '4'
2018-04-12 14:54:13.170 (Rmpro) Device Name: 'Rmpro - Temp'
2018-04-12 14:54:13.170 (Rmpro) Device nValue: 0
2018-04-12 14:54:13.170 (Rmpro) Device sValue: ''
2018-04-12 14:54:13.170 (Rmpro) Device: 254 - ID: 2, Name: 'Rmpro - Remote', nValue: 0, sValue: ''
2018-04-12 14:54:13.170 (Rmpro) Device ID: '2'
2018-04-12 14:54:13.170 (Rmpro) Device Name: 'Rmpro - Remote'
2018-04-12 14:54:13.170 (Rmpro) Device: 255 - ID: 3, Name: 'Rmpro - Import', nValue: 0, sValue: 'Off'
2018-04-12 14:54:13.170 (Rmpro) Device ID: '3'
2018-04-12 14:54:13.170 (Rmpro) Device Name: 'Rmpro - Import'
2018-04-12 14:54:13.170 (Rmpro) Pushing 'PollIntervalDirective' on to queue
2018-04-12 14:54:13.170 (Rmpro - Import) Updating device from 0:'Off' to have values 0:'Off'.
2018-04-12 14:54:13.174 (Rmpro) Update 0:'Off' (Rmpro - Import)
2018-04-12 14:54:13.174 (Rmpro) Connecting to: 192.168.0.71:xxxxxxxxxxxx
2018-04-12 14:54:13.175 Error: (Rmpro) Error Connecting to Broadlink device....192.168.0.71
2018-04-12 14:54:13.218 (Rmpro) No ini file :/home/pi/domoticz/plugins/BroadlinkRM2/remote/plugin_remote_2.ini
2018-04-12 14:54:13.218 (Rmpro) Custom Commands for Remote not managed
2018-04-12 14:54:13.218 (Rmpro) Device Number begin to : 2
2018-04-12 14:54:13.218 (Rmpro) Processing 'PollIntervalDirective' message
2018-04-12 14:54:13.218 (Rmpro) Heartbeat interval set to: 30.
2018-04-12 14:54:22.617 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-12 14:54:22.635 (Rmpro) Processing 'onHeartbeatCallback' message
2018-04-12 14:54:22.635 (Rmpro) Calling message handler 'onHeartbeat'.
2018-04-12 14:54:52.622 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-12 14:55:22.626 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-12 14:55:22.648 (Rmpro) Processing 'onHeartbeatCallback' message
2018-04-12 14:55:22.648 (Rmpro) Calling message handler 'onHeartbeat'.
2018-04-12 14:55:22.649 Error: (Rmpro) Error getting temperature data from Broadlink device....Timeout
2018-04-12 14:55:22.649 Error: (Rmpro) Error Connecting to Broadlink device....192.168.0.71
2018-04-12 14:55:52.631 (Rmpro) Pushing 'onHeartbeatCallback' on to queue
2018-04-12 14:55:52.653 (Rmpro) Processing 'onHeartbeatCallback' message
2018-04-12 14:55:52.653 (Rmpro) Calling message handler 'onHeartbeat'.
2018-04-12 14:56:22.636 (Rmpro) Pushing 'onHeartbeatCallback' on to queue Thanks in advance for your feedback
