Login to Domoticz dashboard in another country.
Posted: Thursday 12 April 2018 11:12
by Rikdev
I am using Domoticz on a Raspberry pi with fix ip-adress. location Belgium. Everything is working ok as long as i stay in Belgium. on PC, whit app on Ipad en android smarthphone.
however, when i am in another country (France - the Netherlands) i can't login to my dashboard. How comes? What do i do?
Re: Login to Domoticz dashboard in another country.
Posted: Thursday 12 April 2018 11:56
by freijn
That is remarkable you have a fixed ipaddress.. Most providers don't do this.
An ipadress ( public internet ) is routable from the world. So I guess you mix-up things..
As ( apperantly ) your ipaddres is on the internet exposed. Can you share it with us so we can see/investigate the routing to it ?
Cheers,
Frank
Posted: Thursday 12 April 2018 12:27
by Egregius
Telenet provides semi fixed ip addresses for home customers. As long as the router isn't unpowered for several hours you'll keep the same ip.
On what port does domoticz listen? I would guess you run into firewall issues.
Posted: Friday 13 April 2018 19:08
by gordonb3
AFAIK it is common practice to filter well known private use ports and addresses between providers. Which includes at least RFC-1918 addresses, but may also include port 8080 (private web server) and 8085 (tomcat). Of course if you are on some public Wifi access point when abroad then other outgoing rules may apply. As a rule: if you want to be certain you can access Domoticz from the outside, use a commonly accepted port (http, ssmtp, submission, imap, pop3) and be aware that http my be proxied so the type of traffic must match the protocol
