Change threshold of open/closed of level/percentage
Posted: Monday 09 April 2018 9:24
Part of my domoticz installation are some forest shuttle curtain rails. I've configured them as 'blinds percentage inverted'. This allows me to open and close them and set them to an inbetween level as well.
However, some of the curtains do not go to the end (either open or closed completely). For example, one of the curtains does not want to be at 0%. I set it to zero, the curtain closes, but after about 10 to 20 seconds the device says it is at 1% instead of 0%. I've reset the end positions several times, and this works for some time, but after a while the issue returns. For the curtains themselves this is not really a problem, there is a little bit of overlap so they are actually completely closed.
The problem is with the device on the dashboard. It only shows the curtains as closed if the level is exactly at 0%. So the curtains are actually closed, but the device says they are open. Is there a file somewhere where I can change how it determines if it is closed or open? So instead of saying closed only at 0% it will say closed if it is <4% or whatever percentage is put into the file.
Does anyone know in which file this can be done?
