Outdoor Temperature sensor (alternative to DHT22)
Antori91
Domoticz version: 4.10717
Post by Antori91 »
As an alternative to DHT22 sensor which is not supposed to be used outdoors, which sensors would you recommend? (I will use this sensor with ESP8266)
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
LouiS22
Re: Outdoor Temperature sensor (alternative to DHT22)
Post by LouiS22 »
Antori91 wrote: Monday 09 April 2018 9:21 Hello,
Why don't you just use a cheap 433mhz one? (assuming you have a decoder :) ).
Antori91
Post by Antori91 »
I use only WiFi as home automation network (and don't want to use anything else as network except for my wired alarm appliance)
LouiS22
Post by LouiS22 »
Antori91 wrote: Monday 09 April 2018 9:27 I use only WiFi as home automation network (and don't want to use anything else as network except for my wired alarm appliance)
I see.
Si7021 then? Works great with ESP8266
Antori91
Post by Antori91 »
Thanks LouiS22
