global_data question
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
I have a friend who is gonna use Domoticz as well. We have global_data for some things.
I can use this code on my RPi without errors:
	    devices = {[SceneGoodNight] = { 'at nighttime' }},
On his RPi i get a error:
Table is NIL
My RPI runs with latest Beta Domoticz on Rasbian. His RPi runs same Beta Domoticz on OSMC OS.
global_data
local Version       = '18.04.08'
SceneEvening        = 11
SceneGoodNight      = 12
SceneMovie          = 15
SceneDayTime        = 13
LivingRoomStatus    = 45
iPhone        = 10
KodiStatus          = 50
    helpers = {
        TurnOnScene = function(domoticz,idx)
            domoticz.devices(idx).switchOn().checkFirst()
        end,
        TurnOffScene = function(domoticz,idx)
            domoticz.devices(idx).switchOff().checkFirst()
        end,
        On = function(domoticz,idx,dim)
            domoticz.devices(idx).dimTo(dim)
        end,
        Off = function(domoticz,idx)
Script:
local results
    active = true,
        devices = {SceneGoodNight},
    logging = {marker = 'SCENE GOODNIGHT ' ..Version..'........'},
     if (domoticz.devices(SceneGoodNight).active) then
        domoticz.helpers.TurnOffScene(domoticz,SceneEvening)
        domoticz.helpers.TurnOffScene(domoticz,SceneDaytime)
        domoticz.helpers.TurnOffScene(domoticz,SceneMovie)
        domoticz.helpers.Off(domoticz,LivingRoomStatus)
        domoticz.log('--------------------==<[ Goodnight is activated ]>==-----------------', domoticz.LOG_FORCE)
        os.execute('/home/osmc/domoticz/scripts/Peter/speech.sh "The scene goodnight is activated"&')
Re: global_data question
Can you please both switch on debugging for dzVents for a moment while executing these scripts ? Maybe that will give just enough information to see what the problem is.
dannybloe
Post by dannybloe »
Yes and post the piece of the log with the errors. Which table is nil? And do you both use the same script sources (filesystem or GUI editor)?
dannybloe
Post by dannybloe »
Looking at the dzVents code I don't believe it is currently guaranteed that global_data.lua is loaded before all other modules. So perhaps in your system it is by coincidence but on your friend's it isn't. In that case the event-script is loaded earlier and there is no SceneGoodNight global available yet.
I never anticipated this kind of usage of global_data but it is a good idea to try to load global_data at the beginning if it exists. I'll add it to my todo list.
poudenes
Post by poudenes »
Hi ALl,
hmm, ok. Sounds logic. It will be nice when global_data is loaded first. When you use lot of devices you can put them in global_data and not have to assign in every script you use. Thats why i did it this way.
The error code we get is:
2018-04-10 10:36:33.469 dzVents: Error (2.4.4): ...oticz/scripts/dzVents/generated_scripts/SceneGoodNight.lua:7: table index is nil
When i remove the = {'at nighttime'} part the script is working. And it has to read the device name also right?
I will revert back to old way and put all devices in every script.
dannybloe
Post by dannybloe »
You can also create a Lua module with the device-ids in there and require that at the top of you script.
poudenes
Post by poudenes »
Thanks. That seems to work for the other RPi. But what is the difference. Modules will always load first and helpers will called when needed?
Thats how i see it now...
dannybloe
Post by dannybloe »
Well, the helpers are part of the global_data. At some point during the bootstrapping of dzVents all the scripts are loaded and the order is just not defined (i.e. explicitly programmed) so on some systems global_data.lua may be loaded after some of the other scripts. So if global_data defines some global variables they will only be available to other scripts after global_data.lua has been loaded. So, I just gotta make sure that global_data.lua is loaded before all other modules.
