Python plugin: Eastron SDM630-Modbus V2
MFxMF
Hello.
Maybe will be useful for somebody.
https://github.com/MFxMF/SDM630-Modbus
In total are 88 parameters mapped.
- screen1.png (390.54 KiB) Viewed 13912 times
miroslavpetrov
Re: Python plugin: Eastron SDM630-Modbus V2
Great work! Thank you!
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Eastron SDM230
rvdgaag
Thank you excellent info, just what I need.
But i Have a mayor question: I need to connect the SM630 with RS485 to my raspberry so I bought a TCP232-204 rs485-etehrnet gateway. But what steps do I need to do to get domoticz to connect to the SDM630 ?
I have been reading on this forum for hours but can't find the answer
miroslavpetrov
I am also working on this problem right now. There are two options:rvdgaag wrote: Saturday 16 June 2018 11:26 Thank you excellent info, just what I need.
I have been reading on this forum for hours but can't find the answer![]()
Option 1: Use tool like socat that allows you to make a virtual serial port (ex.:/dev/ttyVir0) and bind it to the ethernet gateway. I couldn't make it work...
Option 2: Since the library used in the plugin is minimalmodbus it doesn't support modbus tcp, a new plugin should be written. I am currently trying to write one however, my python experience is not fantastic but I am slowly getting there.
Eastron SDM230
Eastron SDM230
Hello MFxMF,
I would like to discus about you're very nice plugin. How could we get in contact?
Neptunus
Neptunus
MFxMF
Hello, How can I help you?neptunus wrote: Thursday 20 December 2018 16:07 Hello MFxMF,
Neptunus
Send me priv message via forum.
Hello MFxMF,
I get the information message below.
We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more in discussions to be able to use this feature. - Spoiler: show
jendrush
It is possible to connect to SDM630 wirelessly? Maybe ESP8266? Probably some kind of solution would be RPi Zero W, and second Domoticz.
UPDATE I see there is solution with ESP8266.
Farmer
Hi, thank you for sharing your code.
Can i use the SDM630 in Domoticz in combinatin with solar energy. So the kWh meter counts back or minus in the Domoticz logs?
Odouch
Could you use HF2211 in conjunction with SDM630?
Odouch
Has anyone tried ESP32 + SDM630 + DomotiCZ?
Odouch
Have you found a solution for ESP8266 and SDM?jendrush wrote: Monday 18 March 2019 19:51 It is possible to connect to SDM630 wirelessly? Maybe ESP8266? Probably some kind of solution would be RPi Zero W, and second Domoticz.
jendrush
I tried ESPEasy with test plugin, and it didn't work very well. It offers possibility to read only 4 registers, and i do not see option to send them to different IDXs. Tried also Tasmota, and it reads a lot more, but again i don't know how to send those readed values to specific IDXs. Currently i am working on code to send values choosen by me to specific IDXs just by HTTP GET request to Domoticz. My SDM630 is not connected to main wires, so i am testing this with only 1 phase connected. You can look at the Reaper7 SDM library on Github. This library is also used in ESPEasy, and Tasmota.
Good day,
I'm a complete beginner.
Can't use this solution?
I can't use myself
https://diytechandrepairs.nu/esp8266-to-monitor-electricity-with-sdm-devices-and-send-to-mqtt/-
hobbyklussy
- Target OS: -
It took me a while but I found out that the cheap Chinese RS485 to USB converter (as shown on the pictures of the writer of this script) seems to work with the SDM630 and raspberry Pi (Domoticz), but in fact it doesn't. It is totally not stable and causes GUI freezes every week.
Since I replaced this adapter with a FTDI based one it really works perfectly without any hangups at all!
I just wanted to share that with you.
kaziormirek
hi
I have DOMOTICZ2021.1 (build 13360) and SDM 630 modbus V2
I have a problem with starting the plugin
I have no choice of COM port
i installed: pyserial, minimalmodbus
- sdm.png (91.54 KiB) Viewed 8346 times
kaziormirek
i solved my problem
in /boot/config.txt
add in last line enable_uart=1
[all]
#dtoverlay=vc4-fkms-v3d
enable_uart=1
The plugin is perfect, but since the update of stable version 2021.1, the power consumption from power is not working properly. Does anyone know how to fix this ?
The Total Power Meter type shows correct power but negative or zero power consumption values.
For example the device from this line:
if 88 not in Devices:
Domoticz.Device(Name="Total Power Meter", Unit=88,TypeName="General",Subtype=0x1D,Used=0).Create()
Does anyone have experience with this ?
jfery
Thanks for your code, but I have a problem.
I have 2 Eastron SDM630-Modbus V2 and I would like to daisy chain them and be able to loop over them in order to retrieve MQTT data via node-red.
Can you tell me if this is feasible and if so, do you have any code that allows to do it?
I thank you in advance.
John
Ps: sorry for my English, but I go through a translator.
John
