2.4.4 Released
Posted: Friday 06 April 2018 8:53
Hi folks,
The past few days we fixed some stuff in dzVents and released a bunch of dot-updates. It seems that people are still have trouble with the new RGB stuff in the latest beta. Unfortunately that's not something that I can easily test myself as I don't have all that hardware. So if there are people out there that can please help us get this to work (as long as it indeed is dzVents related).
Here's the notes:
2.4.4
Here's the notes:
2.4.4
- Fixed rawTime and rawData so it shows leading zeros when values are below 10.
- Fixed one wildcard issue. Should now work as expected.
- Fixed a problem in Domoticz where you couldn't change the state of some door contact-like switches using the API or dzVents. That seems to work now.
- Fixed trigger wildcards. Now you can do `*aa*bb*cc` or `a*` which will require the target to start with an `a`
- Added more EvoHome device types to the EvoHome device adapter.
- Fixed RGBW device adapter
- Fixed EvoHome device adapter
- Changed param ordering opentherm gateway command (viewtopic.php?f=59&t=21620&p=170469#p170469)
