Pt100 with Domoticz
Metlik
Pt100 with Domoticz
Post by Metlik »
Hello!
I have a several (16 - sixteen) PT100 temperature sensors (thermo couples). Which interface You can suggest (or better to use), to connect them and monitor the temperature using Raspberry Pi3 and Domoticz?
Thank you in advance!
SweetPants
Re: Pt100 with Domoticz
Post by SweetPants »
I do not know of any device that takes PT100 as a sensor. You can build something yourself using an Arduino. http://www.instructables.com/id/Reading ... g-Arduino/ but you will need some additional analog circuitry to get this working. The Arduino (at least the Nano), has 10-bit analog inputs you can use.
