problem Domoticz/PI 2B after reboot
Posted: Wednesday 04 April 2018 14:30
by Johndomo
Looking for some advice...
I had Domoticz running on a PI 2 B and all worked well and stable.
Last weekend I added a new Zwave module and after inclusion, I did a reboot (sudo reboot) to make it visible.
But there it ended... I see in my router that the Raspberry isn't connected anymore to it (cable), so it probably doesn't start correctly.
I operated the Raspberry only external, via Putty, but of course that doesn't work anymore.
What is the best way to go?
A. Download a new image and start all over again. Would mean that everything is updated, but that I loose my program and have to re-include all devices again?
B. Get a fixed display/keyboard and connect it to the Raspberry. But then what? My Linux knowledge is very limited.
Any smart ideas? Thx!
Re: problem Domoticz/PI 2B after reboot
Posted: Wednesday 04 April 2018 15:05
by edwin1234
I should first connect a monitor to the raspberry pi so you can see what he is doing.
And look at your internet connection
Maybe he had another ip or so
Posted: Wednesday 04 April 2018 22:44
by Johndomo
Thank you. I connected a display and saw that it waited for a login. I thought this should be done automatically?
Anyway, I connected a keyboard and logged in, then it started Domoticz.
But when I look in the Router software, the Raspberry still isn't mentioned in the connected devices list? Also, Domoticz cannot be started on the laptop or Phone.
Any ideas?
Posted: Friday 06 April 2018 7:53
by Johndomo
I rebooted the Raspberry again, now it shows in the router and I see it gets the same fixed IP adress as before.
But I can still not open Domoticz from my laptop or my mobile?
What can be the problem? Any suggestions are welcome!
Posted: Saturday 07 April 2018 10:22
by edwin1234
I have a new errorlog
Now its a bit longer 😃
Hope someone can help
2018-04-07 00:47:24.192 (VirtualPlugwise-2-py) General/Text (Unknown)
2018-04-07 00:47:39.319 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:47:39.634 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:47:39.954 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:47:44.067 (VirtualPlugwise-2-py) Lighting 2 (CvKetelPlug)
2018-04-07 00:47:44.154 (VirtualPlugwise-2-py) Lighting 2 (CvKetelShedule)
2018-04-07 00:47:44.176 (VirtualPlugwise-2-py) General/Text (Unknown)
2018-04-07 00:47:50.244 (Rfxcom ) Temp (Retour)
2018-04-07 00:47:52.196 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:47:52.528 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:47:52.720 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:48:00.379 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:48:03.968 (VirtualPlugwise-2-py) Lighting 2 (CvKetelPlug)
2018-04-07 00:48:04.046 (VirtualPlugwise-2-py) Lighting 2 (CvKetelShedule)
2018-04-07 00:48:04.070 (VirtualPlugwise-2-py) General/Text (Unknown)
2018-04-07 00:48:11.008 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:48:11.238 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:48:12.999 (VirtualPlugwise-2-py) Lighting 2 (CvKetelPlug)
2018-04-07 00:48:13.075 (VirtualPlugwise-2-py) Lighting 2 (CvKetelShedule)
2018-04-07 00:48:18.334 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:48:23.133 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:48:23.200 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:48:23.386 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:48:27.451 (Pinger) Lighting 2 (Tv)
2018-04-07 00:48:29.247 (Rfxcom ) Temp (Retour)
2018-04-07 00:48:42.271 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:48:42.505 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:48:43.331 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:48:53.938 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:48:54.005 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:48:54.198 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:48:57.351 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:49:08.453 (Rfxcom ) Temp (Retour)
2018-04-07 00:49:13.211 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:49:13.776 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:49:24.775 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:49:24.836 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:49:25.031 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:49:26.331 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:49:36.356 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:49:44.493 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:49:45.050 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:49:47.259 (Rfxcom ) Temp (Retour)
2018-04-07 00:49:55.598 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:49:55.673 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:49:55.851 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:50:09.540 (Rfxcom ) Temp (RookgasTemperatuur)
2018-04-07 00:50:15.341 (Rfxcom ) Temp + Humidity (Temp/Lucht)
2018-04-07 00:50:15.772 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:50:16.324 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:50:26.251 (Rfxcom ) Temp (Retour)
2018-04-07 00:50:26.630 (Nefit Easy) Thermostat (Ingestelde Temperatuur)
2018-04-07 00:50:26.705 (Nefit Easy) Temp (ruimte Temperatuur)
2018-04-07 00:50:26.887 (Nefit Easy) Temp (Aanvoer Temperatuur)
2018-04-07 00:50:47.043 (Rfxcom ) RFXMeter (GasVerbruik)
2018-04-07 00:50:47.308 (Nefit Easy) P1 Smart Meter (Gas)
2018-04-07 00:50:47.601 (Rfxcom ) RFXMeter (Unknown)2018-04-07 00:50:52.682 Error: Domoticz received fatal signal 11 !...
2018-04-07 00:50:52.904 Error: /home/pi/domoticz/domoticz() [0x1cdc48]
2018-04-07 00:50:52.905 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2018-04-07 00:50:52.905 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0xb6a49180]
