[Solved] RPI 3 as MS gateway, arduino Mega as node over USB
Posted: Tuesday 03 April 2018 22:52
Hi Folks,
I've been browsing forums and tutorials, but I couldn't find an working solution.
I run domoticz V3.8153 on a Raspberry Pi 3B, with Stretch OS.
I would like to connect 2 16CH relay boards and 1 8CH relay board to my RPi. One 16CH board is wired directly to the RPi's GPIO and imported in Domoticz using SYSFS. I have a arduino mega clone here that I would like to use to connect the other 16CH and the 8CH relay board to. Since the arduino and the relay boards and the RPi are in the same box, I would like to connect them wired, so not over radio, but USB.(the usb ports have no further use for me on the RPi)
I was thinking of making my RPi with Domoticz also a MySensors gateway without radio, and connect my Mega clone as "node" with the MySensors relay board sketch to the RPi with USB.
Is this possible? If yes, could someone give me a push in the right direction to get this running?
Thanks in advance,
KoenP
Thanks in advance,
KoenP
