How to ad barometic sensor
Posted: Tuesday 03 April 2018 19:39
by losholmen
I'm looking for an instruction, how to wiring and program a barometic sensor type adafruit BPM 180 to rpi / domoticz
Skickat från min iPhone med Tapatalk
Re: How to ad barometic sensor
Posted: Tuesday 11 December 2018 7:16
by carymay
Posted by losholmen:
I'm looking for an instruction, how to write my essay and program a barometic sensor type adafruit BPM 180 to rpi / domoticz
Hello @losholmen,
Perhaps, one of the possible options is to have this sensor directly connected on the header pins and configured in hardware (since you will have to query I2C bus, since there's no XCLR pin on the BMP180) as I2C BMP085/180 in Domoticz. Have you checked the sensor user guide for Arduino on Adafruit?
-Cary
Posted: Tuesday 11 December 2018 11:57
by Toulon7559
1. Connect BMP180-wiring as I2C-sensor to the header of the RPI.
2. Go to Domoticz-Dashboard/Setup/Hardware
2a. At the bottom select Type = I2C Sensors, select subtype BMP085/180, and Add
2b. In the window popping up insert an applicable name and activate for the device, and you are in business with Domoticz
3. Go Dashboard/Setup/Devices and you will see that device with a green icon at the right side.
Activate that icon and when blue it is part of your active configuration.
