Only bat % updating
Posted: Tuesday 03 April 2018 13:47
I'm trying to help to dev a Python Plugin for Zigate.
Zigate is a kind of RFLink but for Zigbee Devices, this can work with a lot of Zigbee Devices, You don't need to pair them to a External Gateway (Everything can stay in your home, no way to send it outside
), and this act so fast, no comparaison with gateway system.
http://zigate.fr/
A french Dev is already working a plugin : https://github.com/sasu-drooz/Domoticz-Zigate
We are facing a problem who can be solve by Python Plugin System creator : Updating Battery Level
The Main way that all Python Plugin Dev use is to creat a % device who show battery level information : ok, acceptable as we don't use to have 25 Mi Robot Vaccum Cleaner in one house
A lot of Zigbee Device send their Battery Level without sending any other information, Xiaomi Ones send this every 50 Minutes.
Actually Python PlugIn system set Battery as an Option, this mean that if a device send a Battery Level Infomation, we have to update the wol device :
This mean that on every Battery level update, device is full updated :
And of course if you set an event on this switch : this event is trigger every 50 minutes, not really WAF.
Is there a way to update Battery information without Update Nvalue and Svalue ?, As this a full fonction of Domoticz this can be a Mandatory Fonction.
http://zigate.fr/
Devices[x].Update(nValue = int(CurrentnValue),sValue = str(CurrentsValue), BatteryLevel = BatteryLvl )Code: Select all
2018-04-03 08:31:28 Right Click
2018-04-03 07:41:21 Right Click
2018-04-03 06:51:16 Right Click
2018-04-03 06:01:08 Right Click
2018-04-03 05:11:01 Right Click
2018-04-03 04:20:53 Right Click
2018-04-03 03:30:47 Right Click
2018-04-03 02:40:39 Right Click
2018-04-03 01:50:30 Right Click
2018-04-03 01:00:22 Right Click
2018-04-03 00:10:14 Right Click
2018-04-02 23:20:06 Right Click
2018-04-02 22:29:58 Right Click
2018-04-02 21:39:51 Right Click
2018-04-02 20:49:45 Right Click
