Visu switches off, light remains on
Posted: Sunday 01 April 2018 1:05
by mischa72
Good evening all,
For a few days I'm struggling with a little strange behaviour of my setup. For now my install is only 1 Sonoff S20 (espeasy flashed) on Domoticz (on Raspbian Stretch).
When I switch on the lights, the little lightbulb on the main Domoticz visualisation goes bright, but after some seconds it dims again while the lights remain on. Using the button on the S20 the lightbulb in the visualisation remains dimmed, but the lights switch on and off.
Best regards,
Mischa
Re: Visu switches off, light remains on
Posted: Sunday 01 April 2018 9:49
by mikeoo
Do you use a Action Off delay maybe on the switch in Domoticz or a timer. Maybe you add the wrong dummy switch for it to Domoticz that could explain the behaviour.
Maybe a problem with the ESPeasy version you use. Check there is there is something that could explain the problem of check if there is a new version or try to flash the S20 again. Could be a bad flash.
I use https://github.com/arendst/Sonoff-Tasmota with Sonoff S20 without problems, maybe check that program if the problems exist.
In Tasmota you only have the setup the IDX of the switch in Domoticz. It have a special Domoticz setting for it. Add a dummy switch for Light and you're done.
