Switch with Off Delay > 30 doesn't trigger
Posted: Saturday 31 March 2018 4:22
I have several PIR, LDR, DHT11 combos running on wemos around the house. The PIRs send an on signal, and then an off signal almost immediately. I have this blockly script in an attempt to increase the timeout delay between movement ending and the lights turning off.
https://imgur.com/a/WXerm
"LDR actual" is the light level in the kitchen
"Kitchen pir timer" is a virtual switch with "delay off" which ideally I want to set to 10+ minutes
"Kitchen big light" is one of the lights in the "kitchen" group, so that this only turns lights off if that one is currently on.
I have this set as an 'All' type.
My problem is, the "kitchen PIR timer" doesn't turn off after the specified time unless it's 30 seconds or under. Is this a bug? Tried on the latest stable release, and have just upgraded to 3.9117 beta but have the same issue.
Thanks for any help!
