Problem io.popen after domoticz update Topic is solved
franzelare
Post by franzelare »
I run a script to ready my X10 dimmers using Heyu for a long time.
after i updated domoticz to the last revision they io.popen is not respoinding anymore
time_HeyuDimmerRead: [string "commandArray = {}..."]:85: attempt to compare number with nil
any clue what to change to get the readout working again?
-- Badkamer dimmer code
if (otherdevices['Badkamer'] ~= 'Off') and (otherdevices['BadkamerManual'] == 'Off') then
    local f = io.popen("/usr/local/bin/heyu rawlevel g8")
    local Dimstand = f:read()
    local Dimnumber = tonumber(Dimstand);
    if (Dimnumber>1) then
        commandArray['Variable:BadkamerDim'] = tostring(Dimstand)
        if PRINT_MODE == true then
            print("Badkamer Dimmer staat aan:")
            print("Badkamer RAWlevel ontvangen:" .. Dimstand)
            DimPrecentage=math.ceil(Dimstand*1.613)
            print("Badkamer level percentage calculated:" .. DimPrecentage)
    if (Dimnumber==0) then
            commandArray['Badkamer'] = 'Off'
if (otherdevices['Badkamer'] == 'Off') then
        print("Badkamer dimmer is Off")
SweetPants
Re: Problem io.popen after domoticz update
Post by SweetPants »
Do you get the right answer when running from command line?
franzelare
found the issue, state engine did work from the command line but domoticz could not do request because of write access in the folder of the state engine
