pilot Home automation
Posted: Saturday 24 March 2018 19:40
by jandirkv
Hello
I use pilot Home automation app to recieve Messages from domoticz. this goes through http messages where you fill in your key in field 1 and then with the following api url. I've added extra spaces because the complete url was not shown correctly
(In Field1 is my app code and in field2 of my girlfriend. see picture below
domoticz copy.jpg (74.17 KiB) Viewed 655 times
the Problem is that the api url refers only to field1 so I only get the message. In DZvents I use this line (which works but only to my iPhone):
domoticz.notify('message header', 'actual message','Prowl/NMS: Very Low, Pushover: N/A')
So I want to incorporate http://api.pilot.patrickferreira.com/#F ... T/#MESSAGE in my dzvents so I can send messages either to my iPhone (use field1 in the url) or to my girlfriends (use field2 in the url). Or if someone has another solution.
Re: pilot Home automation
Posted: Saturday 24 March 2018 20:17
by jandirkv
I already solved it. Here is my solution, maybe I can help someone else with it.
domoticz.openURL('http://api.pilot.patrickferreira.com/'app code' without the quotes/'header' again without the quotes/'subject')
Posted: Sunday 25 March 2018 10:52
by dannybloe
I have made a global helper (in global_data) where you can send Pilot messages to some or all known recipients. At the top I defined some users with their keys. And you can send messages like this:
domoticz.helpers.notifyPilot(domoticz, 'Some subject', 'Some message', 'John')
domoticz.helpers.notifyPilot(domoticz, 'Some subject', 'Some message', 'all') -- send to all
domoticz.helpers.notifyPilot(domoticz, 'Some subject', 'Some message', {'John', 'Katy'})
I use this global function in all my scripts. Works like a charm and even encodes nasty characters in messages. Here is the code:
local pilotUsers = {
    ['John'] = 'xxxx', -- use pilot key
    ['Mary'] = 'yyy',
    ['Katy'] = 'zzz'
	helpers = {
	    notifyPilot = function(domoticz, subject, message, user)
		if (subject == nil or subject == '') then
			subject = '–'
		if (message == nil or message == '') then
			message = '–'
		--http://api.pilot.patrickferreira.com/KEY/SUBJECT/MESSAGE
		-- generic function for sending messages
		local _notifyUser = function(key, name)
			domoticz.log('Notify Pilot user: ' .. tostring(name) .. ';' .. tostring(subject) .. ';' .. tostring(message), domoticz.LOG_INFO)
			local msg = tostring(key) .. '/' .. domoticz.utils.urlEncode(subject .. '/' .. message, '%20')
			local url = 'http://api.pilot.patrickferreira.com/' .. msg
			domoticz.openURL(url)
		if (user == 'All') then
			for name, key in pairs(pilotUsers) do
				_notifyUser(key, name)
		elseif (type(user) == 'table') then
			for _, name in pairs(user) do
				_notifyUser(pilotUsers[name], name)
			_notifyUser(pilotUsers[user], user)
