['UpdateDevice'] can not and ['OpenURL'] can use notifications.
Posted: Friday 23 March 2018 14:11
In Events I wrote a LUA script to monitor batterij-voltage of a remote node. I like to receive a notification in Telegram_app if the LiFePo4 voltage goes below 2.75 volt. (idxVolt = the idx of the device and volt is the value)
I can use two different ways to get the result in Domoticz.
With this command
commandArray['OpenURL']="127.0.0.1:8080/json.htm?type=command¶m=udevice&idx="..idxVolt.."&nvalue=0&svalue="..volt
logfile reports:
2018-03-23 14:04:01.433 EventSystem: Fetching url...
2018-03-23 14:04:02.024 (Virtual) General/Voltage (LoRa TTN-vcc)
Value is updated and notification to Telegram will work.
With this command
commandArray[3] = {['UpdateDevice'] = idxVolt .. '|0|' .. volt}
there is nothing in the logfile, values are received by Domoticz but notifications do not work.
Is there a logical reason for this behaviour ?
With this command
logfile reports:
With this command
