Page 1 of 2
Lua script executing sh script... not working!
Posted: Thursday 22 March 2018 19:18
by echeberri77
Hello guys,
I searched this forum for a couple of days before posting but I did't find any way to solve my problem.
I have this lua script named script_device_lights.lua, located under /xavier/domoticz/scripts/lua/
if (devicechanged['Luci corridoio'] == 'On') then
os.execute ("/home/xavier/domoticz/scripts/luci_corridoio.sh")
This is the content of the bash script luci_corridoio.sh:
#!/bin/bash
izsynth -e naturalreaders -v Federica -t "Luci del corridoio accese"
I have a dummy light switch connected to my sonoff: when I trigger the switch 'Luci corridoio' I have my lights ON and the lua script execute luci_corridoio.sh that should simply play a vocal message saying my lights are on.
This is the domoticz log:
2018-03-22 19:02:40.214 (SonOff_corridoio) Lighting 1 (Luci corridoio)
2018-03-22 19:02:40.423 Executing script: /home/xavier/domoticz/scripts/luci_corridoio.sh
2018-03-22 19:02:41.269 MQTT: Topic: domoticz/in, Message: {"idx":13,"nvalue":0,"svalue":""}
2018-03-22 19:02:41.274 LUA: Time set to Night
My lua script is chmod +x and 755
My sh script is chmod +x and 755
If I launch my sh script in a terminal Windows using both root and not-root users it is working and I am able to hear the message...
THE PROBLEM IS THAT WHEN THE SH SCRIPT IS EXECUTED BY DOMOTICZ I SIMPLY CAN'T HEAR ANYTHING (sorry for the capital letters.....)
Could you please help me to understand my error because it is driving me totally crazy!
Thanks!!!
Echeberri
Re: Lua script executing sh script... not working!
Posted: Thursday 22 March 2018 21:05
by freijn
Hi Echeberri
please try the following where i have the second one successfully running here.
os.execute ('/home/xavier/domoticz/scripts/luci_corridoio.sh')
or better
os.execute ('/home/xavier/domoticz/scripts/luci_corridoio.sh &')
Posted: Friday 23 March 2018 8:35
by echeberri77
freijn wrote:Hi Echeberri
or better
I tried to modify my Lua script as you suggested but It is still not working.
Domoticz executes the sh batch but I can't hear any sound (if I launch the same sh batch in a terminal Window It works perfectly...).
Any hint?
Inviato dal mio MHA-L29 utilizzando Tapatalk
Posted: Friday 23 March 2018 13:10
by freijn
The only thing I can think of is that if Domoticz exe the script you are a different user.
Assuming the domoticz user does not have access to the sound device or the file which need to be played.
what happens in the script ?
Posted: Friday 23 March 2018 13:17
by echeberri77
freijn wrote:The only thing I can think of is that if Domoticz exe the script you are a different user.
How to see which user is used by domotics? How to assign to this user more priviledges?
Posted: Friday 23 March 2018 13:52
by echeberri77
echeberri77 wrote:freijn wrote:The only thing I can think of is that if Domoticz exe the script you are a different user.
I granted chmod 777 to izsynth directory and executable but nothing changed! I Simply can't hear sound... I was wondering how to give access to everyone to sound card... Hmmm.... But is It necessary?
Posted: Friday 23 March 2018 15:08
by jannl
Not only access rights, also path settings and environment vars (if used) should be checked.
Besides, as far as I can see I do not see an error.....
Posted: Friday 23 March 2018 15:09
by echeberri77
echeberri77 wrote:echeberri77 wrote:freijn wrote:The only thing I can think of is that if Domoticz exe the script you are a different user.
I also added all users to the group "sound" but sh is still mute if played by domoticz... Hmmmm....
Posted: Friday 23 March 2018 15:11
by echeberri77
jannl wrote:Not only access rights, also path settings and environment vars (if used) should be checked.
Path settings are correct because domoticz executes the sh script... (So It means sh file is found). Domoticz script directory is chmod 777 and There aren't any environment vars used...
Posted: Friday 23 March 2018 15:18
by jannl
I mean the path settings in the script. Does the script find everything it needs?
Posted: Friday 23 March 2018 15:22
by echeberri77
jannl wrote:I mean the path settings in the script. Does the script find everything it needs?
Read above: i think the script is Pretty simple. I press a dummy switch that switchs a lamp on. When this device changes to ON position It triggers a sh script. I can read from the log that domoticz correctly executes the sh script but no sound Can be heard... If i launch the same sh script from a terminal windows using a non root user I am able to hear the sound...
Posted: Friday 23 March 2018 15:27
by jannl
Hm. Read what I wrote. Off course Domoticz executes the script. You entered the path.
The script itself propably does not find the binary you try to call.
Not sure what you know about how linux works, but when a shell is forked (what happens when executing the script like this), most likely that shell does not have a lot of settings, hence my remarks.
Posted: Friday 23 March 2018 15:29
by echeberri77
jannl wrote:Hm. Read what I wrote. Off course Domoticz executes the script. You entered the path.
By binary you mean the izsynth executable? It is on the system path and i can call It from any directory and It is rwx for all users.
Posted: Friday 23 March 2018 15:30
by jannl
The script most likely has no path (or did you check). Try using the complete path to the binary.
Posted: Friday 23 March 2018 15:31
by echeberri77
echeberri77 wrote:jannl wrote:Hm. Read what I wrote. Off course Domoticz executes the script. You entered the path.
Is There a way to have a more verbose domoticz log? Maybe It could help...
Posted: Friday 23 March 2018 15:34
by jannl
The error ia not in Domoticz. The script has an error (i think). If Domoticz had an error it would be in the logging. Just try adding the complete path to the binary in the script.
Posted: Friday 23 March 2018 15:36
by freijn
os.execute ('/home/xavier/domoticz/scripts/luci_corridoio.sh /home/log/myscript.log')
try the above. and see /home/log/myscript.log
by echeberri77
jannl wrote:The script most likely has no path (or did you check). Try using the complete path to the binary.
Please be more specific: Lua script or sh script?
Lua script is inside domoticz/script. Inside Lua script I read:
... Os.execute ('/domoticz/script/luci_corridoio.sh')
Also this path is correct because domoticz log tells me that domoticz started the sh script.
Let's go inside the sh script:
I Simply execute ezsynth with some arguments.
I can't really find any path issues...
Posted: Friday 23 March 2018 15:37
by jannl
The path ezsynth inside the script. The script itself is executed as shown in the Domoticz log
Posted: Friday 23 March 2018 15:38
by echeberri77
jannl wrote:The path ezsynth inside the script. The script itself is executed as shown in the Domoticz log
Ok, I'll adding complete path. I'll let you know. Thanks!
