Lua 3D array
JustMitchie
Lua 3D array
Post by JustMitchie »
Hello, i am trying to assing the value from my p1 meter, which is a json array
ActTime	1521732455
AstrTwilightEnd	"20:48"
AstrTwilightStart	"04:37"
CivTwilightEnd	"19:26"
CivTwilightStart	"05:59"
DayLength	"12:19"
NautTwilightEnd	"20:06"
NautTwilightStart	"05:19"
ServerTime	"2018-03-22 16:27:35"
SunAtSouth	"12:05"
Sunrise	"06:33"
Sunset	"18:52"
result
        0
                AddjMulti	1
                AddjMulti2	1
                AddjValue	0
                AddjValue2	0
                BatteryLevel	255
                Counter	"2323.313"
                CounterToday	"5.603 m3"
                CustomImage	0
                Data	"2323.313"
                Description	""
                Favorite	1
                HardwareID	9
                HardwareName	"Power usage"
                HardwareType	"P1 Smart Meter USB"
                HardwareTypeVal	4
                HaveTimeout	false
                ID	"1"
                LastUpdate	"2018-03-22 16:25:45"
                Name	"Gas"
                Notifications	"false"
                PlanID	"0"
                PlanIDs
                0	0
                Protected	false
                ShowNotifications	true
                SignalLevel	"-"
                SubType	"Gas"
                SwitchTypeVal	1
                Timers	"false"
                Type	"P1 Smart Meter"
                TypeImg	"counter"
                Unit	2
                Used	0
                XOffset	"0"
                YOffset	"0"
                idx	"20"
status	"OK"
title	"Devices"
In PHP i would use explode i think, but no clue how to do it in Lua. I want to assign the value of CounterToday to otherdevices[Gas}
Can someone point me in the right direction? Kind regards, Michel
freijn
Domoticz version: Stable
Re: Lua 3D array
Post by freijn »
not sure how the values are split?
Just by CR/LF ?
here are a lot of examples
http://lua-users.org/wiki/SplitJoin
JustMitchie
Re: Lua 3D array
Ah ik zag dat je nederlands bent. Die P1 meter geeft dus een mooie array, maar ik wil dus alleen de currentvalue hebben met de GasMeter heet 'ie CounterToday, Als het een php array was zou je gaan zo van $data[result[0][CounterToday] die wil ik in een virtuele gasmeter stoppen. Bij de stroommeter is er nog eentje, de usage. Die is in php $data[result][0][usage]
Maar bij die stroommeter moeten er dus twee values in (sValue voor die tweede?) nogmaals, geen idee hoe lua werkt ;( thanks for the help
JustMitchie
Re: Lua 3D array
print(' test gas')
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local config=assert(io.popen('curl "http://username:password:192.168.2.15:8080/json.htm?type=devices&rid=20"')) -- notice double quotes
local data = config:read('*all')
config:close()
local jsonValue = json:decode(data)
value = jsonValue.result.CounterToday
print(value)
This is what i tried in Lua, however i get a Error: EventSystem: in Gas_Update: [string "--..."]:27: attempt to call a nil value
in the log.
jvdz
Domoticz version: 4.107
Re: Lua 3D array
Post by jvdz »
Can you share the actual JSON data as the posted data in not in JSON format?
Jos
JustMitchie
Re: Lua 3D array
http://forum:forum:ip:port/json.htm?type=devices&rid=19
Is the url, it has viewing rights on the utilities page. However, when i try it, it goes straight to google. I am probably looking at a typo here, but the ip is
84.81.105.118:8080 the pass is forum the user is forum and the idx is 19 for the power meter, 20 for the gas meter.
I hope that this is more convenient than uploading a imgurl....
Regards, michel
mag in het nederlands, engels maakt mij niet uit. ;)
Last edited by JustMitchie on Thursday 29 March 2018 13:09, edited 1 time in total.
JustMitchie
Re: Lua 3D array
https://imgur.com/a/C8h2F <- imgur link with screenshots made from the browser of the kwh meter.
it has both values. CounterToday and Usage.
regards, michel
jvdz
Re: Lua 3D array
Post by jvdz »
English is fine ...no worries. ;)
This should work to decode:
local jsonData = json:decode(Stringjson)
print(jsonData.result[1].CounterToday)
Jos
JustMitchie
Re: Lua 3D array
jvdz wrote: Thursday 22 March 2018 19:42 English is fine ...no worries. ;)
Jos
This now makes
print(' test gas')
   json = (loadfile "/home/michel/domoticz/scripts/lua/JSON.lua")  -- For Linux
   local config=assert(io.popen('curl "http://forum:forum:192.168.2.15:8080/json.htm?type=devices&rid=20"')) -- notice double quotes
   local Stringjson = config:read('*all')
   print(Stringjson)
   config:close()
and results in
2018-03-22 20:00:50.557 LUA: test gas
2018-03-22 20:00:50.780 LUA:
2018-03-22 20:00:50.780 Error: EventSystem: in Gas_Update: [string "--..."]:32: attempt to index global 'json' (a function value)
i am getting better at this.
Kind regards,
Michel
jvdz
Re: Lua 3D array
Post by jvdz »
Think the URL needs to be:
local config=assert(io.popen('curl "http://forum:[email protected]:8080/json.htm?type=devices&rid=20"')) -- notice double quotes
it works for me with:
local config=assert(io.popen('curl "http://forum:[email protected]:yyyy/json.htm?type=devices&rid=19"')) -- notice double quotes
Jos
JustMitchie
Re: Lua 3D array
jvdz wrote: Thursday 22 March 2018 20:13 Think the URL needs to be:
local config=assert(io.popen('curl "http://forum:[email protected]:8080/json.htm?type=devices&rid=19"')) -- notice double quotes
Jos
Now its breaking at line 8 (i removed the top comments so the script is shorter)
[string "print(' test gas')..."]:8: attempt to index local 'json' (a function value)
local json = (loadfile "/home/michel/domoticz/scripts/lua/JSON.lua")  -- For Linux <-straight from domoticz lua example it there was without local in front of it
i thought i was getting it, im totally lost here.... :(
Last edited by JustMitchie on Thursday 29 March 2018 13:18, edited 1 time in total.
jvdz
Re: Lua 3D array
Post by jvdz »
I don't know where you have stored the JSON.lua lib but this is what works for me:
json = (loadfile "/usr/local/share/lua/5.2/JSON.lua") ()
local config=assert(io.popen('curl "http://xx:yy/json.htm?type=devices&rid=19"')) -- notice double quotes
print(Stringjson)
config:close()
Jos
JustMitchie
Re: Lua 3D array
jvdz wrote: Thursday 22 March 2018 20:32 I don't know where you have stored the JSON.lua lib but this is what works for me:
print(Stringjson)
config:close()
Jos
i dont know why, but changing the string to manually typing the same loadfile works.
now it hangs on
 Error: EventSystem: in Gas_Update: [string "print(' test gas')..."]:9: attempt to index local 'jsonData' (a nil value)
with this as value
so, now its back, to how get the specific value.
print(' test gas')
   json = (loadfile "/home/michel/domoticz/scripts/lua/JSON.lua") ()
   print(Stringjson)
   config:close()
   print(jsonData)
   print(jsonData.result[0].CounterToday)
printing the stringJson gives out a proper whitespace printed
and if i do print(jsonValue) it gets the same attempt to index nill value...
Last edited by JustMitchie on Thursday 05 April 2018 10:11, edited 1 time in total.
jvdz
Re: Lua 3D array
Post by jvdz »
You still have the wrong url in there. The : after userid:password needs to change to @
So it should look like:
local config=assert(io.popen('curl "http://forum:forum@xx:yy/json.htm?type=devices&rid=20"')) -- notice double quotes
Jos
JustMitchie
Re: Lua 3D array
DAT WAS HEM :oops:
explains the straight to google search when entering the url in the browser...
I tried a different way tho, i base64encoded the username and pass, voilla. It works :D which is kinda the same right? thanks for the help Jos! <3
jvdz
Re: Lua 3D array
Post by jvdz »
It's always easy and simple when it makes sense. ;)
Enjoy.
Jos
JustMitchie
Re: Lua 3D array
jvdz wrote: Thursday 22 March 2018 21:52 It's always easy and simple when it makes sense. ;)
Enjoy.
Jos
Was het maar zo'n feest....
 commandArray['Gas'] = jsonData.result[1].CounterToday
does'nt set the Gas meter.... The event fires without errors tho, so i dont have a clue (again :shock: ) about whats going wrong this time..
jvdz
Re: Lua 3D array
Post by jvdz »
What about?:
commandArray['UpdateDevice']=otherdevices_idx['gas']..'|0|'..jsonData.result[1].CounterToday
I think these devices need to SValue.
What I don't understand is why you call it gas while it is a kWh value for electricity. The other thing to consider is that you probably only want the value and not the kWh fed into the device.
Jos
jvdz
Re: Lua 3D array
Post by jvdz »
Check here for the proper format of Electricity devices with JSON but also explains how to code the UpdateDevice:
https://www.domoticz.com/wiki/Domoticz_ ... mart_meter
JustMitchie
Re: Lua 3D array
jvdz wrote: Thursday 22 March 2018 22:15 What about?:
Jos
I want to split the values, and i dont want to have to look at the usage of the previous homeowner ;)
