[EnOcean] Temperature Sensor added in EnOceanSensors Table but not as Device
Posted: Tuesday 20 March 2018 20:48
by Polarduck
I've buy a Trio2Sys Temperature sensor (model T2S10020076) which has been correctly added in the EnoceanSensors Table, but not in any other Device table. So I'm unable to work with it.
This issue seems to be same as magicduck's issue viewtopic.php?f=56&t=22249&p=171685&hil ... an#p171685
This Temperature sensor is listed as compatible il Domoticz HCL.
How will be possible to add this component as device.
Thanks for you help
Re: [EnOcean] Temperature Sensor added in EnOceanSensors Table but not as Device
Posted: Friday 18 May 2018 20:15
by EdddieN
Did you find a solution? I have the same issue but for a CO2 sensor.
