HELP python developer for Dash Button server
Posted: Saturday 17 March 2018 17:37
by TheCondor
Hi all, i arranged a basic script in node.js by copy/merge/paste some found around and finally obtain a semi-working one (need to be optimized) which i post here.
It could be awesome if someone with python skill can translate it and optimize.
It run an http server on port 8443, defined dash_X with the ip of each dash button that my mikrotik lease to them and listen for 200 handleresponse. Based on the client ip i run json actions. It works but it's all off than optimized...
var http = require('http');
var fs = require('fs');
var server = http.createServer(handleResponse);
var requestify = require('requestify');
server.on('connection', handleConnection);
function handleResponse(req, res) {
  res.writeHead(200);
  res.end();
var queue = {};
var dash_1 = '::ffff:192.168.99.57';
var dash_2 = '::ffff:192.168.99.58';
var dash_3 = '::ffff:192.168.99.59';
var dash_4 = '::ffff:192.168.99.60';
function handleConnection(conn) {
  var remoteAddress = conn.remoteAddress;
  // Only respond to our dash button
	if ((remoteAddress !== dash_1) || (remoteAddress != dash_2) || (remoteAddress != dash_3) || (remoteAddress != dash_4));
		// Don't process the second petition
		var now = new Date().getTime() /1000;
		if (queue[remoteAddress] && now - queue[remoteAddress] < 1) {
			queue[remoteAddress] = new Date().getTime() /1000;
			return
		queue[remoteAddress] = now;
		// Here your action!
	if (remoteAddress == dash_1) {
		requestify.get('http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=169&switchcmd=Toggle');
	} else if (remoteAddress == dash_2) {
		requestify.get('http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=181&switchcmd=Toggle');
	} else if(remoteAddress == dash_3) {
		requestify.get('http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=167&switchcmd=Toggle');
	} else if (remoteAddress == dash_4) {
		requestify.get('http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=4&switchcmd=Toggle');
server.listen(8443);
