Hi everybody
I extended my installation
1 Rpi 2b master
1 slave 3b RPi with gateway xiaomi connects
The two Pi is on 3.8153 stable version
On the slave I see my sensors humidity / temp
However on the main it goes back only the info of temp
Where is the problem?
I'm looking for since yesterday and I find nothing
I varied the humidity from 25% to 90%
Ok on slave
KO on Master
Thank you for everything!!!!
Error aqara on master Dz ok on master Dz
vwstepha
- Domoticz version: 2020.2
Rpi Master 2022.2 Beta 14905 (Broadlink ok.....)
Rpi slave 2020.2 (since 10days but with error...) with 2 rflink(rts 433 + 833)
vwstepha
Re: Error aqara on master Dz ok on master Dz
no body have this config?
and this pb?!
Arf
my matos slave log
my matos master log
and this pb?!
Arf
my matos slave log
Gateway Xiaomi Rdc 271FA601 1 Xiaomi Humidity General Pressure 1007.0 Bar - - Add dispositifRenamele dispositif Log 2018-09-02 15:10:39
21 Gateway Xiaomi Rdc 1FA6 1 Xiaomi Humidity Humidity LaCrosse TX3 Humidity 64 % - - Add dispositifRename le dispositif Log 2018-09-02 15:10:39
22 Gateway Xiaomi Rdc 1FA6 2 Salle de Bain Temp + Humidity LaCrosse TX3 25.4 C, 74 % - - Mettre en non-utiliséRenommer le dispositif Log 2018-09-02 15:10:39Code: Select all
236 Motherboard 000005DC 1 Process Usage General Custom Sensor 28.29 MB - - Add dispositifRename dispositif Log 2018-09-02 15:14:05
206 Serveur esclave 1FA6 166 Salle de bain temp Temp LaCrosse TX3 25.3 C - 100 Mettre en non-utiliséRenommer le dispositif Log 2018-09-02 15:14:00
2 Motherboard 0000044E 1 HDD /boot General Percentage 51.64% - - Add dispositifRename le dispositif Log 2018-09-02 15:12:54Rpi Master 2022.2 Beta 14905 (Broadlink ok.....)
