Slider change or on/off button change
Posted: Wednesday 14 March 2018 21:49
I have finished my first upgrade from LUA to dzvents scipt
I only have one issue left.
I have a switch with volumeslider. With lua it was
if (devicechanged[RECEIVER_VOLUME] == 'On') then .. do things belonging to on button
Elsif (devicechanged[RECEIVER_VOLUME] == 'Off') then do things belonging to off button
Else was a volume change...
I tried to migrate this, but only ON or OFF works and a volume change does not work, it takes the current_state on or off!
Someone an idea ?
i marked the else tree where the volumechange was coded with: --- FROM HERE IT DOES NOT WORK WHEN VOLUME IS CHANGED
Someone an idea ?
active = true,
devices = {
'denon_volume'
execute = function(domoticz, RECEIVER_VOLUME)
local scriptnaam = 'dztest_volume'
local TVSTATUS = domoticz.devices('tv') -- switch met tv status
local RECEIVER_SOURCE = domoticz.devices('denon_source') -- switch met DENON devices
local RECEIVER_MIXER = domoticz.devices('denon_mixer') -- switch met DENON mixer
local RADIO_SENDER = 'denon_radio' -- switch met DENON radio zender
local IPTV = domoticz.variables('iptv').value -- ip adress tv
local DENONSTATUS = domoticz.variables('denonstatus') -- USER variabele in domoticz waar DENON status wordt bijgehouden
local MAXLEVEL = 30 -- MAximaal volume DENON
domoticz.log('PRG: ' ..scriptnaam ..' tv:' .. IPTV .. ' Status:' .. TVSTATUS.state) -- voor debugging
if (RECEIVER_VOLUME.state == 'On') then -- denon wordt AAN gezet
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON" ); -- zet denon aan
DENONSTATUS.set('On') -- zet uservariabele aan
domoticz.log('PRG: ' ..scriptnaam ..': denon is aangezet') -- debugging
if (TVSTATUS.state == 'On') then --TV staat AAN
RECEIVER_SOURCE.switchSelector(20) -- zet versterker op tv .afterSec(2)
RECEIVER_MIXER.switchSelector(10) -- set versterker op stereo
domoticz.log('PRG: ' ..scriptnaam ..': denon op tv gezet') -- debugging
elseif (TVSTATUS.state == 'Off') then --TV staat UIT
RECEIVER_SOURCE.switchSelector(10) -- zet versterker op RADIO .afterSec(2)
RADIO_SENDER.switchSelector(10) -- set radio zender sky
RECEIVER_MIXER.switchSelector(20) -- set versterker op mch stereo
domoticz.log('PRG: ' ..scriptnaam ..': denon op radio gezet') -- debugging
else --TV heeft geen status
domoticz.log('PRG: ' ..scriptnaam ..': Geen tv status bekend') -- debugging
elseif (RECEIVER_VOLUME.state == 'Off') then -- denon wordt UIT gezet
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FOFF" ); -- zet denon uit
DENONSTATUS.set('Off') -- zet uservariabele aan
domoticz.log('PRG: ' ..scriptnaam ..': denon is uitgezet') -- debugging
else -- denon VOLUME wordt veranderd
domoticz.log('PRG: ' ..scriptnaam ..': VOLUME aangepast') -- debugging
if (DENONSTATUS == 'Off') then -- als denon uitstaat
NewLevel = RECEIVER_VOLUME.volume - 80 ; -- Apply offset from absolute to relative
if tonumber(NewLevel) > MAXLEVEL then -- Peter toegevoegd volume maxlevel
NewLevel = MAXLEVEL -- maximaal geluidsniveau nog checken of dit wel werkt met math.min constructie
end -- einde toevoeging maxvolume
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (NewLevel)); --set volume
domoticz.log('PRG: ' ..scriptnaam .. 'Device:' .. RECEIVER_VOLUME .. ' send command Mute = Off; Set Volume = ' .. NewLevel) -- debugging
