Aeotec Dual Nano Switch ZW132 second output
Posted: Monday 12 March 2018 7:31
by AdamMac
Have installed the Dual Nano switch without any physical switches connected to the inputs but want to switch independently output 1 and output 2 from domoticz. It looks like in the Device list I can only switch both outputs at the same time.
Dual Nano switch.PNG (267.6 KiB) Viewed 1167 times
Anyone able to help out with a fix? I see no one has mentioned anything about the Dual nano here before.
Cheers!
Re: Aeotec Dual Nano Switch ZW132 second output
Posted: Tuesday 27 March 2018 18:11
by fargle
I had the same prob with the ZW140, which is the same device without the energy monitor, until I did the 1.02 firmware update mentioned here. I see there is an upgrade for the ZW132 listed there as well, can't hurt to try.....
I can now control both outputs separately, and there is a common switch as well. They are slow to report status changes back to the dashboard,up to 10 secs, although the operation itself is quick
It looks as if these Aeotec nano switches are still a work in progress in OpenZWave.
