slow response of status change
elbennito
Post by elbennito »
I use denkovi smartden ip-32in and smartden ip-16R boards as in and output.
they work correctly. But when I make a input "high", (put +12V on the input) I only see the status change in domoticz after 45sec.
When I watch the input board from the denkovi software I can see the status change immediately.
I already changed in the options.xml RetryTimeout and ThreadTerminateTimeout. But that doesnt help.
So I think I need to be able to change a setting that says after how many seconds domoticz checks an update change of the denkovi board.
Or do I need find a setting in the denkovi boards on how quickly these "upload" there status change?
elbennito
Re: slow response of status change
Post by elbennito »
The input module now has the switching mode I asked for. super quick reaction of denkovi!
I can now switch my lights (with the standard wallswitches) without the need of domoticz and without a delay.
I dont care about the update of the lightbulbs in domoticz after 4 seconds.
And switching the lichts from domoticz already worked perfect. So I am very happy!
going to install my switchboard this weekend
mail from denkovi:
Please try with the following firmware version (attached).
The instructions are here: http://denkovi.com/Documents/DAEnetIP4/ ... Finder.pdf
The new feature is that the relay can be controlled in Toggle mode - which means it will turn relay ON when the button is pressed once, it will turn off when the button is pressed again, it will turn ON when button is pressed again and so on...
firmware.rar
(145.95 KiB) Downloaded 87 times
