Selector dzvents selecting buttons
parrotface
Post by parrotface »
I am using a selector switch to control heating zones and manually selecting the buttons is working OK.
Using the dzVents script I can switch the selector Off
domoticz.devices('Heat Pump Boost').switchOff().afterMin(60)
I can't work out the syntax to select a different selector switch button. Do I use the level 10 , 20 30 etc or the button Name - zone1, zone2 zone3 etc
what is the correct syntax to select zone1?
Re: Selector dzvents selecting buttons
in dzVents you can use .state to select the name.
execute = function(domoticz, device )
local state = device.state
if state == "name of state-1" then
   do stuff
elseif state == "name of state-2" then
   do other stuff
parrotface
Thanks for your reply
If I understand it correctly your script means I can check to see which button of the selector is active.
What I need is how to change the selector from dzVents script to change the active button.
I can select the Off button but not the other selections.
parrotface
tried these
This works OK domoticz.devices('selector').switchOff().afterMin(60)
These DO NOT work
domoticz.devices('selector').modeSet(10)
domoticz.devices('selector').levelSet(10)
domoticz.devices('selector').set(10)
note selector is name of my selector switch
from https://www.domoticz.com/wiki/DzVents:_ ... _scripting
switchSelector(level): Function. Switches a selector switch to a specific level (numeric value, see the edit page in Domoticz for such a switch to get a list of the values). Supports command options.
so in your case:
domoticz.devices('selector').switchSelector(10)
parrotface
Thanks for reply
Still can't get it working
domoticz.devices('selector').switchOff() works every time
domoticz.devices('selector').switchSelector(Zone1) or
domoticz.devices('selector').switchSelector(10) wont work
Does the command produce an error in the logfile or is it just ignored ? Can you post the output of domoticz.devices('selector').dump() ?
maybe that will give us clue what is going wrong.
