sleeptimer for switch to measure powerconsumption Topic is solved
pvklink
Domoticz version: latest b
Post by pvklink »
RPI 3b
Latest beta domoticz
LUA script
Problem:
After my switch turns on, i want to check if it uses power (otherwise my device is defect)
Problem is that when i put on the device it takes 15 seconds for the powerusage is available, so i need kind of sleep function.
i get print 07c with value 0.0 en when the script is finished it does give a value with print 07a! larger timer does not help...
I tried one, it does pause but it looks like the the powerconsumption cant be read during this lua
local switchlint = 'warmtelint'             -- schakelaar die bij onderschreiding temperatuur aangezet wordt
local switchverbruik = 'Verbruikwarmtelint'             -- schakelaar die bij onderschreiding temperatuur aangezet wordt
local curwatlimit = 1                       -- minimale onderwaarde temperatuur
local wacht=2000
function round2(num, numDecimalPlaces)
  return tonumber(string.format("%." .. (numDecimalPlaces or 0) .. "f", num))
    curwat = otherdevices_svalues["Verbruikwarmtelint"]
    print ('07a Stroomlintverbruik heeft waarde' .. curwat .. '/')
    curwat=0
if devicechanged[switchlint] == 'On' then
    i = 1
    while i  <= wacht do
        ping_success=os.execute('ping -c1 -w 1 192.168.20.1')
        --print ('teller:'..tostring(i)..'')
	    i = i + 1
    if tonumber(curwat) > tonumber(curwatlimit) then            -- lint gebruikt stroom, dus werkt
        print ('07b Stroomlint werkt. Verbruikt ' .. curwat)
        print ('07c Stroomlint werkt niet. Verbruikt ' .. curwat)
Jablotron connection, Ikea
pvklink
Re: sleeptimer for switch to measure powerconsumption
Post by pvklink »
I have a working script, with dzvents is was much easier!
I like to learn what i dit wrong in my LUA script above...
So if someone finds my error(s) your welcome!
    	active = true,
        timer = {'every 5 minutes'}
execute = function(domoticz)
    curwat = tonumber(domoticz.devices('Verbruikwarmtelint').WhActual)
    if domoticz.devices('warmtelint').state == 'On' then
            domoticz.log('xx Stroomlint werkt. Verbruikt ' .. curwat)
            domoticz.log('xx Stroomlint werkt niet! en switch staat aan!' .. curwat)
