Sensor status update
Posted: Wednesday 07 March 2018 17:45
Hi everyone.
I need your help to understand if my understanding on how Domoticz dals with devices is correct.
Background. I have a push button connected into an input of a Piface card directly plugged on my domoticz Raspberry.
Everything works fine, but from time to time (average 10 days) a device is triggered as if somebody pushed the button... but nobody did it.
From the device log I see that the button goes on and off within the same second (no milliseconds available in Domoticz
I think we all agree that this should be something due to an electrical interference (bounce).
In this scenario I'm trying to fix the issue by adding the following logic in the LUA device event:
1) the event is triggered by a device change
2) if the triggered device is the push button (information in DeviceChanged) then I go to read again the status of the push button via using the OtherDevice function assuming that the time between the triggering event and the re-read is longer than the "bounce"
The question is: am I correct when I assume that the OtherDevice function is re-reading the status of the push button?
If not, do you have an alternative way to deal with this issue withe a "software trick" to avoid adding electronic components?
The current event is here:
Thanks for reading till here
Giacomo
time = os.date("%x %X")
for name, value in pairs(devicechanged) do
deviceValue = value --Store value of the device changed to deviceValue variable
deviceName = name --Store name of the device changed to deviceName variable
if deviceName == 'Shutters Up'
then
if deviceValue == 'On'
then
print ('DEVICECHANGED '..deviceName..' '..deviceValue)
for deviceName,deviceValue in pairs(otherdevices) do
if (deviceName=='Shutters Up')
then
print ('OTHERDEVICES '..deviceName..' '..deviceValue)
commandArray['SendNotification']=(time .. ' OPEN SHUTTER TRIGGERED ' .. deviceValue)
then
print ('OPENING SHUTTERS')
commandArray['All shutters'] = 'On'
if deviceName == 'Shutters Down'
then
then
commandArray['All shutters'] = 'Off'
Giacomo
