Best way to install Domoticz on Ubuntu server 16.04
Posted: Sunday 04 March 2018 18:18
by cazz
I have now reinstall the Domoticz over three times and not got it to work.
I have install it in three different ways but still have problem with it
I have no problem to install the Domoticz, I also have no problem to install OpenZwave (I get no error anyway)
But when I trying to add a node to the Aeon Labs Z-Stick USB Gen5 nothing happend.
I have a Z-Wave Schuko Plug-in Switch plus Power Meter and it does not show up when I trying to make Domoticz to find it.
Re: Best way to install Domoticz on Ubuntu server 16.04
Posted: Sunday 04 March 2018 18:25
by febalci
i just downloaded the linux precompiled binary from domoticz downloads (stable) and openened up the tgz archive and installed on ubuntu 17.10 server. Using ZWave gen5 stick. No problems so far.
Posted: Sunday 04 March 2018 18:40
by cazz
hmm ok, do you have any guide that I can follow?
Posted: Sunday 04 March 2018 18:50
by cogliostrio
The easiest and quickest way would probably be as described here:
https://domoticz.com/downloads/
sudo curl -L install.domoticz.com | bash
Posted: Sunday 04 March 2018 19:09
by cazz
ok I can try it again.
Last time I did install OpenZwave first but now I just run the command and see.
Posted: Sunday 04 March 2018 19:20
by cazz
ok I have now install it again
After I have add the USB and see that Domoticz find it I go to the control panel
I select "Add Device" and press "Go"
Almost right after it say
"Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)"
I press the button for " Z-Wave Schuko Plug-in Switch plus Power Meter" three times but nothing happend.
No new device start to show.
/Update
Have try a little more but same thing but her is the log
2018-03-04 19:49:41.130 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2018-03-04 19:49:41.130 Build Hash: 494fff71, Date: 2017-07-30 12:19:41
2018-03-04 19:49:41.130 Startup Path: /home/konto/domoticz/
2018-03-04 19:49:41.341 PluginSystem: Started, Python version '3.5.2'.
2018-03-04 19:49:41.342 Active notification Subsystems: gcm, http (2/12)
2018-03-04 19:49:41.354 WebServer(HTTP) started on address: :: with port 8080
2018-03-04 19:49:41.365 WebServer(SSL) started on address: :: with port 443
2018-03-04 19:49:41.365 Proxymanager started.
2018-03-04 19:49:41.365 Starting shared server on: :::6144
2018-03-04 19:49:41.365 RxQueue: queue worker started...
2018-03-04 19:49:41.365 TCPServer: shared server started...
2018-03-04 19:49:43.366 EventSystem: reset all events...
2018-03-04 19:49:43.367 EventSystem: reset all device statuses...
2018-03-04 19:49:43.378 Python EventSystem: Module not found - Trying to initialize.
2018-03-04 19:49:43.379 Python EventSystem: Initalizing event module.
2018-03-04 19:49:43.379 EventSystem: Started
2018-03-04 19:49:43.698 PluginSystem: Entering work loop.
2018-03-04 19:49:43.866 OpenZWave: using config in: /home/konto/domoticz/Config/
2018-03-04 19:49:43.892 OpenZWave: Starting...
2018-03-04 19:49:43.892 OpenZWave: Version: 1.4-2692-g3fc69674-dirty
2018-03-04 19:49:44.106 OpenZWave: Driver Ready
2018-03-04 19:49:44.126 OpenZWave: All Nodes queried
2018-03-04 19:49:48.637 Incoming connection from: 192.168.1.56
2018-03-04 19:50:12.623 OpenZWave: Heal Node command initiated for node: 1 (0x01)...
2018-03-04 19:50:29.876 OpenZWave: Received timeout notification from HomeID: 3649732117, NodeID: 255 (0xff)
Posted: Sunday 04 March 2018 20:28
by febalci
Did you tried hard resetting aoetec gen5 and adding the nodes again? Seems like there is no zwave nodes config on gen5. Try adding with off port, take out gen5 from usb, press gen 5 button, when blinking blue press node s button.
Posted: Sunday 04 March 2018 20:31
by cazz
yes I did shut the computer down, remove the USB and push a the button until it led to be blue and then plug it in and start the server again
Posted: Sunday 04 March 2018 20:32
by febalci
No please read the aoetec gen5 manual, when blinking blue do not plug it in usb. Take it near the node and press s button on node.
Posted: Sunday 04 March 2018 20:45
by cazz
ok after I have done that and plug it in USB and start the server and look in the log I can see
2018-03-04 20:38:01.506 OpenZWave: New Node added. HomeID: 3878640583, NodeID: 1 (0x01)
I guess it is the new device but I can't see it?
Posted: Monday 05 March 2018 20:52
by cazz
Have no idea what I have done.
But today I did reconnect the USB and restart the Domoticz and now I can see it??
Posted: Tuesday 13 March 2018 8:58
by maomanna
if you include a node but it dont show up, wake the node or do the include again (without exclude).
this helps for me.
