Alecto SA33 smoke alarm not detected
Posted: Wednesday 28 February 2018 19:32
by pascalsiekman
Hello all,
Im having a RPI Domoticz v3.8153 and RFXCom433E firmware Ext/1020.
In RFXCom Oregon Scientific is enabled.
Also the learn mode is active.
If I push the test button on the Alecto SA33 smoke alarm it will not show up.
What can I do to troubleshoot this.
Greatings Pascal
Re: Alecto SA33 smoke alarm not detected
Posted: Wednesday 28 February 2018 20:50
by SweetPants
Do you mean with "learn mode", "Accept new hardware devices" in the settings menu?
Posted: Wednesday 28 February 2018 21:11
by pascalsiekman
Setup:
Hardware/Devices:
Accept new Hardware Devices Allow for 5 Minutes
But also if I use the learn light switch it's not working.
Posted: Wednesday 28 February 2018 22:44
by b_weijenberg
Please check with RFXmngr and only Oregon enabled.
If not received contact support rfxcom.com
Posted: Thursday 01 March 2018 21:24
by pascalsiekman
RFXMngr is seeing them.
A
1-3-2018 21:06:05
Packettype = Security1
subtype = SA30 smoke detector
Sequence nbr = 6
id1-3 = 0C9B00 decimal:826112
status = Panic
Signal level = 7 -64dBm
Can I insert them by manual? And not learning mode?
Posted: Friday 17 February 2023 19:00
by Lebo2d9
I know I'm replying to an old post but I have the same problem.
I have recently replaced a smokedetector and the new one is not detected by domoticz.
RFXmgr is seeing the smokedetector.
This one is not seen by domoticz
Sequence nbr = 1
id1-3 = 157E00 decimal:1408512
status = Panic
This one is seen by domoticz
Sequence nbr = 0
id1-3 = 877A00 decimal:8878592
status = Panic
I haven't upgraded yet to 2023.1
