Outdoor light at nighttime
Posted: Wednesday 28 February 2018 19:12
by jandirkv
Hello I'm new to DZvents scripting. I have Lots of VBA experience but I cant get the sintax right. I want a script that turns on my outdoor light 15 minutes before Sunset and 15 minutes after Sunset. But when I use Siri to turn off my lights when i go to bed and want de outdoor light to turn on again. I made the following script.
timer = { 'every 1 minutes'}
execute = function(domoticz,timer)
if (domoticz.time > '30 minutes before sunset' and domoticz.time < '15 minutes after sunrise' and domoticz.devices('Lamp Buiten').state) == 'Off' then
domoticz.devices('Lamp Wand 1').switchSelector(55)
if (domoticz.time > '16 minutes after sunrise' and domoticz.time < '16 minutes before sunset' and domoticz.devices('Lamp Buiten').state) == 'On' then
domoticz.devices('Lamp Buiten').switchOff()
Domoticz log give the following error: attempt to compare string with table.
I would appreciatie the help.
Re: Outdoor light at nighttime
Posted: Wednesday 28 February 2018 21:49
by SweetPants
Please put your code between code blocks to make it more readable
Posted: Wednesday 28 February 2018 22:17
by jandirkv
Posted: Wednesday 28 February 2018 23:43
by NuNca
jandirkv wrote: Wednesday 28 February 2018 22:17
think the problem is that == 'Off' and == 'On' are outside the ).
try this.
timer = { 'every minute'}
if (domoticz.time > '30 minutes before sunset' and domoticz.time < '15 minutes after sunrise' and domoticz.devices('Lamp Buiten').state == 'Off') then
if (domoticz.time > '16 minutes after sunrise' and domoticz.time < '16 minutes before sunset' and domoticz.devices('Lamp Buiten').state == 'On') then
Posted: Thursday 01 March 2018 19:43
by jandirkv
Thank you for your help nunca. I tried your code but still no luck. Log still gives the following error: 'attempt to compare string with table'
Posted: Thursday 01 March 2018 23:39
by NuNca
No problem, I didn't check the rest of the code. but the time rules don't seem to check out.
Here is another try, did test it and seems to work for me.
if (domoticz.time.matchesRule('between 30 minutes before sunset and 15 minutes after sunrise') and domoticz.devices('Lamp Buiten').state == 'Off') then
if (domoticz.time.matchesRule('between 16 minutes after sunrise and 16 minutes before sunset') and domoticz.devices('Lamp Buiten').state == 'On') then
Posted: Friday 02 March 2018 7:38
by tlpeter
Try something like this (this is not a tested and used script so you need to fix it for your self!!!)
active = true,
devices = {'Keuken'}
execute = function(domoticz, roomSwitch)
if
(roomSwitch.state == 'On') then
domoticz.devices('Keukenkastjes wit').dimTo(100)
elseif
(roomSwitch.state == 'Off') and (domoticz.time.matchesRule('at sunset-22:00')) then
domoticz.devices('Keukenkastjes wit').dimTo(20)
elseif
(roomSwitch.state =='Off') and (domoticz.time.matchesRule('at 22:01-23:59')) then
domoticz.devices('Keukenkastjes wit').dimTo(0)
elseif
(roomSwitch.state =='Off') and (domoticz.time.matchesRule('at 00:00-sunset')) then
Posted: Saturday 03 March 2018 20:23
by jandirkv
NuNca wrote: Thursday 01 March 2018 23:39
I tried it but it did not work for me. The outdoorlamp was not turned on this evening. I see you used the matchesrules Command. Is there a user manual besides the very limited one on the domoticz site where I can find commands like that.
Posted: Wednesday 28 March 2018 20:45
by jandirkv
Thank you all for the help. I finally figured it out. I was running the stable version and that version had dzvents 2.2.0 which did not support the between rule. I update to the beta and now al my scripts work.
