Python plugin: Xiaomi Mi Flower Mate
blauwebuis
- Domoticz version: current
With this plugin you can easily connect to your Xiaomi Flower Mate devices.
These are Bluetooth LE plant monitoring devices which cost about 12 dollars. They last up to a year on a coincell battery, and measure moisture, temperature, light and conductivity.
https://wiki.hackerspace.pl/projects:xiaomi-flora
1. Install the plugin
2. Keep automatic mode, or change to manual mode. In manual mode you can control which devices should be enabled, simply by adding their mac addresses on the hardware page.
3. The plugin creates 4 sensors (moisture, etc) for each device.
4. The plugin creates a special switch. Toggle the switch to get fresh data from all sensors.
By having a switch to poll for new data, it becomes easy to create timers and other fun integrations in scripts.
Details on the wiki:
https://www.domoticz.com/wiki/Plugins/Mi_flower_mate
Download on Github:
https://github.com/flatsiedatsie/Mi_Flower_mate_plugin
Download on Github:
Last edited by blauwebuis on Wednesday 21 February 2018 1:02, edited 1 time in total.
joostnl
Re: Python plugin: Xiaomi Mi Flower Mate
Great to see new development! Are there any advantages above the original wiki script?
blauwebuis
UPDATE
I've added an "automatic" mode. It does a bluetooth scan when Domoticz starts and then automatically adds any new MiFlora sensors it finds. So after installing this plugin your MiFlora devices will automatically show up.
Advantages of using the plugin:
- Much easier to install than the old script.
- No need to manually edit anything in the script. The plugin even has an 'automatic' mode.
- Easy to change polling frequency: just set a timer for the 'master switch' which the plugin creates. Goodbye cron!
- Curious how your plants are doing right now? Just toggle that switch.
- It uses the new BluePy library, and the latest version of the MiFlora library, making it more robust.
The Mi Flora / Mi Flower Mate devices have come down in price a bit too ( $12 ).
IDANIT
TYVM, this plugin is awesome, great job!!!
Is it possible (how) to poll, let say every hour instead once a day (grafana)? As I noticed it checks the status of both on and off.blauwebuis wrote: Wednesday 21 February 2018 0:57 Easy to change polling frequency: just set a timer for the 'master switch' which the plugin creates.
blauwebuis
Setting a timer is easy. Just setup the switch with a timer as you would any other switch.
I could make it so that the switch immediately turns itself off again.
IDANIT
It is easy when You know how toblauwebuis wrote: Thursday 22 February 2018 0:19 Setting a timer is easy. Just setup the switch with a timer as you would any other switch.
I think it would be okblauwebuis wrote: Thursday 22 February 2018 0:19 I could make it so that the switch immediately turns itself off again.
Some issue:
2018-02-22 08:32:14.672 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:32:20.644 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:32:30.677 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:32:40.653 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:32:50.680 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:33:00.656 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:33:10.639 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:33:20.667 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:33:30.644 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:33:40.671 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:33:50.699 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-22 08:34:00.678 (MiFlora) Calling message handler 'onHeartbeat'.Code: Select all
2018-02-22 08:04:03.883 Domoticz V3.8930 (c)2012-2018 GizMoCuz
2018-02-22 08:04:03.886 Build Hash: 2b97ba86, Date: 2018-02-21 09:02:15
2018-02-22 08:04:03.887 Startup Path: /home/pi/domoticz/
2018-02-22 08:04:04.314 EventSystem: reset all events...
2018-02-22 08:04:05.075 PluginSystem: Started, Python version '3.5.3'.
2018-02-22 08:04:05.137 WebServer(HTTP) started on address: :: with port 8080
2018-02-22 08:04:05.176 WebServer(SSL) started on address: :: with port 443
2018-02-22 08:04:05.183 Proxymanager started.
2018-02-22 08:04:05.193 TCPServer: shared server started...
2018-02-22 08:04:05.193 RxQueue: queue worker started...
2018-02-22 08:04:07.194 (MiFlora) Started.
2018-02-22 08:04:07.195 EventSystem: reset all events...
2018-02-22 08:04:07.196 EventSystem: reset all device statuses...
2018-02-22 08:04:07.350 PluginSystem: Entering work loop.
2018-02-22 08:04:07.740 Python EventSystem: Initalizing event module.
2018-02-22 08:04:07.747 EventSystem: Queue thread started...
2018-02-22 08:04:07.747 EventSystem: Started
2018-02-22 08:04:08.809 (MiFlora) Initialized version 1.0.0, author 'blauwebuis'
2018-02-22 08:04:08.809 (MiFlora) Entering work loop.-
Oliwier
Same problem here every 10s 'onHeartbeat' but bigger issue is:IDANIT wrote: Thursday 22 February 2018 8:53Some issue:Code: Select all
2018-02-22 08:32:04.672 (MiFlora) Calling message handler 'onHeartbeat'. 2018-02-22 08:32:14.672 (MiFlora) Calling message handler 'onHeartbeat'. 2018-02-22 08:33:50.699 (MiFlora) Calling message handler 'onHeartbeat'. 2018-02-22 08:34:00.678 (MiFlora) Calling message handler 'onHeartbeat'.
2018-02-23 15:31:56.966 Error: (MiFlora) 'onCommand' failed 'BTLEException'.
2018-02-23 15:31:56.966 Error: (MiFlora) ----> Line 242 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function onCommand
2018-02-23 15:31:56.966 Error: (MiFlora) ----> Line 93 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function onCommand
2018-02-23 15:31:56.966 Error: (MiFlora) ----> Line 149 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function getPlantData
2018-02-23 15:31:56.966 Error: (MiFlora) ----> Line 103 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/miflora/miflora_poller.py, function firmware_version
2018-02-23 15:31:56.966 Error: (MiFlora) ----> Line 47 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/miflora/backends/__init__.py, function __enter__
2018-02-23 15:31:56.967 Error: (MiFlora) ----> Line 55 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/miflora/backends/bluepy.py, function connect
2018-02-23 15:31:56.967 Error: (MiFlora) ----> Line 353 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function __init__
2018-02-23 15:31:56.967 Error: (MiFlora) ----> Line 402 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function _connect
blauwebuis
@idanit: you are using a older version that still has debugging output enabled.
@Oliwier: how many Flower Mates do you have? I have tested it with 2. I also got the error you mentioned, but fixed that by adding a bit more time between readings of all the sensors. Perhaps if you have more than 2 it needs a bit more time still. Or perhaps you're also using the older version, as you also get the debug output.
You can try making this longer in the code too:
# give bluetooth a little breathing room
time.sleep(1)-
IDANIT
I've noticed that it is 1.0.0 version, but I just git clone it from Your github. I did it again but it is still 1.0.0.blauwebuis wrote: Friday 23 February 2018 18:56 @idanit: you are using a older version that still has debugging output enabled.
I am not much of a python programmer, should I change it to
time.sleep(2)Code: Select all
time.sleep(3)-
Oliwier
1. I got 5 MiFlorasblauwebuis wrote: Friday 23 February 2018 18:56 @Oliwier: how many Flower Mates do you have? I have tested it with 2. I also got the error you mentioned, but fixed that by adding a bit more time between readings of all the sensors. Perhaps if you have more than 2 it needs a bit more time still. Or perhaps you're also using the older version, as you also get the debug output.
# give bluetooth a little breathing room time.sleep(1)
2. I've changed sleep time to 3 sec.
3. I git clone plugin onece again... no 'onHeartbeat' but same as @Idanit plugin v 1.0.0
4. still got the same error as before:
2018-02-25 12:00:01.140 Schedule item started! Name: MiFlora - Flip to update Mi Flowermates, Type: On Time, DevID: 1, Time: 2018-02-25 12:00:01
2018-02-25 12:00:01.152 (MiFlora) onCommand called for Unit 1: Parameter 'On', Level: 0
2018-02-25 12:00:01.175 (MiFlora) getting data from sensor: xxxxxxxxx
2018-02-25 12:00:03.508 (MiFlora) moisture = 0
2018-02-25 12:00:03.517 (MiFlora) temperature = 26.7
2018-02-25 12:00:03.526 (MiFlora) light = 40
2018-02-25 12:00:03.536 (MiFlora) conductivity = 0
2018-02-25 12:00:06.539 (MiFlora) getting data from sensor: xxxxxxxxx
2018-02-25 12:00:08.167 (MiFlora) moisture = 0
2018-02-25 12:00:08.177 (MiFlora) temperature = 22.4
2018-02-25 12:00:08.187 (MiFlora) light = 76
2018-02-25 12:00:08.196 (MiFlora) conductivity = 0
2018-02-25 12:00:11.199 (MiFlora) getting data from sensor: xxxxxxxxxx
2018-02-25 12:00:14.566 (MiFlora) moisture = 30
2018-02-25 12:00:14.575 (MiFlora) temperature = 21.6
2018-02-25 12:00:14.585 (MiFlora) light = 108
2018-02-25 12:00:14.594 (MiFlora) conductivity = 343
2018-02-25 12:00:17.598 (MiFlora) getting data from sensor: xxxxxxxxxx
2018-02-25 12:00:22.107 (MiFlora) moisture = 1
2018-02-25 12:00:22.117 (MiFlora) temperature = 26.7
2018-02-25 12:00:22.126 (MiFlora) light = 22
2018-02-25 12:00:22.135 (MiFlora) conductivity = 0
2018-02-25 12:00:25.139 (MiFlora) getting data from sensor: xxxxxxxxxxx
2018-02-25 12:00:29.497 (MiFlora) moisture = 23
2018-02-25 12:00:29.507 (MiFlora) temperature = 21.5
2018-02-25 12:00:29.516 (MiFlora) light = 104
2018-02-25 12:00:29.525 (MiFlora) conductivity = 164
2018-02-25 12:23:22.515 Domoticz: TCP connected to: 192.168.1.85:6144
2018-02-25 12:25:01.383 Incoming Domoticz connection from: 192.168.1.110
2018-02-25 13:00:01.852 Schedule item started! Name: MiFlora - Flip to update Mi Flowermates, Type: On Time, DevID: 1, Time: 2018-02-25 13:00:01
2018-02-25 13:00:01.856 (MiFlora) onCommand called for Unit 1: Parameter 'Off', Level: 100
2018-02-25 13:00:01.875 (MiFlora) getting data from sensor: xxxxxxxxxxxx
2018-02-25 13:00:05.484 (MiFlora) moisture = 0
2018-02-25 13:00:05.497 (MiFlora) temperature = 26.7
2018-02-25 13:00:05.510 (MiFlora) light = 6
2018-02-25 13:00:05.523 (MiFlora) conductivity = 0
2018-02-25 13:00:08.524 (MiFlora) getting data from sensor: xxxxxxxxxxxxxxxxx
2018-02-25 13:00:13.047 (MiFlora) moisture = 0
2018-02-25 13:00:13.056 (MiFlora) temperature = 22.5
2018-02-25 13:00:13.066 (MiFlora) light = 0
2018-02-25 13:00:13.075 (MiFlora) conductivity = 0
2018-02-25 13:00:16.079 (MiFlora) getting data from sensor: xxxxxxxxxxxxxxxxx
2018-02-25 13:00:19.013 Error: (MiFlora) 'onCommand' failed 'BTLEException'.
2018-02-25 13:00:19.013 Error: (MiFlora) ----> Line 242 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function onCommand
2018-02-25 13:00:19.013 Error: (MiFlora) ----> Line 93 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function onCommand
2018-02-25 13:00:19.014 Error: (MiFlora) ----> Line 149 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function getPlantData
2018-02-25 13:00:19.014 Error: (MiFlora) ----> Line 103 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/miflora/miflora_poller.py, function firmware_version
2018-02-25 13:00:19.014 Error: (MiFlora) ----> Line 47 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/miflora/backends/__init__.py, function __enter__
2018-02-25 13:00:19.014 Error: (MiFlora) ----> Line 55 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/miflora/backends/bluepy.py, function connect
2018-02-25 13:00:19.014 Error: (MiFlora) ----> Line 353 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function __init__
2018-02-25 13:00:19.014 Error: (MiFlora) ----> Line 402 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function _connect-
Oliwier
Well, 5 sec also did not help... lets try with 7.
blauwebuis
@oliwier: see also here:
https://github.com/IanHarvey/bluepy/issues/218
Are you using python 3.5 by any chance?
Oliwier
Indeed, 3.5.3
IDANIT
I've read somewhere that there are some issues with python 3.5 on Raspbian Stretch.
I uninstalled version 3.5 and installed 3.4, but the problem remained. Also 10s did not solve the problem.
Oliwier
IDANIT wrote: Wednesday 28 February 2018 20:13 I uninstalled version 3.5 and installed 3.4, but the problem remained. Also 10s did not solve the problem.
sudo apt-get remove python3.5
IDANIT
and
sudo apt-get autoremove
blauwebuis
UPDATE
I've uploaded a new version of the plugin that may fix the bluetooth issue.
The plugin now uses the heartbeat function to poll one sensor per heartbeat.
- This could give more space between polls, and thus prevent the Bluepy helper from crashing if users have a lot of Flower Mates.
- This also keeps Domoticz happy, as the plugin now doesn't take up too much processing time.
The plugin now also toggles the switch visually to "on" when the switch it pressed, and turns itself visually back into the off-state once all the polling is done.
IDANIT
sorry mate, no change at all.
Well... there is one... instead of: "onCommand"
it is: "onHeartbeat"
Error: (MiFlora) ----> Line 402 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function _connectCode: Select all
Error: (MiFlora) 'onHeartbeat' failed 'BTLEException'.
Error: (MiFlora) ----> Line 247 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function onHeartbeat
Error: (MiFlora) ----> Line 99 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function onHeartbeat
Error: (MiFlora) ----> Line 154 in /home/pi/domoticz/plugins/Mi_Flower_mate_plugin/plugin.py, function getPlantData
Error: (MiFlora) ----> Line 402 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function _connecRe: Python plugin: Xiaomi Mi Flower Mate
I'm also facing the BTLEException error. 90% of the time the plug-in is working great, but it seems when the script has trouble seeing the Flower Mate the script crashes and i have to restart Domoticz before the script will work again.
deennoo
That a really good Job guy !
I'm using BLE Scanner Plugin too, I have 2 bluetooth LE dongle, can you add a choice of which one to use please ? using dongle mac adresse is a good choice, hci0 or hci1 can be good too
Actually, if i check miflora info running blescanner this give this :
018-03-10 16:42:46.830 Error: (Miflora) 'onHeartbeat' failed 'BTLEException'.
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 247 in /home/pi/domoticz/plugins/MiFlora/plugin.py, function onHeartbeat
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 99 in /home/pi/domoticz/plugins/MiFlora/plugin.py, function onHeartbeat
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 154 in /home/pi/domoticz/plugins/MiFlora/plugin.py, function getPlantData
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 103 in /home/pi/domoticz/plugins/MiFlora/miflora/miflora_poller.py, function firmware_version
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 47 in /home/pi/domoticz/plugins/MiFlora/miflora/backends/__init__.py, function __enter__
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 55 in /home/pi/domoticz/plugins/MiFlora/miflora/backends/bluepy.py, function connect
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 353 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function __init__
2018-03-10 16:42:46.830 Error: (Miflora) ----> Line 402 in /usr/local/lib/python3.5/dist-packages/bluepy/btle.py, function _connectDomoticz stable 3.5877 for real & Domoticz beta for test
http://domo-attitude.fr
