Combining dimmer with Harmony activities
Posted: Monday 19 February 2018 20:20
C# developer here and kind of new to the whole scripting thing in Domoticz.
First I tried Blockly, which is nice, but I like more control.
So then I found Lua and tried some little things, which works ok.
Then I found dzVents, which I like more than Lua, so sticking with that for now.
Now I'm running into the following;
I'd like to change a dimmer level when watching a movie or watching TV, both are Logitech Harmony activities (Harmony Elite/Hub).
So I set up 4 events; both a On and Off event for both activities. The On event looks like this:
The Off event looks like this:
The only issue with this; when I switch from "TV kijken" to "Film kijken", first the dimmer is set to the LEDSpotsLevel followed by the activity level. But these are following up eachother so fast, the 2nd instruction is ignored.
active = true,
devices = {
'TV kijken',
local light = domoticz.devices('LED spots')
if (device.state == 'On') then
domoticz.globalData.LEDSpotsLevel = light.level
light.dimTo(40)
}Code: Select all
active = true,
devices = {
'TV kijken',
if (device.state == 'Off') then
light.dimTo(domoticz.globalData.LEDSpotsLevel)
}Question: How can I prevent the 2nd instruction from being ignored, or how can I prevent the 'restore' instruction from being sent at all when there's a follow-up event?2018-02-19 20:04:34.976 Harmony Hub: Changing activity
2018-02-19 20:04:42.558 Harmony Hub: Finished changing activity
2018-02-19 20:04:42.633 dzVents: Info: Handling events for: "Film kijken", value: "Off"
2018-02-19 20:04:42.633 dzVents: Info: ------ Start internal script: Film kijken start: Device: "Film kijken (Harmony)", Index: 10
2018-02-19 20:04:42.641 dzVents: Info: ------ Finished Film kijken start
2018-02-19 20:04:42.641 dzVents: Info: ------ Start internal script: Film kijken stop: Device: "Film kijken (Harmony)", Index: 10
2018-02-19 20:04:42.642 dzVents: Off
2018-02-19 20:04:42.642 dzVents: Info: ------ Finished Film kijken stop
2018-02-19 20:04:42.643 EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua
2018-02-19 20:04:42.720 dzVents: Info: Handling events for: "TV kijken", value: "On"
2018-02-19 20:04:42.721 dzVents: Info: ------ Start internal script: TV kijken start: Device: "TV kijken (Harmony)", Index: 9
2018-02-19 20:04:42.722 dzVents: Info: ------ Finished TV kijken start
2018-02-19 20:04:42.722 dzVents: Info: ------ Start internal script: TV kijken stop: Device: "TV kijken (Harmony)", Index: 9
2018-02-19 20:04:42.723 dzVents: Info: ------ Finished TV kijken stop
2018-02-19 20:04:42.723 EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/dzVents/runtime/dzVents.lua
