Selective Notifications from Python/API/JSON Topic is solved
ycahome
Domoticz version: lat Beta
Post by ycahome »
As far as I know In python we have only one way to send notifications:
use urllib to fetch
http://127.0.0.1:8080/json.htm?param=sendnotification&type=command&subject=<subject>&body=<body>
What I would like to be able to select which notification-systems must be activated. Basically just like it is possible to configure this for switches/sensors in the GUI after choosing the "notification" button.
So the command would be something like:
http://127.0.0.1:8080/json.htm?param=sendnotification&type=command&system=notificationsystems&subject=<subject>&body=<body>
So an additional parameter, which then contains one or more systems from the list: clickatell, email, http, kodi, lms, nma, prowl, pushalot, pushbullet, pushover.
This is already implemented via LUA,
can we have the same on python via JSON/API or by exporting notification parameters (to avoid end user intervention to be required)?
ycahome
Re: Selective Notifications from Python/API/JSON
Post by ycahome »
Just answered myself by reading the following post:
http://www.domoticz.com/forum/viewtopic ... 31&t=14884
