IR remote control issue
Posted: Friday 09 February 2018 15:13
by BartSr
Hi.
I found an interesting article about IR remote control with Samsung protocol.
http://techiesms.blogspot.nl/2016/01/ir ... iting.html
As the frequency of transmission is around 38 kHz I tried with several values (see the "x" in the code down below).
I hardcoded for this purpose the adress and data for switching TV ON/OFF.
Commands are sent continuously with timedelay in between.
This works; but sometimes yes, sometimes no.
Any suggestions how to get this more reliable?
I use the Arduino supplied from USB as well as 12V DC adapter
TIA
-Bart
code:
//#include <EEPROM.h>
int eaddr = 0;
#define ir_led 8
int address;
int data;
boolean bin[8], Data[32];
int k = 0;
int x = 0;
void setup()
Serial.begin(9600);
pinMode(ir_led, OUTPUT);
// address = EEPROM.read(0); // address is stored at address 0 of EEPROM
address = 7;
dec_to_bin(address); //convert the address into binary
for (int i = 0; i < 8; i++)
Data = bin;
Data[i + 8] = bin;
void loop()
for (int r = 1; r < 4; r++) // sending data from address 1 of EEPROM ; This loop will transmit 3 buttons data through IR
// data = EEPROM.read(eaddr + r);
data = 2;
dec_to_bin(data); //convert data into binary
Data[i + 16] = bin;
Data[i + 24] = !bin;
for (int i = 0; i < 32; i++)
Serial.print(Data);
Serial.println();
x=115;
transmit(); //transmit
x=116;
x=117;
x=118;
x=119;
x=120;
delayMicroseconds(3100);
// delay(1000); // sending next data after 1 s
delay(8000); // sending next data after 1 s
void dec_to_bin(int dec) // converting decimal to binary
bin = dec % 2;
dec = dec / 2;
void transmit()
Serial.print(x);
Serial.println();
burst(x); // start bit = 4500/26=173 --> 4500/38=118
digitalWrite(ir_led, LOW);
delayMicroseconds(4500); //start bit
if (Data == 1)
burst(15);
delayMicroseconds(1690); //high bit
burst(15);
delayMicroseconds(560); //low bit
burst(15);
digitalWrite(ir_led, LOW); //stop bit
void burst(int pulses)
for (int i = 0; i < pulses; i++)
// 9 17
digitalWrite(ir_led, 1);
delayMicroseconds(9);
digitalWrite(ir_led, 0);
delayMicroseconds(17);
