How is the connection setup to MyDomoicz
Posted: Thursday 08 February 2018 11:18
Today I tried to setup MyDomoicz for the Domoicz that is in our holidayhome 1500km away.
This Domoticz is connected to the internet via 4G. The issue with that is that you cannot access any device on the local lan through the public IP (because of NAT that the telco's use for 4G). S what I used to do is setup a VPN from that Domoticz to my router at home and access it from there.
Drawback: My router assigns the VPN IP 'radomly'so after a connection-drop I have to figure out via which VPN Ip I can access the remote Domoticz.
From the description n he Wiki I understood that MyDomoricz works the other way around: Remote Domoticz connects to MyDomoticz. This should work over 4G (it does for my heatpump in the same location).
But since I do not see my remote Domoticz appearing in MyDomoticz (but I noticed the remote Domoticz received the instance ID) I might be wrong.
In which case MyDmoticz is no solution for me.
Can someone clarify how the connection between a remote Donmoticz and the MyDomoticz service is setup:
- From remote Domoticz -> MyDomoticz
OR
- From MyDomoticz -> remote Domoticz
OR
