Cloud cover from darksky
aleph0
Domoticz version: 11838
Post by aleph0 »
Hi All,
I made a script to grab a few more information from darksky than the darksky hardware plugin of domoticz:
- Cloud cover
- Visibility
- UV Index
- Atmospheric pressure
- Tomorrow forecast, min and max temperature (useful to warn one day in advance of adverse weather)
It's pretty straitforward and can be customized easily with more or less information. Forecast widget is of type "text"
Script LUA Time
--[[ Script to get some values from darksky API
local dev_Patm ="Pression atmosphérique"    -- Atmospheric pressure
local dev_UV   ="Index UV"                  -- UV Index
local dev_Vis  ="Visibilité"                -- Visibility
local dev_Cloud="Couverture nuageuse"       -- Cloud layer
local dev_Tmin ="Température min J+1"       -- Tomorrow temperature min forecast
local dev_Tmax ="Température max J+1"       -- Tomorrow temperature max forecast
local dev_Prev ="Previsions J+1"            -- Forecast d+1
local api_key="your_api_key" -- darksky secret key
local coord="45.0,4.0"                 -- latitude,longitude
local debug=0
function UpdateDev(device,nvalue,svalues)
    --Met à jour un device numérique Domoticz
    commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[device]..'|'..tostring(nvalue)..'|'..tostring(svalues)}
function os.capture(cmd, raw)
    local f = assert(io.popen(cmd, 'r'))
    local s = assert(f:read('*a'))
    f:close()
    if raw then return s end
    s = string.gsub(s, '^%s+', '')
    s = string.gsub(s, '%s+$', '')
    s = string.gsub(s, '[\n\r]+', ' ')
    return s
time = os.date("*t")
if  ((time.min+2)%5)==0  then -- Run every 5 minutes
    -- Querying Darksky
    json = (loadfile "/opt/domoticz/scripts/lua/JSON.lua")()  -- For Linux
    result=os.capture('curl -s "https://api.darksky.net/forecast/'..api_key..'/'..coord..'?lang=fr&units=ca&exclude=hourly,flags"')
    --print(result)
    -- Reading values from json
    local jsonValeur = json:decode(result)
    val_Patm =jsonValeur.currently.pressure
    val_UV   =jsonValeur.currently.uvIndex
    val_Vis  =jsonValeur.currently.visibility
    val_Cloud=jsonValeur.currently.cloudCover*100
    val_Tmin =round(jsonValeur.daily.data[1].temperatureLow,1)
    val_Tmax =round(jsonValeur.daily.data[1].temperatureHigh,1)
    icon     =jsonValeur.daily.data[1].icon
    summary  =jsonValeur.daily.data[1].summary
    -- Converting darksky icon into domoticz forecast code
    if icon=="clear-day" or icon=="clear-night"                     then prev=1 --Sunny
    elseif icon=="rain" or icon=="snow" or rain=="sleet"            then prev=6 --Cloudy/Rain
    elseif icon=="wind" or icon=="fog"                              then prev=0 --Stable
    elseif icon=="cloudy"                                           then prev=2 --Cloudy
    elseif icon=="partly-cloudy-day" or icon=="partly-cloudy-night" then prev=3 --Unstable
    else        prev=5 --Unknown
    forecast=summary.."<br>Min : "..val_Tmin.."°C Max : "..val_Tmax.."°C"
    if debug==1 then
        print("Pression : "..val_Patm)
        print("Index UV : "..val_UV)
        print("Visibilité : "..val_Vis)
        print("Couverture nuageuse : "..val_Cloud)
        print("Température min J+1 : "..val_Tmin)
        print("Température max J+1 : "..val_Tmax)
        print("Icon : "..icon.." "..prev)
        print("Summary : "..summary)
        print("Prévisions : "..forecast)
    -- Updating domoticz devices
    UpdateDev(dev_Patm,0,val_Patm..";"..prev)
    UpdateDev(dev_UV,0,val_UV..";0")
    UpdateDev(dev_Vis,0,val_Vis)
    UpdateDev(dev_Cloud,0,val_Cloud)
    UpdateDev(dev_Tmin,0,val_Tmin)
    UpdateDev(dev_Tmax,0,val_Tmax)
    if otherdevices_svalues[dev_Prev] ~= forecast then UpdateDev(dev_Prev,0,forecast) end
Additionnaly, in the solar sensor script of JM Leglise, I replaced the "octa" information with this cloud layer to get more frequent and accurate update.
Comments welcome !
Marci
Domoticz version: 3.8153
Re: Cloud cover from darksky
Post by Marci »
Worked great once I’d polyfilled os.capture by adding the following at line 3...
    f:close()
    return s
...thanks muchly!
aleph0
Post by aleph0 »
Oops, you're right, I forgot this one ! Post updated !!
EdwinK
Post by EdwinK »
Is there anything else i need to do? create devices or so to get this to work
aleph0
Post by aleph0 »
Yes, you need to create devices beforehand, register on darksky to get an api key and paste it in the script in the api_key variable
angelus1753
Domoticz version: 3.9056
Post by angelus1753 »
I'm making my first steps in Domoticz (and LUA for that matter) and I was wondering how to marry your script with the Lux script from Leglise. Perhaps you can show your script?
DS-218+ with Jadahl Domoticz
hairynoggin
Post by hairynoggin »
what are the names of the dummy switches?
also I get an error: Error: EventSystem: in cloud script: [string "--[[ Script to get some values from darksky A..."]:38: attempt to call a nil value
can anyone with knowledge let me know what is going wrong?
thanks in advance
Holland
Domoticz version: Beta Ch
Post by Holland »
Thanks aleph0.
Mine starts to bark at line 48 and 49, the round function.
2018-08-11 00:23:01.323 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_weather_darksky.lua: .../pi/domoticz/scripts/lua/script_time_weather_darksky.lua:48: attempt to call global 'round' (a nil value)
I tried including the round function, but to no prevail.
Some directions would be helpful
JCLB
Post by JCLB »
I think that the function os.capture doesn't collect the array daily.data[x] for some reason.
same problem occurs with icon =jsonValeur.daily.data1.icon and summary =jsonValeur.daily.data1.summary
aleph0
Post by aleph0 »
I forgot to include the round function in the script :-( Here it is, corrected
local debug=0
    f:close()
    return s
function round(num, dec)
    if num == 0 then
        return 0
        local mult = 10^(dec or 0)
        return math.floor(num * mult + 0.5) / mult
    -- Querying Darksky
    --print(result)
    if debug==1 then
Holland
Post by Holland »
Thanks for your quick reply. I have included the round function.
But now errors at line 19. See below. Did you encounter that one before?
For the rest it works nicely, as variables have darksky values. It's just the last part, writing the data to the created devices.
2018-08-13 10:58:01.107 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_weather_darksky.lua: .../pi/domoticz/scripts/lua/script_time_weather_darksky.lua:19: attempt to concatenate field '?' (a nil value)
aleph0
Post by aleph0 »
Holland wrote: Monday 13 August 2018 11:13 But now errors at line 19. See below. Did you encounter that one before?
No, it works fine here !
Can you set local debug=1 at line 15 so that we can track which update fails ?
Holland
Post by Holland »
See below;
2018-08-13 11:43:01.022 Status: LUA: {"latitude":52.0,"longitude":4.0,"timezone":"Europe/Amsterdam","currently":{"time":1534153380,"summary":"Bruine","icon":"rain","precipIntensity":0.3937,"precipProbability":0.37,"precipType":"rain","temperature":21.13,"apparentTemperature":21.22,"dewPoint":16.27,"humidity":0.74,"pressure":1005.18,"windSpeed":17.14,"windGust":20.44,"windBearing":215,"cloudCover":0.54,"uvIndex":3,"visibility":11.31,"ozone":327.49},"daily":{"summary":"Pluie faible aujourd’hui et jeudi, avec des températures maximales atteignant 27°C jeudi.","icon":"rain","data":[{"time":1534111200,"summary":"Pluie faible dans la matinée et l’après-midi.","icon":"rain","sunriseTime":1534134101,"sunsetTime":1534187507,"moonPhase":0.08,"precipIntensity":0.3378,"precipIntensityMax":1.2751,"precipIntensityMaxTime":1534140000,"precipProbability":0.88,"precipType":"rain","temperatureHigh":21.97,"temperatureHighTime":1534165200,"temperatureLow":16.61,"temperatureLowTime":1534212000,"apparentTemperatureHigh":22.02,"apparentTemperatureHighTime":1534165200,"apparentTemperatureLow":16.76,"apparentTemperatureLowTime":1534212000,"dewPoint":15.71,"humidity":0.78,"pressure":1006.23,"windSpeed":7.39,"windGust":27.89,"windGustTime":1534183200,"windBearing":250,"cloudCover":0.89,"uvIndex":3,"uvIndexTime":1534154400,"visibility":14.47,"ozone":322.8,"temperatureMin":17.61,"temperatureMinTime":1534194000,"temperatureMax":21.97,"temperatureMaxTime":1534165200,"apparentTemperatureMin":17.71,"apparentTemperatureMinTime":1534194000,"apparentTemperatureMax":22.02,"apparentTemperatureMaxTime":1534165200},{"time":1534197600,"summary":"Nuages épars dans la matinée.","icon":"partly-cloudy-day","sunriseTime":1534220600,"sunsetTime":1534273787,"moonPhase":0.11,"precipIntensity":0.0254,"precipIntensityMax":0.094,"precipIntensityMaxTime":1534204800,"precipProbability":0.31,"precipType":"rain","temperatureHigh":22.59,"temperatureHighTime":1534251600,"temperatureLow":16.4,"temperatureLowTime":1534298400,"apparentTemperatureHigh":22.59,"apparentTemperatureHighTime":1534251600,"apparentTemperatureLow":16.56,"apparentTemperatureLowTime":1534298400,"dewPoint":15.05,"humidity":0.78,"pressure":1012.39,"windSpeed":14.58,"windGust":26.17,"windGustTime":1534226400,"windBearing":289,"cloudCover":0.31,"uvIndex":5,"uvIndexTime":1534244400,"visibility":16.09,"ozone":315.08,"temperatureMin":16.61,"temperatureMinTime":1534212000,"temperatureMax":22.59,"temperatureMaxTime":1534251600,"apparentTemperatureMin":16.76,"apparentTemperatureMinTime":1534212000,"apparentTemperatureMax":22.59,"apparentTemperatureMaxTime":1534251600},{"time":1534284000,"summary":"Nuages épars dans la matinée.","icon":"partly-cloudy-night","sunriseTime":1534307099,"sunsetTime":1534360066,"moonPhase":0.15,"precipIntensity":0.0025,"precipIntensityMax":0.0102,"precipIntensityMaxTime":1534334400,"precipProbability":0.07,"precipType":"rain","temperatureHigh":25.21,"temperatureHighTime":1534334400,"temperatureLow":16.67,"temperatureLowTime":1534392000,"apparentTemperatureHigh":25.21,"apparentTemperatureHighTime":1534334400,"apparentTemperatureLow":16.71,"apparentTemperatureLowTime":1534392000,"dewPoint":15.51,"humidity":0.74,"pressure":1016.71,"windSpeed":12.76,"windGust":22.98,"windGustTime":1534352400,"windBearing":235,"cloudCover":0.16,"uvIndex":5,"uvIndexTime":1534330800,"visibility":16.09,"ozone":307.17,"temperatureMin":16.4,"temperatureMinTime":1534298400,"temperatureMax":25.21,"temperatureMaxTime":1534334400,"apparentTemperatureMin":16.56,"apparentTemperatureMinTime":1534298400,"apparentTemperatureMax":25.21,"apparentTemperatureMaxTime":1534334400},{"time":1534370400,"summary":"Nuageux durant toute la journée.","icon":"partly-cloudy-day","sunriseTime":1534393599,"sunsetTime":1534446344,"moonPhase":0.18,"precipIntensity":0.1651,"precipIntensityMax":0.8077,"precipIntensityMaxTime":1534431600,"precipProbability":0.7,"precipType":"rain","temperatureHigh":26.98,"temperatureHighTime":1534420800,"temperatureLow":14.06,"temperatureLowTime":1534474800,"apparentTemperatureHigh":27.16,"apparentTemperatureHighTime":1534420800,"apparentTemperatureLow":14.06,"apparentTemperatureLowTime":1534474800,"dewPoint":14.96,"humidity":0.72,"pressure":1013.74,"windSpeed":10.8,"windGust":29.29,"windGustTime":1534399200,"windBearing":231,"cloudCover":0.49,"uvIndex":4,"uvIndexTime":1534417200,"visibility":16.09,"ozone":309.52,"temperatureMin":16.67,"temperatureMinTime":1534392000,"temperatureMax":26.98,"temperatureMaxTime":1534420800,"apparentTemperatureMin":16.71,"apparentTemperatureMinTime":1534392000,"apparentTemperatureMax":27.16,"apparentTemperatureMaxTime":1534420800},{"time":1534456800,"summary":"Nuages épars débutant dans la soirée.","icon":"partly-cloudy-night","sunriseTime":1534480098,"sunsetTime":1534532620,"moonPhase":0.22,"precipIntensity":0.0686,"precipIntensityMax":0.5258,"precipIntensityMaxTime":1534456800,"precipProbability":0.68,"precipType":"rain","temperatureHigh":21.31,"temperatureHighTime":1534510800,"temperatureLow":16.29,"temperatureLowTime":1534546800,"apparentTemperatureHigh":21.31,"apparentTemperatureHighTime":1534510800,"apparentTemperatureLow":16.29,"apparentTemperatureLowTime":1534546800,"dewPoint":11.56,"humidity":0.68,"pressure":1017.36,"windSpeed":12.05,"windGust":26.73,"windGustTime":1534467600,"windBearing":275,"cloudCover":0.42,"uvIndex":5,"uvIndexTime":1534503600,"visibility":16.09,"ozone":323.09,"temperatureMin":14.06,"temperatureMinTime":1534474800,"temperatureMax":21.31,"temperatureMaxTime":1534510800,"apparentTemperatureMin":14.06,"apparentTemperatureMinTime":1534474800,"apparentTemperatureMax":21.31,"apparentTemperatureMaxTime":1534510800},{"time":1534543200,"summary":"Nuageux durant toute la journée.","icon":"partly-cloudy-day","sunriseTime":1534566598,"sunsetTime":1534618895,"moonPhase":0.25,"precipIntensity":0.1067,"precipIntensityMax":0.16,"precipIntensityMaxTime":1534618800,"precipProbability":0.25,"precipType":"rain","temperatureHigh":21.54,"temperatureHighTime":1534608000,"temperatureLow":17.08,"temperatureLowTime":1534654800,"apparentTemperatureHigh":21.66,"apparentTemperatureHighTime":153460
2018-08-13 11:43:01.035 Status: LUA: Pression : 1005.18
2018-08-13 11:43:01.035 Status: LUA: Index UV : 3
2018-08-13 11:43:01.035 Status: LUA: Visibilité : 11.31
2018-08-13 11:43:01.035 Status: LUA: Couverture nuageuse : 54
2018-08-13 11:43:01.035 Status: LUA: Température min J+1 : 16.6
2018-08-13 11:43:01.035 Status: LUA: Température max J+1 : 22
2018-08-13 11:43:01.035 Status: LUA: Icon : rain 6
2018-08-13 11:43:01.035 Status: LUA: Summary : Pluie faible dans la matinée et l’après-midi.
2018-08-13 11:43:01.035 Status: LUA: Prévisions : Pluie faible dans la matinée et l’après-midi.
2018-08-13 11:43:01.035 Min : 16.6°C Max : 22°C
aleph0
Post by aleph0 »
Ok... it doesn't help much as everything is read correctly from darksky...
update the function "UpdateDev" with some printouts to see what it tries to do :
    print(device,nvalue,svalues)
Something unrelated, after you got it to work : in the line os.capture(blablabla) you can change lang=fr by lang=nl (or en or... see https://darksky.net/dev/docs for the full list) to get forecast in your own language
Holland
Post by Holland »
See below.
2018-08-13 12:08:01.239 Status: LUA: Pression atmosphérique
2018-08-13 12:08:01.239 Status: LUA: 0
2018-08-13 12:08:01.239 Status: LUA: 1005.14;6
And I adjusted the Darksky output to nl. Thanks !
aleph0
Post by aleph0 »
hmm... did you adjust all the local dev_... variables to match your domoticz device names ? I doubt you use french names for them ;-)
Holland
Post by Holland »
It's a tough one...
Actually I kept all variable names the same, simular to the devices.
Could there be a problem with the device type used? I don't know if that's critical
juanjogarciac
Post by juanjogarciac »
Great script.
There are a lot of possibilities in https://darksky.net/dev/docs.
One question. Is Icon a text device? Or is possible to use some graphical device?
Thank you !!
Juanjo
aleph0
Post by aleph0 »
Icon is only the text displayed next to "forecast" in the barometer widget. I didn't try to display an actual icon. If you want to do so, I suggest to have a look at the moon phase script: they can display an icon from a script. Then we need to adapt the method
wergeld
Post by wergeld »
I am also getting the error on running the following function:
I have the following debug:
2018-09-26 18:58:37.578 Status: LUA: Pression : 1016.71
2018-09-26 18:58:37.579 Status: LUA: Index UV : 0
2018-09-26 18:58:37.579 Status: LUA: Visibilité : 10
2018-09-26 18:58:37.579 Status: LUA: Couverture nuageuse : 19
2018-09-26 18:58:37.579 Status: LUA: Température min J+1 : 75.4
2018-09-26 18:58:37.579 Status: LUA: Température max J+1 : 89.9
2018-09-26 18:58:37.579 Status: LUA: Icon : rain 6
2018-09-26 18:58:37.579 Status: LUA: Summary : Light rain in the evening.
2018-09-26 18:58:37.579 Status: LUA: Prévisions : Light rain in the evening.
2018-09-26 18:58:37.579 Min : 75.4°C Max : 89.9°C
2018-09-26 18:58:37.579 Status: LUA: Cloud Layer
2018-09-26 18:58:37.579 Status: LUA: 0
2018-09-26 18:58:37.579 Status: LUA: 19
I am not really sure what it is complaining about here.
