Page 1 of 4
Get online airquality data
Posted: Tuesday 06 February 2018 22:42
by elmortero
I have no airquality sensor but was interested in getting the info online.
This is what I came up with. It provides the general air quality index (AQI), but also separate values for the various polutors that are measured in order to get the index.
data from http://waqi.info/
An API key is required and can be aquired here ==> http://aqicn.org/data-platform/token/
I used two sensors for the Ozon value - mainly as a test - but you can use just the alert sensor and put the ozon value in the text
This separation was done to have a numeric value instead of text so it can be displayed as a graph
this script requires dzVents 2.4.0 or higher
If you are on a previous version and cannot upgrade please refer to BakSeeDaa's solution for fetching data from external servers
in this posthttp://www.domoticz.com/forum/viewtopic.php?f=59&t=19327
timer = { 'every 6 minutes' },
httpResponses = { 'waqi' } -- matches callback string below
execute = function(domoticz, triggerItem)
local lat = 'Your_Latitude'
local long = 'Your_longitude'
local apikey = 'YOU_API_KEY'
local AirC = domoticz.devices('AirC') -- virtual sensor of the type "Air Quality"
local prevAirC = AirC.co2 -- get the current value of the Air Quality sensor
local ozone = domoticz.devices('Ozon-Index') -- virtual sensor of the type "Alert"
local ozon = domoticz.devices('Ozon') -- virtual sensor of the type "Custom Sensor"
local prevo3 = tonumber(ozon.rawData[1])
if (triggerItem.isTimer) then
domoticz.openURL({
url = 'http://api.waqi.info/feed/geo:'..lat..';'..long..'/?token='..apikey,
method = 'GET',
callback = 'waqi'
elseif (triggerItem.isHTTPResponse) then
local response = triggerItem
if (response.ok and response.isJSON) then
-- print('CalidAireV2 triggered by Callback')
local aqius = tonumber(response.json.data.aqi) -- combined air quality
local dom = tostring(response.json.data.dominentpol) -- shows the dominant polutor
local colevel = tonumber(response.json.data.iaqi.co.v) -- level of CO
local no2 = tonumber(response.json.data.iaqi.no2.v) -- level of NO2
local o3 = tonumber(response.json.data.iaqi.o3.v) -- level of Ozone
local so2 = tonumber(response.json.data.iaqi.so2.v) -- level of SO2
local pm10 = tonumber(response.json.data.iaqi.pm10.v) -- partical matter of particles < 10µm
local pm25 = tonumber(response.json.data.iaqi.pm25.v) -- partical matter of particles < 2.5µm
if aqius ~= nil then --and aqius ~= prevAirC
AirC.updateAirQuality(aqius)
ozon.updateCustomSensor(o3) -- write the numerical value to the custom sensor
-- get the alert level. Based on info from:
-- https://en.wikipedia.org/wiki/Air_quality_index
if o3 ~= prevo3 then -- before updating the sensor check if the value has changed (in order to avoid unneeded updating, and
-- flooding the log
local o3n = tonumber(o3)
if o3n <= 100 then level = domoticz.ALERTLEVEL_GREEN; nfo = "Excellent"
elseif o3n > 100 and o3n <= 168 then level = domoticz.ALERTLEVEL_YELLOW; nfo = "Polluted"
elseif o3n > 168 and o3n <= 208 then level = domoticz.ALERTLEVEL_ORANGE; nfo = "Poor"
elseif o3n > 208 then level = domoticz.ALERTLEVEL_RED; nfo = "Alarming"
ozone.updateAlertSensor(level, 'nfo') -- if you want just on sensor with alert level and value (as text) replace nfo with o3
print('**CalidAireV2 failed to fetch info')
Re: Get online airquality data
Posted: Friday 27 July 2018 21:41
by capman
I have used this script but have this error in the log.
Status: dzVents: Error (2.4.7): ...var/scripts/dzVents/generated_scripts/Luchtkwaliteit.lua:40: attempt to index field 'co' (a nil value)
Someone now where the error is ? I use latest beta on synology. Dzvents version 2.4.7
Posted: Friday 27 July 2018 22:02
by elmortero
if you paste the URL in a browser with your data do you get a json result?
replace X,Y and Z
http://api.waqi.info/feed/geo:XXXX;YYYY/?token=ZZZZZ
If you get result, is there a value for co ?
Posted: Friday 27 July 2018 22:03
by waaren
capman wrote: Friday 27 July 2018 21:41
The error is that the response data does not contain a value for co and the script does not check for that.
Good part is that this value is not used elsewhere in the script so you can do a couple of things to prevent the error stopping the script execution.
put -- at the start of line 40 to make it a comment line
or
delete line 40
or
build in a check like
if response.json.data.iaqi.co ~= nil and response.json.data.iaqi.co ~= nil then
print('**CalidAireV2 failed to fetch co info')
local colevel = 0
Posted: Friday 27 July 2018 22:14
by waaren
Just checked but value for co is not there
"status": "ok",
"data": {
"aqi": 72,
"idx": 5284,
"attributions": [
"url": "http://www.luchtmeetnet.nl/",
"name": "RIVM - Rijksinstituut voor Volksgezondheid en Milieum, Landelijk Meetnet Luchtkwaliteit"
"city": {
"geo": [
xx.89361,
y.48759
"name": "xxxxxxxxx, Rotterdam Zuid",
"url": "http://aqicn.org/city/netherland/rotterdam-zuid/xxxxxxxx/"
"dominentpol": "o3",
"iaqi": {
"no2": {
"v": 10.9
"o3": {
"v": 72
"p": {
"v": 1007.1
"pm10": {
"v": 18
"pm25": {
"v": 45
"t": {
"v": 31.9
"w": {
"v": 5.5
"wg": {
"v": 8.5
"time": {
"s": "2018-07-27 20:00:00",
"tz": "+01:00",
"v": 1532721600
Posted: Friday 27 July 2018 22:22
by elmortero
For my location it is..
But your previous comment is correct, the data is not used in the script.
In fact, anything else than the general AQI index and ozone is unused. I added that to fetch all values for them to be available.
The idea was to read the dominant polutor and then use the value of that one. But that value is already in the aqius variable.
The lines that populate dom, colevel, no2, so2, pm10 and pm25 can be removed from the script.
Posted: Saturday 28 July 2018 8:24
by EdwinK
So, with the output from
http://api.waqi.info/feed/geo:51.860069 ... ?token=API I could those readings in other alerts? What do I need to change in this script to view those?
Posted: Saturday 28 July 2018 10:19
by waaren
@EdwinK,
there are many ways to do that but if you want to be able to look at the values of the other polluters over time in a domoticz graph you could
add for every value that you want to show a virtual device with type "Custom sensor" and change the line
in the script with this code snippet
local coDevice = domoticz.devices('co') -- virtual sensor of the type "Custom Sensor"
co.updateCustomSensor(tonumber(response.json.data.iaqi.co.v))
and do this for all polluters of which you want to store the values in a virtual sensor.
Posted: Saturday 28 July 2018 10:22
by capman
I have also no 'co' output. This is the result.
"status":"ok",
"data":{
"aqi":57,
"idx":8903,
"attributions":[
"url":"http://www.irceline.be/en/",
"name":"IRCEL-CELINE - Belgian Interregional Environment Agency"}],
"city":{"geo":[xxxxxxxx,yyyyyyyy],
"name":"xxxxxxxxxx",
"url":"http://aqicn.org/city/belgium/fla/xxxxxxxxx/"},
"dominentpol":"pm25",
"iaqi":{"h":{"v":91.2},
"no2":{"v":8.7},
"p":{"v":1006.9},
"pm10":{"v":20},
"pm25":{"v":57},
"t":{"v":21.2},
"w":{"v":3.5}},
"time":{"s":"2018-07-28 09:00:00",
"tz":"+01:00","v":1532768400}}}
But i have also no '03' output that you use for the ozon. Maybe it's another value ? Or I can't use the script
Posted: Saturday 28 July 2018 10:42
by capman
But on the site I have this.
- airquality.JPG (155.38 KiB) Viewed 7568 times
Maybe I can also use it as temp , wind, humidity , pressure sensor in place of WU.
The other values means.
PM2.5 = Fine particulate matter
PM10 = Respirable particulate matter
NO2 = Nitrogen dioxide
On the bottom you have the forecast calendar , and there is a ozone row.
Maybe the PM10 I can use, because this is not healthy when it's to high
Posted: Saturday 28 July 2018 11:03
by waaren
capman wrote: Saturday 28 July 2018 10:22
I have also no 'co' output. ... But i have also no '03' output that you use for the ozon. Maybe it's another value ? Or I can't use the script
The station closest to your lat / long setting does not measure O3. The nearest station for you that does measure O3 is Schoten.
If you use
http://api.waqi.info/feed/geo:51.25;4.5 ... =xxxxxxxxx
you will get info from that station
Posted: Saturday 28 July 2018 11:09
by capman
I give this a try , just to test the script. Thanks.
Posted: Saturday 28 July 2018 11:14
by elmortero
waaren wrote: Saturday 28 July 2018 11:03
Indeed, according to this site
http://www.vmm.be/data/ozon-actuele-waa ... hrijdingen Schoten is your nearest station that provides Ozone info.
(Waaren is way faster in his replies than I am
Posted: Saturday 28 July 2018 11:22
by capman
I think that I just moving then to Schoten
BTW , the script is working when I use the lat and lon for Schoten
- working.JPG (37.72 KiB) Viewed 7551 times
I gone try to edit the script for the PM10 value. This is also some importing value for the air quality.
Posted: Saturday 28 July 2018 11:35
by elmortero
capman wrote: Saturday 28 July 2018 11:22
The script already gets that value, you just need to create a sensor and update it with the value that is stored in the variable pm25
Posted: Saturday 28 July 2018 12:13
by capman
But I need to change this also ? Because you're using values for the ozone (o3) and not for the respirable particulate matter (pm10).
I only gone use the pm10 value.
-- flooding the log
Posted: Saturday 28 July 2018 12:30
by elmortero
capman wrote: Saturday 28 July 2018 12:13
This line (if you copied it from the original script) fetches the PM10 value:
Create a Custom sensor, like the one you have created for Ozon
for example : local PM10sensor = domoticz.devices('PM10') -- virtual sensor of the type "Custom Sensor"
Then add this to your script (somewhere after the line I just quoted)
if pm10 ~= nil then
PM10sensor.updateCustomSensor(pm10)
Posted: Saturday 28 July 2018 12:55
by EdwinK
waaren wrote: Saturday 28 July 2018 10:19
@EdwinK,
I think I better wait till someone more smarter with scripting has done this
Posted: Saturday 28 July 2018 12:58
by elmortero
EdwinK wrote: Saturday 28 July 2018 12:55
Do you want it to be for PM10 only?
Posted: Saturday 28 July 2018 13:21
by elmortero
For PM10 only (with alert sensor):
httpResponses = { 'PM10' } -- matches callback string below
local PM10sensor = domoticz.devices('PM10') -- virtual sensor of the type "Custom sensor"
local prevPM10 = PM10sensor.rawData[1] -- get the current value of the Alert
local pmalert = domoticz.devices('PM10-Alert')
domoticz.openURL({
method = 'GET',
callback = 'PM10'
if pm10 ~= nil and pm10 ~= prevPM10 then
if pm10 ~= prevpm10 then -- before updating the sensor check if the value has changed (in order to avoid unneeded updating,
if pm10 <= 100 then level = domoticz.ALERTLEVEL_GREEN; nfo = "Good"
elseif pm10 > 100 and pm10 <= 200 then level = domoticz.ALERTLEVEL_YELLOW; nfo = "Polluted"
elseif pm10 > 200 and pm10 <= 300 then level = domoticz.ALERTLEVEL_ORANGE; nfo = "Very Polluted"
elseif pm10 > 300 then level = domoticz.ALERTLEVEL_RED; nfo = "Alarming"
pmalert.updateAlertSensor(level, nfo) -- if you want just on sensor with alert level and value (as text) replace nfo with o3
print('**PM10failed to fetch info')
