HTTPRespons and json and Hue
Posted: Sunday 04 February 2018 15:03
by Maxx
Hello All,
Taking it one small step further..
I am trying to get the Hue light status directly fom the Hue bridge. (Status in Domoticz is not updated when the light is offline)
I use the following script. (based on the dzvents template)
		timer = {
			'every minute' -- just an example to trigger the request
		httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://192.168.1.105/api/[i]username[/i]/lights/4',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
			domoticz.log('Timer event')
		if (item.isHTTPResponse) then
			if (item.statusCode == 200) then
				if (item.isJSON) then
                    domoticz.log('JSON was detected')
                    local someValue = item.json.name
					-- update some device in Domoticz
					domoticz.devices('Tekst').updateText(someValue)
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
When I run the script I do not get error mesages nor any of the logmessages I put in the script. I suspect the HTTPResponse is not ok.
The URL in the browser gives the following result:
  "state": {
    "on": false,
    "bri": 51,
    "alert": "none",
    "mode": "homeautomation",
    "reachable": true
  "swupdate": {
    "state": "noupdates",
    "lastinstall": "2017-11-14T19:35:13"
  "type": "Dimmable light",
  "name": "Veranda 2",
  "modelid": "LWB010",
  "manufacturername": "Philips",
  "capabilities": {
    "streaming": {
      "renderer": false,
      "proxy": false
  "uniqueid": "00:17:88:01:02:b0:10:91-0b",
  "swversion": "1.29.0_r21169",
  "swconfigid": "C40F3F07",
  "productid": "Philips-LWB010-1-A19DLv3"
In the Wiki there is a dzvents script "Simple_script_to_update_Philips_Hue_status" but I think with the new dzvents version I should be to use the HTTPResponse and openURL option.
Thanks in advance
Re: HTTPRespons and json and Hue
Posted: Sunday 04 February 2018 19:25
by Maxx
Update:
Item is returning with HTTPResonse = 200 so that is ok.
In the errorlog the following error occurs:
(2.4.1): ...omoticz/scripts/dzVents/generated_scripts/Hue status.lua:28: attempt to index field 'json' (a nil value)
When I check json of Domoticz this works fine ( see previous tread "HTTPRespons and json")
Can somebody help me out here?
Posted: Thursday 08 February 2018 7:50
by dannybloe
Interesting.. looks like parsing of the response data didn't result in any json code. Try:
domoticz.log(item.data)
domoticz.log(item.headers)
domoticz.log(domoticz.utils.fromJSON(item.data))
When I feed your json sample above to the json parser I do get a nice Lua table in return.
Posted: Friday 09 February 2018 17:05
by Maxx
Hello
I did the following:
{["Date"]="Fri, 09 Feb 2018 15:51:00 GMT", ["Access-Control-Max-Age"]="3600", ["Pragma"]="no-cache", ["Cache-Control"]="no-store, no-cache, must-revalidate, post-check=0, pre-check=0", ["Expires"]="Mon, 1 Aug 2011 09:00:00 GMT", ["Content-Type"]="application/json", ["Access-Control-Allow-Origin"]="*", ["Connection"]="close", ["Access-Control-Allow-Headers"]="Content-Type", ["Access-Control-Allow-Credentials"]="true", ["Access-Control-Allow-Methods"]="POST, GET, OPTIONS, PUT, DELETE, HEAD", ["Server"]="nginx"
        domoticz.log(item.statusCode)
returns 200
{"lights":{"4":{"state":{"on":false,"bri":51,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:35:13"},"type":"Dimmable light","name":"Veranda 2","modelid":"LWB010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":false,"proxy":false}},"uniqueid":"00:17:88:01:02:b0:10:91-0b","swversion":"1.29.0_r21169","swconfigid":"C40F3F07","productid":"Philips-LWB010-1-A19DLv3"},"6":{"state":{"on":true,"bri":92,"hue":62095,"sat":118,"effect":"none","xy":[0.4782,0.3224],"ct":399,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:34:30"},"type":"Extended color light","name":"Zithoek","modelid":"LCT010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":true,"proxy":true}},"uniqueid":"00:17:88:01:02:96:22:52-0b","swversion":"1.29.0_r21169","swconfigid":"6A139B19","productid":"Philips-LCT010-1-A19ECLv4"},"7":{"state":{"on":false,"bri":51,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:34:32"},"type":"Dimmable light","name":"Veranda 1","modelid":"LWB010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":false,"proxy":false}},"uniqueid":"00:17:88:01:02:b0:0f:32-0b","swversion":"1.29.0_r21169","swconfigid":"C40F3F07","productid":"Philips-LWB010-1-A19DLv3"},"8":{"state":{"on":true,"bri":91,"hue":40414,"sat":65,"effect":"none","xy":[0.3236,0.3445],"ct":167,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:35:32"},"type":"Extended color light","name":"Eethoek 2","modelid":"LCT010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":true,"proxy":true}},"uniqueid":"00:17:88:01:02:92:13:80-0b","swversion":"1.29.0_r21169","swconfigid":"6A139B19","productid":"Philips-LCT010-1-A19ECLv4"},"9":{"state":{"on":true,"bri":91,"hue":40411,"sat":65,"effect":"none","xy":[0.3236,0.3445],"ct":167,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:34:46"},"type":"Extended color light","name":"Eethoek 1","modelid":"LCT010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":true,"proxy":true}},"uniqueid":"00:17:88:01:02:82:9a:c5-0b","swversion":"1.29.0_r21169","swconfigid":"6A139B19","productid":"Philips-LCT010-1-A19ECLv4"},"10":{"state":{"on":true,"bri":88,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:35:07"},"type":"Dimmable light","name":"Overloop","modelid":"LWB010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":false,"proxy":false}},"uniqueid":"00:17:88:01:02:4a:17:7f-0b","swversion":"1.29.0_r21169","swconfigid":"C40F3F07","productid":"Philips-LWB010-1-A19DLv3"},"11":{"state":{"on":true,"bri":92,"hue":41103,"sat":58,"effect":"none","xy":[0.3296,0.3432],"ct":176,"alert":"none","colormode":"xy","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:34:35"},"type":"Extended color light","name":"Piano","modelid":"LCT012","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":true,"proxy":true}},"uniqueid":"00:17:88:01:02:85:44:11-0b","swversion":"1.29.0_r21169","swconfigid":"EA9279F9","productid":"Philips-LCT012-1-E14ECLv1"},"12":{"state":{"on":false,"bri":254,"hue":7688,"sat":199,"effect":"none","xy":[0.5014,0.4153],"ct":447,"alert":"none","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:34:38"},"type":"Extended color light","name":"Marieke","modelid":"LCT012","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":true,"proxy":true}},"uniqueid":"00:17:88:01:02:85:46:98-0b","swversion":"1.29.0_r21169","swconfigid":"EA9279F9","productid":"Philips-LCT012-1-E14ECLv1"},"13":{"state":{"on":true,"bri":90,"ct":269,"alert":"none","colormode":"ct","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:35:18"},"type":"Color temperature light","name":"Keuken","modelid":"LTW001","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":false,"proxy":false}},"uniqueid":"00:17:88:01:02:37:6c:45-0b","swversion":"5.105.0.21536"},"14":{"state":{"on":false,"bri":254,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:34:51"},"type":"Dimmable light","name":"Lantaarnpaal 1","modelid":"LWB010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":false,"proxy":false}},"uniqueid":"00:17:88:01:02:b0:0f:41-0b","swversion":"1.29.0_r21169","swconfigid":"C40F3F07","productid":"Philips-LWB010-1-A19DLv3"},"15":{"state":{"on":false,"bri":254,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:34:57"},"type":"Dimmable light","name":"Lantaarnpaal 2","modelid":"LWB010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":false,"proxy":false}},"uniqueid":"00:17:88:01:02:b1:76:d6-0b","swversion":"1.29.0_r21169","swconfigid":"C40F3F07","productid":"Philips-LWB010-1-A19DLv3"},"16":{"state":{"on":false,"bri":254,"alert":"none","mode":"homeautomation","reachable":true},"swupdate":{"state":"noupdates","lastinstall":"2017-11-14T19:35:02"},"type":"Dimmable light","name":"Lantaarnpaal 3","modelid":"LWB010","manufacturername":"Philips","capabilities":{"certified":true,"streaming":{"renderer":false,"proxy":false}},"uniqueid":"00:17:88:01:02:48:b2:c1-0b","swversion":"1.29.0_r21169","swconfigid":"C40F3F07","productid":"Philips-LWB010-1-A19DLv3"},"17":{"state":{"on":false,"bri":246,"hue":64131,"sat":125,"effect":"none","xy":[0.5133,0.3333],"ct":467,"alert":"none","colormode":"xy","mode":"ho
{["lights"]={["4"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=false, ["proxy"]=false}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:35:13", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="C40F3F07", ["type"]="Dimmable light", ["state"]={["on"]=false, ["mode"]="homeautomation", ["bri"]=51, ["reachable"]=true, ["alert"]="none"}, ["modelid"]="LWB010", ["productid"]="Philips-LWB010-1-A19DLv3", ["name"]="Veranda 2", ["uniqueid"]="00:17:88:01:02:b0:10:91-0b"}, ["10"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=false, ["proxy"]=false}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:35:07", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="C40F3F07", ["type"]="Dimmable light", ["state"]={["on"]=true, ["mode"]="homeautomation", ["bri"]=151, ["reachable"]=true, ["alert"]="none"}, ["modelid"]="LWB010", ["productid"]="Philips-LWB010-1-A19DLv3", ["name"]="Overloop", ["uniqueid"]="00:17:88:01:02:4a:17:7f-0b"}, ["17"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=true, ["proxy"]=true}}, ["swupdate"]={["lastinstall"]="2017-12-17T01:09:23", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="3416C2DD", ["type"]="Extended color light", ["state"]={["effect"]="none", ["sat"]=125, ["mode"]="homeautomation", ["ct"]=467, ["bri"]=246, ["alert"]="none", ["xy"]={0.5133, 0.3333}, ["hue"]=64131, ["reachable"]=true, ["colormode"]="xy", ["on"]=false}, ["modelid"]="LCT015", ["productid"]="Philips-LCT015-1-A19ECLv5", ["name"]="Naomi", ["uniqueid"]="00:17:88:01:03:fa:ec:12-0b"}, ["12"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=true, ["proxy"]=true}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:34:38", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="EA9279F9", ["type"]="Extended color light", ["state"]={["effect"]="none", ["sat"]=199, ["mode"]="homeautomation", ["ct"]=447, ["bri"]=254, ["alert"]="none", ["xy"]={0.5014, 0.4153}, ["hue"]=7688, ["reachable"]=true, ["colormode"]="ct", ["on"]=false}, ["modelid"]="LCT012", ["productid"]="Philips-LCT012-1-E14ECLv1", ["name"]="Marieke", ["uniqueid"]="00:17:88:01:02:85:46:98-0b"}, ["11"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=true, ["proxy"]=true}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:34:35", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="EA9279F9", ["type"]="Extended color light", ["state"]={["effect"]="none", ["sat"]=64, ["mode"]="homeautomation", ["ct"]=170, ["bri"]=150, ["alert"]="none", ["xy"]={0.3243, 0.3388}, ["hue"]=41225, ["reachable"]=true, ["colormode"]="xy", ["on"]=true}, ["modelid"]="LCT012", ["productid"]="Philips-LCT012-1-E14ECLv1", ["name"]="Piano", ["uniqueid"]="00:17:88:01:02:85:44:11-0b"}, ["14"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=false, ["proxy"]=false}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:34:51", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="C40F3F07", ["type"]="Dimmable light", ["state"]={["on"]=false, ["mode"]="homeautomation", ["bri"]=254, ["reachable"]=true, ["alert"]="none"}, ["modelid"]="LWB010", ["productid"]="Philips-LWB010-1-A19DLv3", ["name"]="Lantaarnpaal 1", ["uniqueid"]="00:17:88:01:02:b0:0f:41-0b"}, ["13"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=false, ["proxy"]=false}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:35:18", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="5.105.0.21536", ["type"]="Color temperature light", ["state"]={["on"]=true, ["mode"]="homeautomation", ["reachable"]=true, ["ct"]=254, ["bri"]=152, ["colormode"]="ct", ["alert"]="none"}, ["modelid"]="LTW001", ["name"]="Keuken", ["uniqueid"]="00:17:88:01:02:37:6c:45-0b"}, ["16"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=false, ["proxy"]=false}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:35:02", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="C40F3F07", ["type"]="Dimmable light", ["state"]={["on"]=false, ["mode"]="homeautomation", ["bri"]=254, ["reachable"]=true, ["alert"]="none"}, ["modelid"]="LWB010", ["productid"]="Philips-LWB010-1-A19DLv3", ["name"]="Lantaarnpaal 3", ["uniqueid"]="00:17:88:01:02:48:b2:c1-0b"}, ["9"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=true, ["proxy"]=true}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:34:46", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="6A139B19", ["type"]="Extended color light", ["state"]={["effect"]="none", ["sat"]=68, ["mode"]="homeautomation", ["ct"]=165, ["bri"]=152, ["alert"]="none", ["xy"]={0.3209, 0.34}, ["hue"]=40784, ["reachable"]=true, ["colormode"]="xy", ["on"]=true}, ["modelid"]="LCT010", ["productid"]="Philips-LCT010-1-A19ECLv4", ["name"]="Eethoek 1", ["uniqueid"]="00:17:88:01:02:82:9a:c5-0b"}, ["8"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=true, ["proxy"]=true}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:35:32", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="6A139B19", ["type"]="Extended color light", ["state"]={["effect"]="none", ["sat"]=68, ["mode"]="homeautomation", ["ct"]=165, ["bri"]=150, ["alert"]="none", ["xy"]={0.3209, 0.34}, ["hue"]=40785, ["reachable"]=true, ["colormode"]="xy", ["on"]=true}, ["modelid"]="LCT010", ["productid"]="Philips-LCT010-1-A19ECLv4", ["name"]="Eethoek 2", ["uniqueid"]="00:17:88:01:02:92:13:80-0b"}, ["7"]={["capabilities"]={["certified"]=true, ["streaming"]={["renderer"]=false, ["proxy"]=false}}, ["swupdate"]={["lastinstall"]="2017-11-14T19:34:32", ["state"]="noupdates"}, ["manufacturername"]="Philips", ["swversion"]="1.29.0_r21169", ["swconfigid"]="C40F3F07", ["type"]="Dimmable light", ["state"]={["on"]=false, ["mode"]="homeautoma
and
 2018-02-09 17:01:01.489 dzVents: Error (2.4.1): An error occured when calling event handler Hue status
2018-02-09 17:01:01.489 dzVents: Error (2.4.1): ...omoticz/scripts/dzVents/generated_scripts/Hue status.lua:31: attempt to index field '?' (a nil value)
The json result code returns negative.
When I try the json calls:
				url = 'http://192.168.1.105/api/xigTvboKxxxxXyp4gUzDLNKIXpUViF',
Hue
or
			url = 'http://192.168.1.231:8080/json.htm?type=devices&rid=582',
KAKU temp sensor
The result on the firefox browser is different
Posted: Friday 09 February 2018 17:17
by dannybloe
Clearly domoticz.utils.fromJSON(item.data) is returning a proper Lua table. And the domoticz log doesn't print the entire data chunk as it is too large for the log. But I don't understand what you try to say in the last part of your post (the last three code blocks). And your json dump is totally different from your initial expected dump. So your info doesn't help me very much here.
Posted: Friday 09 February 2018 18:47
by Maxx
Hello Danny,
I realise I was not clear.
Bottomline is that a json call to Hue returns isJson as false and when I do the json to a kaku temp device, it works.
While trying to look for the cause I noticed that the headers are different (doing the URL call in the Firefox browser):
For Hue
Access-Control-Allow-Credentials	true
Access-Control-Allow-Headers	Content-Type
Access-Control-Allow-Methods	POST, GET, OPTIONS, PUT, DELETE, HEAD
Access-Control-Allow-Origin	*
Access-Control-Max-Age	3600
Cache-Control	no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Connection	close
Content-Type	application/json
Date	Fri, 09 Feb 2018 17:33:09 GMT
Expires	Mon, 1 Aug 2011 09:00:00 GMT
Pragma	no-cache
Server	nginx
For Kaku:
Cache-Control	no-cache
Connection	Keep-Alive
Content-Encoding	gzip
Content-Length	635
Content-Type	application/json;charset=UTF-8
Keep-Alive	max=20, timeout=20
Pragma	no-cache
Also the "onbewerkte gegevens" in Firefox look different.
When I force the json to Hue from dzvents (bypassing the condition isJson ) it returns an error:
Not sure if this points to the problem but I hope this makes my problem clearer
Posted: Saturday 10 February 2018 13:50
by dannybloe
Can you PM me your script code, both the http requests and both the response headers with the complete response data (copy it from Chrome's network tab).
Posted: Tuesday 14 August 2018 11:08
by kimhav
Just out of curiosity, as I was looking at the same thing here myself on how to handle the status when a Hue unit goes offline, will this script be included in future betas? Since it would be great to ensure that Domoticz keeps track whether a device is offline or not to block the user from turning on if it won't respond to it.
Posted: Thursday 16 August 2018 20:03
by Maxx
I use the following script to get the status of my Hue lights:
local light_ID = ''
		timer = {
			'every 5 minutes'
		httpResponses = {
			'Light_Callback'
			domoticz.openURL({
				url = 'http://192.168.1.161/api/xigTvboK2fVo6lUViF/lights',
				method = 'GET',
				callback = 'Light_Callback',
            domoticz.log('HTTP reponse was ok')
			if (item.statusCode == 200) and (item.isJSON) then
                    for light_no=4,17,1 do
                        light_ID = tostring(light_no)
                            local Bereikbaar = item.json[light_ID]['state']['reachable']
                            local Naam = item.json[light_ID]['name']
                            if Bereikbaar == false then
                                domoticz.log('---------Lamp ' .. Naam .. ' onbereikbaar---------')
                            elseif Bereikbaar == true then
                               domoticz.log('++++++++Lamp ' .. Naam .. ' bereikbaar+++++++++')
This works fine and you can use the output to feedback the real status to Domoticz, I didn't try this yet.
Posted: Wednesday 19 September 2018 12:18
by Ascari
@Maxx
I try to use your scrip but it's not working for me
IsJson = false
Can you help me ?
Posted: Wednesday 19 September 2018 12:59
by waaren
Ascari wrote: Wednesday 19 September 2018 12:18 I try to use your scrip but it's not working for me
IsJson = false
Can you help me ?
What do you see if you enter http://192.168.1.161/api/xigTvboK2fVo6lUViF/lights in your browser ?
Posted: Wednesday 19 September 2018 13:21
by Ascari
I see :
{"1":{"state":{"on":true,"bri":20,"hue":14910,"sat":144,"effect":"none","xy":[0.4596,0.4105],"ct":369,"alert":"none","colormode":"ct","reachable":false},"type":"Extended color light","name":"Living1","modelid":"LCT001","manufacturername":"Philips","uniqueid":"00:17:88:01:00:d3:3e:01-0b","swversion":"5.23.1.13452"},"2":{"state":{"on":true,"bri":20,"hue":14910,"sat":144,"effect":"none","xy":[0.4596,0.4105],"ct":369,"alert":"none","colormode":"ct","reachable":false},"type":"Extended color light","name":"Living2","modelid":"LCT001","manufacturername":"Philips","uniqueid":"00:17:88:01:00:d3:39:8f-0b","swversion":"5.23.1.13452"},"3":{"state":{"on":true,"bri":20,"hue":14910,"sat":144,"effect":"none","xy":[0.4596,0.4105],"ct":369,"alert":"none","colormode":"ct","reachable":false},"type":"Extended color light","name":"Living3","modelid":"LCT001","manufacturername":"Philips","uniqueid":"00:17:88:01:00:ff:c0:4f-0b","swversion":"5.23.1.13452"},"4":{"state":{"on":true,"bri":254,"hue":14910,"sat":144,"effect":"none","xy":[0.4596,0.4105],"ct":369,"alert":"none","colormode":"ct","reachable":false},"type":"Extended color light","name":"Salon","modelid":"LCT001","manufacturername":"Philips","uniqueid":"00:17:88:01:00:d3:38:e5-0b","swversion":"5.23.1.13452"},"5":{"state":{"on":false,"bri":20,"hue":6682,"sat":254,"effect":"none","xy":[0.6290,0.3642],"alert":"none","colormode":"hs","reachable":true},"type":"Color light","name":"Meuble","modelid":"LST001","manufacturername":"Philips","uniqueid":"00:17:88:01:00:cd:a8:11-0b","swversion":"5.23.1.13452"},"6":{"state":{"on":false,"bri":254,"alert":"none","reachable":true},"type":"Dimmable light","name":"Boule","modelid":"LWB004","manufacturername":"Philips","uniqueid":"00:17:88:01:00:de:54:0c-0b","swversion":"5.38.2.19136"},"7":{"state":{"on":true,"bri":254,"alert":"none","reachable":false},"type":"Dimmable light","name":"Milo","modelid":"LWB004","manufacturername":"Philips","uniqueid":"00:17:88:01:00:de:48:f1-0b","swversion":"5.38.2.19136"},"8":{"state":{"on":false,"bri":186,"alert":"none","reachable":false},"type":"Dimmable light","name":"Chambre","modelid":"LWB004","manufacturername":"Philips","uniqueid":"00:17:88:01:00:de:57:6d-0b","swversion":"5.38.2.19136"}}
But in the logs Domoticz
["statusCode"]=200,
["isJSON"]=false,
Posted: Wednesday 19 September 2018 17:12
by Maxx
Looking at the respons in your browser you are using your own IP adres and username, which is good
Can you check the header of the json, it should be something like:
Connection	close
Date	Wed, 19 Sep 2018 15:06:06 GMT
Pragma	no-cache
Server	nginx
Posted: Wednesday 19 September 2018 22:04
by Ascari
Strange because Firefoc say it's JSON
Connection close
Content-type application/json
Pragma no-cache
Accept text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Encoding gzip, deflate
Accept-Language fr,fr-FR;q=0.8,en-US;q=0.5,en;q=0.3
Connection keep-alive
Host 192.168.0.243
Upgrade-Insecure-Requests 1
User-Agent Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:62.0) Gecko/20100101 Firefox/62.0
Posted: Thursday 20 September 2018 1:10
by waaren
Ascari wrote: Wednesday 19 September 2018 12:18 ...
IsJson = false
Can you change the line
into
if item.ok and item.isJSON then
and check if that makes any difference? It worked for me but I have to admit that I have not figured out why :D
Posted: Thursday 20 September 2018 9:29
by Ascari
I have an error also
2018-09-20 09:29:00.387 Status: dzVents: Error (2.4.7): There was a problem handling the request
2018-09-20 09:29:00.387 Status: dzVents: Error (2.4.7): {["trigger"]="Light_Callback", ["callback"]="Light_Callback", ["isSecurity"]=false, ["_contentType"]="", ["isDevice"]=false, ["ok"]=true, ["isTimer"]=false, ["isGroup"]=false, ["statusCode"]=200, ["isVariable"]=false, ["baseType"]="httpResponse", ["headers"]={["Cache-Control"]="no-store, no-cache, must-revalidate, post-check=0, pre-check=0", ["Access-Control-Allow-Headers"]="Content-Type", ["Content-type"]="application/json", ["Access-Control-Max-Age"]="3600", ["Access-Control-Allow-Methods"]="POST, GET, OPTIONS, PUT, DELETE, HEAD", ["Connection"]="close", ["Expires"]="Mon, 1 Aug 2011 09:00:00 GMT", ["Pragma"]="no-cache", ["Access-Control-Allow-Credentials"]="true", ["Access-Control-Allow-Origin"]="*"}, ["isScene"]=false, ["isHTTPResponse"]=true, ["data"]="{"state":{"on":true,"bri":8,"hue":14910,"sat":144,"effect":"none","xy":[0.4596,0.4105],"ct":369,"alert":"none","colormode":"ct","reachable":false},"type":"Extended color light","name":"Living1","modelid":"LCT001","manufacturername":"Philips","uniqueid":"00:17:88:01:00:d3:3e:01-0b","swversion":"5.23.1.13452"}", ["isJSON"]=false}
2018-09-20 09:29:00.387 Status: dzVents: Info: ------ Finished 00YT
Posted: Thursday 20 September 2018 11:00
by waaren
Ascari wrote: Thursday 20 September 2018 9:29 I have an error also
You could try with a brute force approach..
replace the code lines
with
domoticz.log('HTTP reponse statusCode: '  .. item.statusCode )
if item.ok then
  item.json = domoticz.utils.fromJSON(item.data)  -- Forcing dzVents to handle data as JSON
Posted: Thursday 20 September 2018 12:06
by Ascari
Not working error also.
I'm working to a another script (parcer) and it's work to receive the reachable status.
Now I look to do a loop and clean code.
When ok I send the code
Posted: Saturday 22 September 2018 10:27
by Ascari
Hello
I try to make the same with Lua code.
I can parse the Json but I again a issue with the "While" only the last true condition update the hueStatus (strange).
When I find a solution for this, I want to add a check (if the statut is not already on OFF, to avaid udpate useless)
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Linux
-- Tableau Hue/Domotiz Exemple Idlamp Hue1 = idz108
lamp = {1,2,3,4,5,6,7,8} --Put your Hue lamp ID here
device = {108,109,110,111,112,113,114,115} --Put your Domotiz ID here
nblamp = 8 --Put here nbr lamp you want check
i = 1
while i <= nblamp
do
	huelightid=lamp[i]
	domohueid=device[i]
	idjson = tostring(huelightid)
	urlid = tostring(domohueid)
			--  API call
	local config=assert(io.popen('curl "http://IPHue/api/UserHue/lights/'..idjson..'"')) -- change Iphue and login hue
	local Stringjson = config:read('*all')
	config:close()
	local jsonData = json:decode(Stringjson)
	lampe = jsonData.name
	reachable = jsonData.state.reachable
			-- print (Stringjson)  -- debug json
	reachable = tostring(reachable)
			-- print('Hue Reachable Log: '..reachable..lampe) -- Test value for Debuging.
	if reachable == "false"
		then
		commandArray['OpenURL']='http://domoticzip:port/json.htm?type=command&param=switchlight&idx='..urlid..'&switchcmd=Off' -- Changedomoticzip and port
		print ('url : '..urlid) -- Log Debug Help
i = i + 1
Code ok here with the help of Waaren :
TODO : CHECK (if the statut is not already on OFF, to avoid udpate useless)
i = 1
while i <= nblamp
do
	huelightid=lamp[i]
	domohueid=device[i]
			--  API call
	local config=assert(io.popen('curl "http://iphue/api/userloginhue/lights/'..idjson..'"'))
	config:close()
		then
        --print ('url : '..urlid) -- Log Debug Help
		-- Thx Waaren
        commandArray[#commandArray+1] = {['OpenURL']='http://ipdomo:port/json.htm?type=command&param=switchlight&idx='..urlid..'&switchcmd=Off'}
i = i + 1
Posted: Saturday 22 September 2018 13:55
by Ascari
I have finish my code LUA and thx Waaren for help.
Here the code.
To use you need to adpat
IP/port Domoticz
IP Hue bridge and login
the two table (lamp & device)
Hope can help other user.
-- Script : Auto OFF Hue if Unreachable
-- Auteur : Vincent Arancio
-- Date : 22/09/2018
-- Version : Preproduction Error
-- TODO : Set HavetimeOut var in true (Blink red on dashboard)
i = 1
while i <= nblamp
do
	huelightid=lamp[i]
	domohueid=device[i]
	--  API call
	local config=assert(io.popen('curl "http://iphue/api/HueLoginDev/lights/'..idjson..'"'))
	config:close()
		then
		local configs=assert(io.popen('curl "http://ipdomo:port/json.htm?type=devices&rid='..urlid..'"'))
		local Stringjson2 = configs:read('*all')
		configs:close()
		local DeviceData = json:decode(Stringjson2)
		--print ('ici encore1'..Stringjson2) -- Debug log
		Statusoff = DeviceData.result[1].Status
		-- print ('ici encore'..Statusoff) -- Debug log
		if Statusoff ~= "Off"
			then
i = i + 1
