Unable to execute batch file with spaces in arguments
quack3d
Post by quack3d »
I'm running Domoticz in Windows and try the following code to send Pushbullet notification to multiple users:
    local title = 'this '
    local message = 'works'
    local tit_msg = title..message
    local path = [["C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat" ]]
    local combined = path..tit_msg
    os.execute(combined)
prints will show this: LUA: "C:\Program Files (x86)\Domoticz\scripts\bash\pushbullet.bat" this works
    local title2 = '"this does" '
    local message2 = '"not"'
    local tit_msg2 = title2..message2
    local path2 = [[& 'C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat' ]]
    local combined2 = path2..tit_msg2
    os.execute(combined2)
print will show this: LUA: & 'C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat' "this does" "not"
    local title3 = [['"this does" ]]
    local message3 = [["not"']]
    local tit_msg3 = title3..message3
    local path3 = [["C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat" ]]
    local combined3 = path3..tit_msg3
    os.execute(combined3)
print will show this: LUA: "C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat" '"this does" "not"'
The pushbullet.bat takes two argument and if arguments are surrounded by " ", it will also work with spaces. And copy pasting either of these two into PowerShell works:
start "C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat" '"this does" "not"'
Suggestions?
jannl
Domoticz version: 2026.1.x
Re: Unable to execute batch file with spaces in arguments
Post by jannl »
Not sure what you mean. It makes sense the argument with spaces does not work. Every parameter in a bash call is seperated with spaces. Counts for every programming language.
Why not use the quotes?
quack3d
Post by quack3d »
Yeah, I know. I guess I wasn't clear enough. I can't get any of those to work in LUA in Domoticz. The print looks right, but it won't send a notification when using quotes and two words. The two lines I wrote at the bottom works only if I paste it in PowerShell.
emme
Domoticz version: latest
Post by emme »
local title3 = 'this does'
local message3 = 'not'
local tit_msg3 = title3..' '..message3
local path3 = 'C:\\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat'
local combined3 = path3..' "'..tit_msg3..'"'
can you try this?
...could you explain also why you use the [[ ]] ?
ciao
M
"We always done this way"
quack3d
Post by quack3d »
I assume you meant \\ for every \ like this: 'C:\\Program Files (x86)\\Domoticz\\scripts\\batch\\pushbullet.bat'
The print for that became LUA: C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat "this does not"
Quotes around the whole "this does not" doesn't look correct and It didn't send any notification either.
I used [[ ]] because I saw it in other examples. :D
emme
Post by emme »
about the \\ you're right
I'm a bit unclear about the right syntax for the command....
let's forget for a while LUA and domoticz... on a simple commandline how the bat will be lounched?
like
pushbullet.bat This is not
pushbullet.bat "This is not"
pushbullet.bat "This" "is" "not"
if spaces are the problem you can also try to fix this line:
local path3 = 'C:\\Program Files (x86)\\Domoticz\\scripts\\batch\\pushbullet.bat'
local combined3 = '"'..path3..' '..tit_msg3..' "'
this should print
"C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat This is not"
but I also in a doubt that windows should be like
local combined3 = '"'..path3..'" '..tit_msg3
"C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat" This is not
quack3d
Post by quack3d »
the .bat needs to be launched like this: .\pushbullet.bat "this does" "not"
The words 'this does not' was just to illustrate that it didn't work. Basically the batch takes two arguments that allows spaces. The first argument will be shown as title and the second as message. Like this: .\pushbullet.bat "this is the title of the push" "and this is the message body"
But even when I get the print to look correctly, the notification doesn't work.
But now I finally made it:
    local title7 = 'the title of the notification'
    local message7 = 'the message body of the notification'
    local tit_msg7 = title7..'"' .. ' "' ..message7
    local path7 = '""C:\\Program Files (x86)\\Domoticz\\scripts\\batch\\pushbullet.bat"'
    local combined7 = path7..' "'..tit_msg7..'""'
    os.execute(combined7)
That prints this: LUA: ""C:\Program Files (x86)\Domoticz\scripts\batch\pushbullet.bat" "the title of the notification" "the message body of the notification""
Now I replaced the message with otherdevices[text_sensor]. Great success! :D
Here is the code for the pushbullet.bat in case anyone else wants to use it:
@echo off
set api=<type your Pushbullet API key here>
set title=%~1
set body=%~2
curl -u %api%: https://api.pushbullet.com/v2/pushes -d type=note -d title="%title%" -d body="%body%"
