Fitbit Aria WiFi Scales Weight Bash Script
Posted: Wednesday 31 January 2018 22:04
by ben53252642
Hey Folks,
This is a bash script for getting weight data from the Fitbit Aria scales and loading it into Domoticz.
1) Register a new Fitbit app here: https://dev.fitbit.com/apps/new, the redirect domain also known as the "Callback URL" does not need to be real, the OAuth 2.0 Application Type is: personal, select read only access.
2) Copy your fitbit apps "OAuth 2.0 Client ID" and put it into the URL below along with your "Callback URL", then visit it using Google Chrome
https://www.fitbit.com/oauth2/authorize?client_id=ENTERYOURCLIENTIDHERE&redirect_uri=ENTERYOURREDIRECTURLHERE&response_type=code&scope=weight+activity+heartrate+location+nutrition+profile+settings+sleep+social
EXAMPLE of how it should look with the added "OAuth" and "Callback URL":
https://www.fitbit.com/oauth2/authorize?client_id=abc123&redirect_uri=https://domoticz.com&response_type=code&scope=weight+activity+heartrate+location+nutrition+profile+settings+sleep+social
When you get to the Fitbit page asking if you want to authorize your app, right click the page and select "Inspect", go to the "Network" tab in Google Chrome then proceed with allowing Fitbit to authorize the app. Look for ?code= in the "Network" tab url's you should see a 40 character long code, put it in the "code" configuration section of the bash script below.
3) Go back to your app https://dev.fitbit.com/apps and copy the client id, client secret and callback URL into the script Fitbit configuration section.
4) Create a new Virtual Sensor in Domoticz type "Scale (Weight)" and get its IDX code from the Domoticz devices page.
5) Enter the IDX number in the bash script, fill out the Domoticz configuration section and set the weight units in the script
To make this as simple as possible, you do not need to edit anything outside of the two lines that look like this:
6) Install system requirements at the Linux terminal: sudo apt-get install jq bc screen
7) Run the script ./aria.sh
aria.sh
#!/bin/bash
# Fitbit Configuration obtained from your app at: https://dev.fitbit.com/apps
clientid="ENTERHERE" #OAuth 2.0 Client ID
clientsecret="ENTERHERE" #Client Secret
callbackurl="ENTERHERE" #Callback URL, eg: https://domoticz.com
# Fitbit Configuration obtained from the browser redirect
code="ENTERHERE"
# Fitbit Configuration weight units
units="Metric" #Options are: Metric, en_US, en_GB
# Domoticz Configuration
domoticzserver="192.168.0.5"
domoticzport="443"
domoticzuser="USERNAME"
domoticzpass="PASSWORD"
domoticzweightsensoridx="ENTERHERE" # Virtual Sensor Type: Scale (Weight)
# Path to folder containing this script
cd /root/scripts/fitbit
# Create fitbit basic auth token
basicauthtoken=$(echo -n "${clientid}:${clientsecret}" | openssl base64)
while true; do
# Get a Fitbit oauth2 token
refreshtoken=$(cat refreshtoken.txt 2> /dev/null)
# If we already have a stored token, get a new one.
if [ ! -f refreshtoken.txt ]; then
echo "Getting access token for the first time..."
oauth=$(curl --max-time 60 -s -X POST -H "Content-Type: application/x-www-form-urlencoded" -H "Authorization: Basic ${basicauthtoken}" "https://api.fitbit.com/oauth2/token?client_id=${clientid}&grant_type=authorization_code&redirect_uri=${callbackurl}&code=${code}")
echo "Detected existing refresh token, getting a new access token..."
oauth=$(curl --max-time 60 -s -X POST --header "Content-Type: application/x-www-form-urlencoded" --header "Authorization: Basic ${basicauthtoken}" "https://api.fitbit.com/oauth2/token?client_id=${clientid}&grant_type=refresh_token&refresh_token=${refreshtoken}")
fi
# Put oauth2 token into easy to use variables and store the refresh token
accesstoken=$(echo "$oauth" | jq ".access_token" | sed 's/["]*//g')
newrefreshtoken=$(echo "$oauth" | jq ".refresh_token" | sed 's/["]*//g')
echo "$newrefreshtoken" > refreshtoken.txt
# Get weight data
date=$(date +"%Y-%m-%d")
getweight=$(curl --max-time 60 -s -X GET -H "Authorization: Bearer ${accesstoken}" -H "Accept-Language: ${units}" "https://api.fitbit.com/1/user/-/body/log/weight/date/${date}/1d.json")
# Extract data from the received json array
latestkey="-1"
for row in $(echo "${getweight}" | jq -c '.weight[]'); do
latestkey=$(echo $(("$latestkey" + 1))) # Since they are all in a single line, we simply count the number of results to work out the latest index key
done
weight=$(echo "$getweight" | jq ".weight[${latestkey}].weight")
# Display data in terminal
echo "Weight: $weight"
# Check to see if a new weight has been recorded since the previous check
logid=$(echo "$getweight" | jq ".weight[${latestkey}].logId")
storedlogid=$(cat storedlogid.txt 2> /dev/null)
if [ "$logid" == "$storedlogid" ]; then
echo "No new weight data"
echo "New weight detected"
echo "$logid" > storedlogid.txt
# Final integrity check, does weight equal more than 5?
if (( $(echo "$weight > 5" |bc -l) )); then
# Send data to Domoticz
echo "Sending data to Domoticz..."
# Domoticz Virtual Sensor Type: Scale (Weight)
curl --max-time 60 -k -s "https://{$domoticzuser}:{$domoticzpass}@{$domoticzserver}:{$domoticzport}/json.htm?type=command&param=udevice&idx={$domoticzweightsensoridx}&nvalue=0&svalue={$weight}"
echo "Problem occured during the final integrity check"
fi
fi
sleep 1800
done
The script is set to loop every 30 minutes to check for new data.
An alternate version is under development which is able to detect when the Fitbit Aria joins the WiFi network after standing on the scales and get the latest data within seconds. This is useful if for example you want an audio announcement in your home after a new weight is recorded: eg "Congratulations you have lost x kilograms". It is expected to be made available in the next few days.
I use this bash script to start aria.sh and run it in the background using screen at startup:
startup.sh
#!/bin/bash
/usr/bin/screen -S ariamonitor -d -m nice -17 ionice -c2 -n6 /path/to/aria.sh
Notes:
1) If you delete refreshtoken.txt you must repeat step 2 and enter the new code into the bash script.
2) The send to Domoticz curl command is set to accept unsigned SSL certificates which may be a security risk.
3) You need to understand and edit as needed the above script to work in your own environment.
Re: Guide - Fitbit Aria WiFi Scales Weight Bash Script
Posted: Wednesday 31 January 2018 22:25
by ben53252642
The alternate version is now available (only different steps from the above script are listed, follow the original script for setup).
This version sits constantly searching for the Fitbit Aria and updates when it is detected. You can experiment with the "sleep 10" value in the "# Check to see if Fitbit Aria is online" section of the script which is the amount of time the system waits after the Aria is detected online before checking for the new weight from the Fitbit API.
1) Set the Fitbit Aria LAN static ip address in the script (you will also need to have your router configured to give the Fitbit Aria a static IP based on it's mac address
2) System requirements: apt-get install jq bc screen fping
#!/bin/bash
code="ENTERHERE"
# Fitbit Aria LAN Static IP address
ariaip="ENTERHERE"
domoticzport="443"
domoticzuser="ENTERHERE"
domoticzpass="ENTERHERE"
while true; do
echo "Standing by to detect Fitbit Aria..."
until fping -b 12 -t 300 "$ariaip" &>/dev/null; do :; done
echo "Fitbit Aria Detected!"
sleep 10
fi
# Get weight data
latestkey="-1"
done
fi
fi
done
The terminal should look something like this:
Notes:
1) It is not recommended to use this version if your Domoticz server is connected to your WiFi router / access point via wireless. The script relies on low latency to be able to detect the Fitbit Aria during the brief time that it is connected to the network.
2) Do not use this version if you know your Fitbit Aria has a poor WiFi signal. If an Aria can't connect when you step on the scales, it will store the result and try again later. In this case you may as well use the first version of the script.
3) My observation is that an Aria is usually detected within about 30 seconds however it can take up to around 10 minutes for an Aria to be detected if it fails to update on WiFi during the first attempt. That said I have yet to see the script fail to detect an Aria, be patient, best results are achieved with a good WiFi signal.
Re: Fitbit Aria WiFi Scales Weight Bash Script
Posted: Thursday 01 February 2018 21:06
by Derik
mmm Perhaps this also working with this scale??
https://health.nokia.com/nl/en/body-plus
Posted: Thursday 01 February 2018 21:09
by ben53252642
Derik wrote: Thursday 01 February 2018 21:06 mmm Perhaps this also working with this scale??
Different system unfortunately, if I had one of their scales I could try to create a Domoticz interface but for now I'm happy with the Fitbit Aria, it's very good quality. If your looking for a scale I suggest getting the Aria.
Posted: Sunday 29 April 2018 14:24
by franzelare
did you ever try to post data to the fitbit api?
i have a different brand scale that is already connected to domoticz but like to send that data to my fitbit profile
Posted: Tuesday 01 May 2018 9:44
by ben53252642
franzelare wrote: Sunday 29 April 2018 14:24 did you ever try to post data to the fitbit api?
Not sure.
That said the Fitbit scales we're not expensive, I'm very happy with mine. Considering the amount of time it would take to create an interface (assuming it's even possible), I suggest thinking about switching to the Fitbit scale since there is an existing solution now for getting data into Domoticz.
Posted: Tuesday 01 May 2018 12:49
by DAVIZINHO
this is a great script and works perfect!!!
Its posible to obtain the body fat values???
hello again, edit my last post.
i see that the script receive all the data of the aria, like:
{"bmi":19.74,"date":"2018-05-01","fat":14.260000228881836,"logId":1525180250000,"source":"Aria","time":"13:10:50","weight":57.7}
now the script obtain the weight but its posible to obtain also the:
- bmi
- fat
this is great!!!, i will try to save this 2 values in a variables to push in 2 new custom idx in domoticz
im very noob in linux, but if i make it posible i post here
Posted: Tuesday 01 May 2018 21:18
by franzelare
ben53252642 wrote: Tuesday 01 May 2018 9:44
Not sure.
I use a medisana scale and blood pressure sensor, both connected through BT-LE with a raspi zero, works fine! so i already have the data in domoticz
so will try to push data to fitbit api.. when i read the api documentation, it must not be so hard when i use this script as start
Posted: Wednesday 02 May 2018 13:41
by DAVIZINHO
Hello again,
I modify the script with this 2 easy things:
Firs in config parameters i put the idx of the new 2 devices: fat and bmi
domoticzbmisensoridx="185" # Virtual Sensor Type: Scale (bmi)
domoticzfatsensoridx="184" # Virtual Sensor Type: Scale (fat)
After this in the # Extract data from the received json array y add this
bmi=$(echo "$getweight" | jq ".weight[${latestkey}].bmi")
fat=$(echo "$getweight" | jq ".weight[${latestkey}].fat" | cut -c 1-5)
To obtain the bmi and fat
Then the last thing is update domotic with this 2 lines:
# Domoticz Virtual Sensor Type: Scale (BMI)
curl -s -i -H "Accept: application/json" "http://{$domoticzuser}:{$domoticzpass}@{$domoticzserver}:$domoticzport/json.htm?type=command&param=udevice&idx=$domoticzbmisensoridx&nvalue=0&svalue=$bmi"
# Domoticz Virtual Sensor Type: Scale (Fat)
curl -s -i -H "Accept: application/json" "http://{$domoticzuser}:{$domoticzpass}@{$domoticzserver}:$domoticzport/json.htm?type=command&param=udevice&idx=$domoticzfatsensoridx&nvalue=0&svalue=$fat"
easy changes and very usefull for me.
Thanks for your work and inspiration!!!
Posted: Wednesday 02 May 2018 13:55
by ben53252642
DAVIZINHO, very good!
I will add these into my Domoticz as well.
Posted: Monday 28 May 2018 22:23
by DAVIZINHO
hello.
Recently I need to reinstall domoticz :-(
And now the aria script stop working :-(
The first error was:
./aria.sh: lĂ­nea 56: refreshtoken.txt: Permiso denegado
jq: error (at <stdin>:1): Cannot iterate over null (null)
i solved it by sudo chmod 777 refreshtoken.txt
after this, i run again and this error:
Weight: null
bmi: null
fat: null
No new weight data
any idea???
this works like a charm and now broken. im sure is my problem :-(
Posted: Tuesday 29 May 2018 3:20
by ben53252642
Try getting another token (follow steps in the first post using Google Chrome), you will need to delete refreshtoken.txt it will get re-created automatically.
Does that fix it?
Posted: Tuesday 29 May 2018 13:06
by DAVIZINHO
WOW, im stupid!!!
i thought this steps are only necesary for the first time, jejeje.
I make it again and works like a charm!
thanks!!!
Posted: Friday 18 January 2019 10:05
by capman
Everything is working fine after some try and edit ;) . Except one issue. When I close my ssh terminal the script is stopt running.
What I have done. First my domoticz server is working with http , and not https. So in the script I change the https to http.
In the ssh terminal I go to the map where the script is and execute it with ./NAMEOFSCRIPT.sh . And it's working the value from the weigt
on my fitbit scale is sending to my dummy weight scale sensor. So I close the terminal and now nothing is sending to domoticz.
What should I do to make this working ? Thanks 8-)
Posted: Saturday 19 January 2019 17:59
by capman
It's working ! I forgot to activate the startup.sh script. Stupid me.
Thanks 4 this great script !!
Posted: Sunday 20 January 2019 12:50
by capman
What about multiple users ? Can I just copy the script and edit the script for the other user ?
Posted: Wednesday 23 October 2019 16:16
by mikeymike
Great topic, thanks for the script(s)!
I added also the fitbit data (not only the aria weight) but have some issues with the 'distance' output I get back from the Fitbit API.
There are more 'activity's' in the output and want only the "total" to be pushed to Domoticz.
Maybe someone can point me in a direction how to extract this from the output, I already checked the https://dev.fitbit.com/build/reference/ ... /activity/ for documentation but don't see a solution.
I added the following lines to the fitbit.sh script:
distance=$(echo "$getactivities" | jq ".summary.distances")
echo "Distance: $distance"
The script shows the following output:
Weight: 87
BMI: 27.4
Fat: 27
Steps: 3705
Floors Climbed: 0
Distance: [
"activity": "total",
"distance": 2.74
"activity": "tracker",
"distance": 2.74
"activity": "loggedActivities",
"distance": 0
"activity": "veryActive",
"distance": 0
"activity": "moderatelyActive",
"distance": 0
"activity": "lightlyActive",
"distance": 2.73
"activity": "sedentaryActive",
"distance": 0
Calories Out: 1699
Sedentary Minutes: 337
Total sleep: 445
How to get the 'total' out of the distance output?
Thanks in advance!
FYI ;-) This is what I got for now:
I also created some Fitbit Aria en Fitbit Charge icons, if you are interested i attached them to this post ;-)
Posted: Thursday 13 August 2020 23:29
by smika
I tried to connect my charge4 but something goes wrong with jq:
parse error: Invalid numeric literal at line 1, column 10
Weight: null
Steps: null
Floors Climbed: null
Calories Out: null
Sedentary Minutes: null
Waiting 30 minutes before next update...
Is there someone who can give me a hint into the right direction? What for information I need to provide for the support?
Smika
Posted: Monday 17 August 2020 9:42
by ben53252642
Sorry I no longer use this script, I haven't used it in the last year or so.
I'm guessing the issue may be related to not running it as a bash script?
Are you starting the script using sh scriptname.sh?
Try ./scriptname.sh for testing.
