Concrete Slab Heating Control
Qcvictor
Post by Qcvictor »
Hi Guys
This is my script for controlling my heater concrete slab, everything is working excepted in cold temperature the Geo stuck because geothermal output temp is too low, I added another probe on the geothermal output for monitoring this temperature.
Need help for introduced this new sensor for stop the Geo unit until she goes up a couple degrees for restart....
Any clue ?
local heating_probe = 'SensorTempSlab'    --Probe Name Concrete Slab
local heating_probe_geo = 'SensorTempGeo' --Probe Name Geothermal Outpout Slab
local thermostat_setpoint = 'Thermostat'  --Virtual Thermostat
local heating_unit = 'GeoUnit'            --Virtual Switch Relay On/off Geothermal Unit
local OnOff = 'Heating Slab On/Off'       --Virtual Switch Script On/Off
local heating_probe_geo_consigne = 35     --Minimum Temp Geothermal Outpout Threshold (°c)
local hysteresis = 0.5                    --Setting Hysteresis (°c)
if (otherdevices[OnOff]=='On') then
-- loop through all the devices
for deviceName,deviceValue in pairs(otherdevices) do
        if (deviceName== thermostat_setpoint ) then
            if tonumber(deviceValue) < tonumber(otherdevices[heating_probe]-hysteresis) then
                if (otherdevices[heating_unit] == "On") then
                commandArray[heating_unit]='Off'
                print("Heating is Off")
            elseif tonumber(deviceValue) > tonumber(otherdevices[heating_probe]+hysteresis) then
                if (otherdevices[heating_unit] == "Off") then
                commandArray[heating_unit]='On'
                print("Heating is On")
-- loop through all the variables
for variableName,variableValue in pairs(uservariables) do
                elseif (devicechanged[OnOff]=='Off') and (otherdevices[heating_unit]=='On') then
                    print ('chauffage extinction')
