skyQ integration/control
Posted: Sunday 28 January 2018 17:30
Ciao,
I recently installed the new SkyQ decoder which looks very nice (finally!!!)
I know there are some few differences between the italian software and the EU software, but the hardware is almost the same.
The decoder looks to have a small API available that can be used to send the remote commands...
I found the script in another forum
but I had to change it a bit to handle the 4digits channels
here it is: save it where you prefer with extension .py then make it executable (sudo chmod +x <filename> ) and then in domoticz you can create a selector switch for each action you can call the script with parameters:
./skyQ.py command <remote command>
./skyQ.py chno <channel number>
./skyQ.py channel <channel name> (this must be configured into the def getchannelno( channel ) )
Hope you enjoy it
ciao
M
here it is:
#!/usr/bin/env python
import sys
import socket
import math
import array
from time import sleep
host_ip = "192.168.0.11" #Sky Q box address
port = 49160
def sendcommand(host,command):
code = getcode(command)
cmd1 = int(math.floor(224 + (code/16)))
cmd2 = int(code % 16)
command1 = array.array('B', [4, 1, 0, 0, 0, 0, cmd1, cmd2]).tostring()
command2 = array.array('B', [4, 0, 0, 0, 0, 0, cmd1, cmd2]).tostring()
s = socket.socket()
s.connect((host,port)) #connect to SkyQ box
reply = s.recv(12) #receive handshake
s.send(reply) #send handshake
reply = s.recv(2) #receive 2 bytes
s.send(reply[0]) #send 1 byte
reply = s.recv(4) #receive 4 bytes
reply = s.recv(24) #receive 24 bytes
s.send(command1) #send command bytes part 1
s.send(command2) #send command bytes part 2
s.close() #close connection
def getcode(cmdname):
commands = {
"power": 0,
"select": 1,
"backup": 2,
"dismiss": 2,
"channelup": 6,
"channeldown": 7,
"interactive": 8,
"sidebar": 8,
"help": 9,
"services": 10,
"search": 10,
"tvguide": 11,
"home": 11,
"i": 14,
"text": 15,
"up": 16,
"down": 17,
"left": 18,
"right": 19,
"red": 32,
"green": 33,
"yellow": 34,
"blue": 35,
"0": 48,
"1": 49,
"2": 50,
"3": 51,
"4": 52,
"5": 53,
"6": 54,
"7": 55,
"8": 56,
"9": 57,
"play": 64,
"pause": 65,
"stop": 66,
"record": 67,
"fastforward": 69,
"rewind": 71,
"boxoffice": 240,
"sky": 241
return commands[cmdname]
def getchannelno( channel ):
chno = {
'sky_news': 100,
'sky_discovery': 401,
'sky_fox_animation': 127
return chno[channel]
if len(sys.argv) == 1:
print "no parameters"
sys.exit(2)
if sys.argv[1] == "channel":
if len(sys.argv) < 3:
print 'USAGE:',sys.argv[0],'[<command>|channel <channel name>]'
sys.exit(2)
chno = getchannelno(sys.argv[2])
for x in range(0,len(str(chno))):
sendcommand(host_ip,str(chno[x]))
sleep(0.2)
elif sys.argv[1] == "chno":
chno = sys.argv[2]
for x in range(0,len(chno)):
sleep(0.2)
else:
sendcommand(host_ip,sys.argv[1])
Hope you enjoy it
ciao
M
