Dash board switch indicator
Posted: Sunday 28 January 2018 14:05
by Nelson
Why do I have to hit off switch twice for it to show correct in dashboard. For example with light starting on, hit off light goes off, dashboard switch indicator shows on, hit off again light still off, dashboard indicator goes to off. Note switches have dimming. These are zwave bulbs. Using current stable version, but had issue with or versions too.
Re: Dash board switch indicator
Posted: Thursday 01 February 2018 16:57
by emme
sometimes I got the same too... on both dimmers and rolling shutters positions
I think is a zWave issue and realted to an eventual delay in sending the command
dimmers switch off smoothly, when you hit the button domoticz send the signal and read the status back, but if the controller delays for any reason, the status could not OFF yet, but Level 50% (or other value from 100%), then it apply to the switch config
To limit this you can try to enable polling on the device but be sure you set a value in seconds NOT less than the number of devices you and configured in your zwave controller
ciao
M
Posted: Saturday 10 February 2018 1:48
by Nelson
Thank you emme for you responce. I'll try a few setting changes and post results.
