Hai.
Would it be possible to use a Somfy Tahoma to control Somfy equipment from Domoticz?
I have my Domoticz running on my Synology and a Tahoma connected to the internal network via a switch.
I also have access to the Tahoma via the Somfy cloud interface.
Would be nice to have a single point of control though as I also have some KaKu devices connected to Domoticz.
Control a Somfy Tahoma with Domoticz
Re: Control a Somfy Tahoma with Domoticz
im very interested
I need it
I need it
mallox
Hi there!
I'm quite new to domoticz and I have a Somfy Tahoma.
i just want to say you can control your tahoma with Domoticz using IFTTT.
On IFTTT you search for tahoma service and you link your account.
On IFTTT you create a new applet :
- IF "webhook" (enter the name of the event , something like 'open_velux")
- THEN launch scenario on Tahoma, and select the scenario you already have. If not, go and create some scenarios and come back here)
In domoticz, you add a new Hardware via setup menu. You choose "Dummy (Does nothing, use for virtual switches only)"
Then you edit the button, and select switch type : "Blinds" or "Blinds inverted"
On action : https://maker.ifttt.com/trigger/{event} ... BsCD8Kxwn4....
Off action : https://maker.ifttt.com/trigger/{event} ... BsCD8Kxwn4....
You have to do that for each blinds
Hope it helps
Hope it helps
- Screenshot 2019-01-29 at 01.34.13.png (129.69 KiB) Viewed 4509 times
abc1000
Thanks, got my IO screen working
But how do you use the MY function?
I'v created a MY scenario (ifttt), but how do i create that in my script?
I have no return signal..
abc1000
So i'll need a "my action" in switch type blinds.
abc1000 wrote: Wednesday 13 March 2019 12:54 Hi,
