Only one if...then working
Thelion
Domoticz version: 2022.1
Post by Thelion »
Hi!
I don't know if this is really an issue, or just the standard way that LUA works, but I found out that script that contains multiple if...then functions, only the last one seems to be triggered.
I have a script like this:
sNestSetpointHeatOn = tonumber(uservariables["uNestSetpointHeatOn"])
sNestSetpointHeatOff = tonumber(uservariables["uNestSetpointHeatOff"])
if ( uservariables["DV_Keuken_Heat"] == 1 or uservariables["DV_Woonkamer_Heat"] == 1 or uservariables["DV_Hal_Heat"] == 1 or uservariables["DV_PC-Kamer_Heat"] == 1  or uservariables["DV_BadKamer_Heat"] == 1  or uservariables["DV_KleedKamer_Heat"] == 1 ) and uservariables["DV_Nest_Heat"] == 0 then
   commandArray['Variable:DV_Nest_Heat']='1'
   commandArray['Nest Verwarmen'] = "On"
   commandArray['SendNotification']='[Nest Verwarmen Aan#[Nest Verwarmen Aan]#0#Classical'
   print('<font color="RED">[DV Nest Aan]</font>')
   commandArray [ 'UpdateDevice'] = "29 | 0 | "..sNestSetpointHeatOn
if ( uservariables["DV_Keuken_Heat"] == 0 and uservariables["DV_Woonkamer_Heat"] == 0 and uservariables["DV_Hal_Heat"] == 0 and uservariables["DV_PC-Kamer_Heat"] == 0  and uservariables["DV_Badkamer_Heat"] == 0  and uservariables["DV_Kleedkamer_Heat"] == 0 ) and uservariables["DV_Nest_Heat"] == 1 then
   commandArray['Variable:DV_Nest_Heat']='0'
   commandArray['Nest Verwarmen'] = "Off"
   commandArray['SendNotification']='[Nest Verwarmen Uit]#[Nest Verwarmen Uit]#0#Classical'
   print('<font color="RED">[DV Nest Uit]</font>')
   commandArray [ 'UpdateDevice'] = "29 | 0 | "..sNestSetpointHeatOff
In this script only the last if..then is ever triggered.
When i split it into 2 seperate scripts, like:
if (uservariables["DV_Keuken_Heat"] == 1 or uservariables["DV_Woonkamer_Heat"] == 1 or uservariables["DV_Hal_Heat"] == 1 or uservariables["DV_PC-Kamer_Heat"] == 1 or uservariables["DV_Badkamer_Heat"] == 1 or uservariables["DV_Kleedkamer_Heat"] == 1) and uservariables["DV_Nest_Heat"] == 0 then
and
if (uservariables["DV_Keuken_Heat"] == 0 and uservariables["DV_Woonkamer_Heat"] == 0 and uservariables["DV_Hal_Heat"] == 0 and uservariables["DV_PC-Kamer_Heat"] == 0 and uservariables["DV_Badkamer_Heat"] == 0 and uservariables["DV_Kleedkamer_Heat"] == 0) and uservariables["DV_Nest_Heat"] == 1 then
They both are triggered when they are supposed to and all works wel.
Is there an explanation for this?
Martijn
freijn
Domoticz version: Stable
Re: Only one if...then working
Post by freijn »
First thing to try...
if ( I only see the opening ( not the closing ) (or do I need to clean my Bril ? )
I suggest to put the ) just before the then and try it again.
Cheers,
Frank
Thelion
Post by Thelion »
Hi freijn,
I think you need to clean your bril ;-) There is a closing bracket, but it is before the last "and".
And the brackets are EXACTLY the same in the separate scripts and there is works flawlessly.
freijn
Post by freijn »
Oeps :-)
then try it with only 1 ==
and put a print statement in the both if's and see which one is selected...
if <= haha that is working start building the other == with it.
try and error... sorry..
Frank
SweetPants
Post by SweetPants »
If both your 'if' statements are valid, then only the last commandArray will be executed. The first is overridden. So your conclusion is correct.
Maybe change the lase if to elseif?
Thelion
Post by Thelion »
Ah. So I’m not losing my mind. :roll:
I don't mind splitting it in two separate scripts, or using elseif for that matter, but I was wondering if this was a bug or by design.
Thanks SweetPants.
Does this also go for DzVents? Or is it possible to have two if..then statements there?
Thelion
Post by Thelion »
Erhm. I just re-read SweetPant's message, and I noticed something. Both if statements are never both valid. So it shouldn't be a problem.
Thelion
Post by Thelion »
Anybody any thoughts on this?
freijn
Post by freijn »
Have you tried my suggestion made a few posts back ?
Thelion
Post by Thelion »
Partly. There is already a print statement in both and only the last one is ever selected.
I didn't know exactly what you meant by
Care to explain?
freijn
Post by freijn »
At least that is my approach if I can't get it to work.. Simplify it and see what happens
So my suggestion :
if ( uservariables["DV_Keuken_Heat"] == 1 or uservariables["DV_Woonkamer_Heat"] == 1 )then
if ( uservariables["DV_Keuken_Heat"] == 0 and uservariables["DV_Woonkamer_Heat"] == 0 )then
Like this or even a single uservariables["DV_Keuken_Heat"] == 1 without an 'or' and 'and'
Strip down the complexity and try if it works, then slowly start building up.
Please let me know if you got my suggestion now, otherwise we switch to pm's and in dutch :-)
Cheers,
Frank
Thelion
Post by Thelion »
Ah. I understand now.
Thanks. Will try that.
