Reading UPLOAD / DOWNLOAD from TomatoUSB
Posted: Friday 26 January 2018 18:20
by sincze
I've been searching the forum to see if it would be possible to read data from my TomatoUSB/ shibby router.
Unfortunately my search was not good enough as I could not find any results.
So I had to build something myself.
To see if all is working I enabled the rsync feature to replicate data from and to a remote location.
This to emulate upload and download.
The script is running on the router itself and posts the data to 2 virtual sensors (COUNTERS).
At the moment it runs every minute or so, but that can be changed to every 5 minutes or every hour.
Probably the /tmp/var/spool is not the best directory but this is just an initial test. :lol:
After a reboot it will be gone.
Just add the following to the Administration -> scripts -> init.
SCRIPT="/var/spool/script.sh"
cat << "EOF" > $SCRIPT
#!/bin/sh
DOMO_IP="***.***.***.***"         # Domoticz IP Address
DOMO_PORT="8080"               # Domoticz Port
UPLOAD_IDX="***"              # Upload IDX
DOWNLOAD_IDX="***"            # Download IDX
killall -USR2 rstats           # Create the statistics
sleep 2                        # Just wait for statistics to be created
if [ -e /var/spool/rstats-history.js ]            # Execute only if file exists
then
        input=$(cat /var/spool/rstats-history.js | grep -A 1 'daily' | grep "[[A-Za-z]]" | sed 's/\],\[/\n/g' | tr -d '[' | tr -d '];' | tail -1)
        download=$(echo $input | cut -f2 -d ',')
        upload=$(echo $input | cut -f3 -d ',')
        upload=$((upload/1024))             # HEX -> DEC conversion and in MB
        download=$((download/1024))         # HEX -> DEC conversion and in MB
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$UPLOAD_IDX&svalue=$upload"
        curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$DOWNLOAD_IDX&svalue=$download"
        echo "File not created!"
fi
EOF
chmod +x $SCRIPT
# uncomment the following line if you want it to execute immediately
#$SCRIPT &
the script file will be created.
You will only have to run it every x minutes or so via: administration -> scheduler.
/tmp/var/spool/script.sh 2>&1 >> /dev/null
