Page 1 of 15
Low cost window/door sensor
Posted: Tuesday 01 April 2014 21:46
by Raspberry Piet
Just to inform compatibility:
For € 2,59 i bought a new Door-sensor (to replace an unreliable AMST-606 KAKU)
This one:
http://www.ebay.nl/itm/Wireless-Door-Wi ... dc3&_uhb=1
After placing a few jumpers the RFXCOM recognized it as:
Packettype = Lighting5
subtype = BBSB new
Sequence nbr = 1
ID = 075555
Unit = 2
Command = Off
Signal level = 7
(other jumper configs results in different ID's)
One disadvantage: It just sends an Off signal (once when door opens) , never an On signal.
For my purpose it doesn't matter, i'm gonna mount it on the letter flap/mailbox (for push-message notification)
Make sure you buy the
433 Mhz version with the
PT2262 chip!
Re: Low cost window/door sensor
Posted: Tuesday 01 April 2014 22:48
by Keptenkurk
Thanks! Ordered two of them...
/paul
Posted: Tuesday 01 April 2014 23:06
by sstolk
Keptenkurk wrote:Thanks! Ordered two of them...
/paul
Same here! 5 euro is not much and maybe they work good enough...
Posted: Tuesday 01 April 2014 23:09
by CopyCatz
Hmm 2 fibaro cat eyes or 20 of these... meh fibaro it is
Posted: Tuesday 01 April 2014 23:32
by Raspberry Piet
CopyCatz wrote:Hmm 2 fibaro cat eyes or 20 of these... meh fibaro it is
You rich kid! I bet you live in a very big house with 20 doors!
These fibaro cat eyes look beautiful!
Posted: Wednesday 02 April 2014 0:53
by Raspberry Piet
I think this PIR motion sensor will work also:
http://www.ebay.nl/itm/171089657359?var ... 1439.l2649
Same 2262 chip and jumpers.
I ordered one.
Will report here if working or not.
edit: Yes! the RFXCOM recognized it as:
Packettype = Lighting1
subtype = ARC
Sequence nbr = 0
housecode = P
unitcode = 16
Command = Off
Signal level = 7
The pir pcb looks slightly different as advertised.
Type PIR538C.
Signal transmission time is about one second. (1.3s)
Have to find out about the different jumper settings.
Posted: Wednesday 02 April 2014 8:01
by BigDog
Erg intresant die ga ik ook bestellen
Posted: Wednesday 02 April 2014 10:21
by sstolk
@Raspberry Piet,
What is your jumper setting? And is it complete impossible to send on commands?
Posted: Wednesday 02 April 2014 19:43
by Derik
Mwhaaaa..
Are those not the sensors that turn your system on a locked for x seconds??
This may mean that every few seconds nothing to start with your domoticz system
The famous bomsignaal ....
http://www.domoticaforum.eu/viewtopic.php?f=27&t=7337
Or are this different motionsensors.??
Because then they do have potential....
Posted: Wednesday 02 April 2014 19:57
by BigDog
As far as i know its not a kaku device
with bomb sigbal
Posted: Wednesday 02 April 2014 20:01
by Derik
I hope you can perhaps test it in the RFXcom [ manager? ]
If it give a bomb you do not use them!!!
Your system is than useless..
Posted: Wednesday 02 April 2014 20:34
by Raspberry Piet
Derik wrote:I hope you can perhaps test it in the RFXcom [ manager? ]
The RFXmngr ignores duplicated packets so can't tell for sure?
But I think it doesn't send a bomb signal.
Simple test: Dummy switch fires a script (that sends a RF signal for lights on) after it received the signal from the chinese door sensor.
The light goes on without delay.
Posted: Wednesday 02 April 2014 20:39
by Derik
There is no delay.
The moment of sending is not the problem.
The time of sending is the problem..
Perhaps you can ask Bert, on his forum..
How you can test the sensor..
Posted: Wednesday 02 April 2014 20:44
by Raspberry Piet
sstolk wrote:@Raspberry Piet,
Jumper settings:
You can choose setting 1.5m 3.3m 4.7m
Choose 3.3m
Setting for different ID's A0-A7 i think.
My setting now is A1 High wich gives ID 075555
Have not checked all possibilities.
Without hardware tweaks i think it will not send on commands.
Posted: Wednesday 02 April 2014 20:46
by Keptenkurk
It could take some time before the door sensor arrives but then i will check with my SDR receiver and see the transmission time.
/paul
Posted: Wednesday 02 April 2014 20:54
by Derik
Keptenkurk wrote:It could take some time before the door sensor arrives but then i will check with my SDR receiver and see the transmission time.
/paul
Mwhhhaa..
In that way i order one...
When you can give the answer, it is very cheap.
I do now try the zwave pir and motion.
Only they are not realy stable on my RPi..
Posted: Wednesday 02 April 2014 21:01
by Raspberry Piet
Derik wrote:There is no delay.
Can't follow. Doesn't sound logical to me.
The RFXCOM sends a RF signal immediately after receiving the RF signal from the chinese sensor.
So my conclusion is the signals don't interfere each other.
In practice the chinese sensor works more reliable for my letter flap than the KAKU ever did.
Derik wrote:Perhaps you can ask Bert, on his forum..
Maybe can test/compare the signal with a RTL-SDR dongle, will try if i find time for it.
Posted: Wednesday 02 April 2014 21:04
by Raspberry Piet
/paul
Ah same thought here about the SDR receiver!
Well my order arrived very quick this time! Only 8 days!
Posted: Tuesday 15 April 2014 12:31
by bizziebis
When you open a door, it sends a off command. What about when you close the door, does it send another off command?
If that's the case, it's easy to write a script which sets an switch for a open or closed door.
Posted: Tuesday 15 April 2014 18:43
by Derik
/paul
Paul..
Do you now more?
