Converting Blockly to dzVents
htilburgs
Post by htilburgs »
I'm currently in the process of converting my Blockly scripts to dzVents.
I've a Blockly script that sends a notification when the front- or backdoor is opened, while the switch "Beveiliging" has status ON
Sensor - Blockly.png (72.1 KiB) Viewed 1658 times
In dzVents I've made the following config:
    on =
        devices = {
            'Sensor Voordeur',
            'Sensor Achterdeur',
            'Beveiliging'
        if
            {(device.name == 'Sensor Voordeur' and device.state == 'Open') and
            (device.name == 'Beveiliging' and device.state == 'On')}
        then
            domoticz.notify('Beveiliging', 'De voordeur wordt geopend')
            domoticz.log('Voordeur wordt geopend!!')
        elseif
            {(device.name == 'Sensor Achterdeur' and device.state == 'Open') and
        then
            domoticz.notify('Beveiliging', 'De achterdeur wordt geopend')
            domoticz.log('Achterdeur wordt geopend!!')
This works partly, but I cannot figure out what I'm doing wrong (I'm not a programmer and doing this with looking at examples)
In the Domoticz log (and also the notification) I get for both frontdoor (voordeur) as for backdoor (achterdeur) "Beveiliging: De voordeur wordt geopend"
Domoticz Log:
2018-01-26 10:20:24.607 dzVents: Info: Handling events for: "Sensor Achterdeur", value: "Open"
2018-01-26 10:20:24.607 dzVents: Info: ------ Start internal script: Sensoren: Device: "Sensor Achterdeur (Aeon Labs Z-Stick GEN5)", Index: 559
2018-01-26 10:20:24.607 dzVents: Info: Voordeur wordt geopend!!
2018-01-26 10:20:24.607 dzVents: Info: ------ Finished Sensoren
2018-01-26 10:20:24.680 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2018-01-26 10:20:26.113 dzVents: Info: Handling events for: "Sensor Achterdeur", value: "Closed"
2018-01-26 10:20:26.113 dzVents: Info: ------ Start internal script: Sensoren: Device: "Sensor Achterdeur (Aeon Labs Z-Stick GEN5)", Index: 559
2018-01-26 10:20:26.113 dzVents: Info: Voordeur wordt geopend!!
2018-01-26 10:20:26.113 dzVents: Info: ------ Finished Sensoren
2018-01-26 10:20:26.191 EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Does anyone see a 'programming' error?
Hardware:
emme
Domoticz version: latest
Re: Converting Blockly to dzVents
Post by emme »
    on =
        devices = {
            'Sensor Voordeur',
            'Beveiliging'
        if domoticz.devices('Sensor Voordeur').state == 'Open' and domoticz.devices('Beveiliging').state == 'On'
        then
        elseif domoticz.devices('Sensor Achterdeur').state == 'Open' and domoticz.devices('Beveiliging').state == 'On' then
dzVents runs once on each device change....
that means that by the time the script runs device.name has only 1 vlue (one of the 3 devices) so any if condition that requires an AND with 2 differen device.name will never came true
With this correction the script will run anytime one of the 3 devices change state... the script doest't care who, it just run
hope this would help
ciao
M
"We always done this way"
htilburgs
Post by htilburgs »
emme wrote: Friday 26 January 2018 10:57
    on =
        devices = {
            'Sensor Voordeur',
            'Beveiliging'
        then
ciao
M
Thnx, that works!
So the difference is in the using of domoticz.devices instead of device.name?
If I'm correct in the device.name you refer to only 1 device and with domoticz.devices you refer to the defined array "devices=..."?
(I'm trying to learn dzVents... :) )
Now for the difficult part:
The frontdoor is open and notification is send.
Then (while the frontdoor is open) I open the backdoor. In this case I still got the message "Beveiliging: De voordeur wordt geopend" instead of the achterdeur.
Hardware:
emme
Post by emme »
the execute = function(domoticz, device) works in this way:
domoticz contain the full table of domoticz framework... device, variables, scenes etc etc...
device contains only the device/variable/timer information that act the script (it works like a shortcut, but it inlcude some more option)
the hard part is because you trigger the script based on 3 devices, but you test only 2... so you can loose a possible state.
so.. explain exactly what behaivour you want to achieve...
I would also ask you if you can translate the messages in English (I'm much more familiar with :P :P) so I can better understand the situation and modify the script accordingly
thanks
ciao
M
Eoreh
Post by Eoreh »
I'm finishing (on this weekend) work on a general script that simplifies this syntax in dzVents. (for "Block" People)
Syntex to set up only on begin skrypt will be like this
plans={
{ onDevice={'Sensor Voordeur',state='On'}, where={'Beveiliging',state='On'}, notify={'Beveiliging','De voordeur wordt geopend'}, log={'Voordeur wordt geopend!!'},
{ onDevice={'Sensor Achterdeur',state='Open'}, where={'Beveiliging',state='On'}, notify={'Beveiliging','De achterdeur wordt geopend'}, log={'Achterdeur wordt geopend!!'}
This will be all that y have to set on at script (at the beginning).
I dont know your language but I believe that I did it well do copy&paste your name devices and text. In general, I mean ideas.
With this script You can do simple a lot of things.
Sounds interesting ?
htilburgs
Post by htilburgs »
Eoreh wrote: Friday 26 January 2018 13:22 I'm finishing (on this weekend) work on a general script that simplifies this syntax in dzVents. (for "Block" People)
plans={
Sounds great!
Hardware:
Eoreh
Post by Eoreh »
I finish ver 1.1 (tested by friends).
You can download and read about it here viewtopic.php?f=59&t=21914
Simple egzample script.
