Dear members,
I've tried to install buienradar on my Domoticz Windows 10 installation. It seems that the manual wasn't written for a Windows 10 user (or I mis something in the manual).
Can someone help me to find the plugins folder, or tell me if there is a alternative way to install buienradar in my setup?
Yours sincerely,
Dutchy
I can't find the plugin folder to install buienradar on Windows 10
jluc2808
Re: I can't find the plugin folder to install buienradar on Windows 10
it's under
C:\Program Files (x86)\Domoticz\plugins
if plugins folder doesn't exist you have to create it manually
then you could store the foler containing you python program inside and the plugin should be names plugin.py
by example :
C:\Program Files (x86)\Domoticz\plugins\Pinger\plugin.py
by example :
Thanks for your reply. I've done exactly what you say, but Domoticz isn't able to show me the buienradar option in the hardware setup. I've rebooted the system a few times to see if there was any effect.
Is there another solution to tackle this issue?
I've provided a image to show what I've put into the self created plugins folder.
